John Wick 4
htpc_rookie
Re: John Wick 4
I have MKB20_v76_John_Wick-_Chapter_4_7534.tgz as unknown too.
As only submitted on Saturday by another poster I will refrain from reposting for now.
Re: John Wick 4
I had no issues with my Amazon copy.
Re: John Wick 4
Still can't rip mine. Dump sent yesterday. Trying to be patient...
Resurface9634
Re: John Wick 4
Same. Want to have a movie night this week with friends and am trying to decide if I should exchange it on amazon or if I should just wait it out....
rkhollister
Re: John Wick 4
Just received my US Amazon SE version (the 3 disc Amazon exclusive with the lenticular overlay on the slip) and it decrypts fine - ripping now
Re: John Wick 4
Figures. Mine is the normal 2 disc version from Amazon US. Regular BR ripped fine so I can always watch that if my patience gets the better of me.rkhollister wrote: Mon Jun 12, 2023 8:34 pm Just received my US Amazon SE version (the 3 disc Amazon exclusive with the lenticular overlay on the slip) and it decrypts fine - ripping now
Re: John Wick 4
My replacement disc arrived from Amazon (standard 2 disc version) and was able to back up this time without errors. Still can't rip yet. Sent dump for this disc just in case but assuming it's the same as the first.cardsdoc wrote: Sun Jun 11, 2023 1:25 pm My Amazon 4K disc won't rip yet and sent dump. Tried to just do a backup so I don't need the disc when database is updated but I keep getting errors on 2 different drives. Other discs are fine. Seems to be a bad disc and initiated a return/exchange. Anyone else get a bad disc?
Re: John Wick 4
My rip attempt on the 4k disc gets about 25-30 min into the process and then hits a roadblock and wont continue or complete. Yesterday error was different than todays attempt, yesterday error was "illegal request" at about 25 min into process, today error below:
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00278.m2ts' at offset '35121917952'
Error 'Internal error - Operation result is incorrect (78)' occurred while reading '\Device\CdRom0' at offset '35121917952'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom0' at offset '35121917952'
Re: John Wick 4
Either a problem with the drive or the disc. My money is on the disc. Check to see if it needs cleaning and failing that, get a replacement. I’ve had to do this with a handful of discs, most recently Aquaman.cabwiz wrote: Tue Jun 13, 2023 1:14 pm My rip attempt on the 4k disc gets about 25-30 min into the process and then hits a roadblock and wont continue or complete. Yesterday error was different than todays attempt, yesterday error was "illegal request" at about 25 min into process, today error below:
Re: John Wick 4
ok will do,t\ tried cleaning disc a handful of times so probably time to try another copy, bummer to double dip but worth a try. thanks
Re: John Wick 4
As my post above notes my first disc from Amazon gave errors and halted pre-maturely when backing up. Tried cleaning and a second drive. Replacement disc worked fine. Still can't decrypt yet but I'm sure database will update soon. I have had a couple bad discs over the years.
Mr_Movie_Dog
Re: John Wick 4
My Amazon 2 disc set for the 4K doesn't rip, haven't tried the HD yet but suspect the same volume key issue. I can rip them by other means so I positively know the disc's are not bad and that it is an AACS decryption issue.
MakeMKV v1.17.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=62194E19F4EC)
Downloading latest HK to C:\Users\xxxxx/.MakeMKV ...
Saved AACS dump file as C:\Users\xxxxx/.MakeMKV/MKB20_v77_John_Wick-_Chapter_4_51AE.tgz
Re: John Wick 4
Anyone getting AV sync errors?
AV sync issue in stream 0 at 1:01:00.782 : video frame timecode differs by +41.708ms
AV sync issue in stream 0 at 1:01:00.865 : secondary stream video frame timecode differs by -83.419ms
AV sync issue in stream 0 at 1:01:00.990 : secondary stream video frame timecode differs by -166.833ms
Re: John Wick 4
Still nothing on my copy from Best Buy. If I submit the dump file, am I supposed to get an email back for confirmation?
MSCloude115
Re: John Wick 4
Nope, just gotta play the waiting game. I submitted the Best Buy dump file a couple days ago as well.gedec wrote: Tue Jun 13, 2023 10:25 pm Still nothing on my copy from Best Buy. If I submit the dump file, am I supposed to get an email back for confirmation?
