MakeMKV will not open a DVD disc
ianmck
Post by ianmck »
Hi
MakeMKV is having a problem opening one of my DVDs. I have been successful copying Bluray discs and other DVD's without issue, however, when a one specific DVD is used I get the following log entries:
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 0 at 50U$77%wM?@GV?:29400071
IFO file for VTS #0 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
DEBUG: Code 0 at &8F3QDY>4ar=Q&&_3:121262854
If I check 'Open DVD manually' I get an identical log entry yet the DVD itself will play on the same computer using VLC Media Player and in my separate Bluray player without problems. I have also changed the DVD opening modes from AUTO with no affect.
Can anyone shed any light on this? Is this just a bad disc?
Any help is much appreciated.
IanMck
makeMKV v1.17.4 (win(x64 release))
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number:
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 3.10
Disc Information
Label: THE_LOVE_PUNCH
Timestamp: 2014-07-23 01:10:22
Protection: CSS/CPPM
Data capacity: 6.50 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Ezatoka
Re: MakeMKV will not open a DVD disc
Post by Ezatoka »
Sometimes another DVD Opening Mode can help: viewtopic.php?f=7&t=28541
ianmck
Post by ianmck »
Hi Ezatoka
Thank you for your reply.
I had seen the post you referenced and had tried to scan the disc using all avallable modes - with exactly the same end result.
In the post there is a reference to MakeMKD hanging during the scan - this is not my experience. This is the log entry no matter which mode I try:
There is a very slight pause (less than a second) after the second line is posted - the bold entries come immediately after.
Since makeMKD can create files for other DVDs and Blurays I own, I must assume the problem is with the DVD itself - although it plays correctly in VLC Media Player and my Bluray player.
BritishBoy1967
Post by BritishBoy1967 »
this is a common error with discs that use the Disney X Project Protection method, basically the disc has 99 titles and causes issues. I used alternate software that supports the Disney X Project Protection and successfully backed up my movie. if you read my posts on this forum it gives a little more detail.
best regards
Simon
