Salo (BFI) - fake playlists
frothr
Post by frothr »
does anyone know the Salo (BFI version) playlist? there are over 160 possible files. or can anyone let me know how to figure out which playlist is the correct one?
frothr
Re: Salo (BFI) - fake playlists
Post by frothr »
so i have java installed and it doesn't make a suggestion for which is the correct playlist. i'll try downloading and installing vlc media player and see if that trick works
frothr
Post by frothr »
I tried installing and checking what VLC Media player says is the correct playlist but that isn't working either. There are issues with playing blu-ray discs? It ends up just crashing, and i'm seeing mixed reviews on forums about the success of getting the correct playlist this way. Any other suggestions on how to find the correct playlist for non-Lionsgate fake playlists?
Salo snip.PNG (63.29 KiB) Viewed 13705 times
SimultaneousNut
Post by SimultaneousNut »
Did you have any luck finding which one it was?
DigitalJosee
Post by DigitalJosee »
According to a friend of mine who has the disk, playlist 00403.mpls is movie with English opening/credits and 00500.mpls is Italian opening/credits.
SimultaneousNut
Wow thanks, I'll try this out.
sandersoni
Post by sandersoni »
Yes, it's these.
English audio
Title information
Source file name: 00403.mpls
Duration: 1:56:58
Chapters count: 14
Segment count: 9
Segment map: 4,9,13,14,10,8,6,2,15
File name: title_t75.mkv
Italian audio
Title information
Source file name: 00500.mpls
Duration: 1:56:58
Chapters count: 14
Segment count: 9
Segment map: 7,9,3,14,5,8,12,2,11
File name: title_t91.mkv
