Encoding
tarabohana
Encoding
#1 Post by tarabohana » Sun Jun 05, 2011 11:49 pm
I've ripped a standard DVD 720x480 and the end result was a 4:3 720x540 screen.
How can I change the video dimension to match the source video?
Do I need to activate the MakeMKV software in order to modify the encoder settings?
Please help !!
tarabohana
Re: Encoding
#2 Post by tarabohana » Mon Jun 06, 2011 1:34 am
I see what the overall problem is.
This software merely makes a replica of the original content by replacing the .VOB extension with the .MKV
I think that I'll stick with GNU apps.
Thank you for the opportunity of sampling your software,
regards, Tara
Navvie
Re: Encoding
#3 Post by Navvie » Tue Jun 07, 2011 5:52 pm
tarabohana wrote:I see what the overall problem is.
Yes, that is clearly the problem here.
:roll:
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
