Avatar The Way of the Water dump submitted
Got the Best Buy steelbook 3 days early!
polskasubie
Re: Avatar The Way of the Water dump submitted
i just submitted the BB SB dump as well!
MKB20_v77_Avatar-_The_Way_of_Water_C2C8
IT needs to be done for the First Avatar that was released in 4K as well. Got both 3 days early from Best buy. How do you submit the BB SB Dump?
MKB20_v77_Avatar_DAF0.tgz
Submit the dump file to svq@makemkv.comBagdad48 wrote: Sat Jun 17, 2023 7:46 pm IT needs to be done for the First Avatar that was released in 4K as well. Got both 3 days early from Best buy. How do you submit the BB SB Dump?
ColonelBlimp043
I've submitted Avatar 1 and 2.
MKB20_v77_Avatar-_The_Way_of_Water_0F3E.tgz
I hope the e-mails went through with the domain issues.
Both of mine are on the way. I should have them Monday/Tuesday. BB SB on both.
rkhollister
Interesting - I just got my BB steelbook and have 0F3E, same as ColonelBlimppolskasubie wrote: Sat Jun 17, 2023 6:53 pm i just submitted the BB SB dump as well!
polskasubie
great... sounding like the JW4 issue with multiple keys for multiple different batches of discs...rkhollister wrote: Sat Jun 17, 2023 11:46 pmInteresting - I just got my BB steelbook and have 0F3E, same as ColonelBlimppolskasubie wrote: Sat Jun 17, 2023 6:53 pm i just submitted the BB SB dump as well!
ColonelBlimp043
Both discs are working now.
Not working for me. This is what I am seeing.
MakeMKV v1.17.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=62194E19F4EC)
Downloading latest HK to C:\XXXXX\XXXXX/.MakeMKV ...
Saved AACS dump file as C:\XXXXX\XXXXX/.MakeMKV/MKB20_v77_Avatar-_The_Way_of_Water_C2C8.tgz
rkhollister
my 0F3E Way of Water is now working as well. I'll try Avatar 1 again after this finishes
MSCloude115
I had the same issue with John wick 4. Restart your modem and flush your dns cache. It worksBagdad48 wrote: Sun Jun 18, 2023 1:43 pm Not working for me. This is what I am seeing.
Worked for me today.
The Best Buy Steelbook dump I submitted yesterday:
Thanks for the quick work Mike!
rkhollister
Anyone figure out the difference (if any) between to 2 titles on the 4K disc? I ripped both and spot checking I can't see a difference.
MPLS 800 has English subtitles burned in. MPLS 801 does not.rkhollister wrote: Sun Jun 18, 2023 8:28 pm Anyone figure out the difference (if any) between to 2 titles on the 4K disc? I ripped both and spot checking I can't see a difference.
