LibreDrive for Pioneer drives
GDMFS0B
Post by GDMFS0B » Sat Jun 03, 2023 1:53 am
Coopervid wrote:
Tue May 09, 2023 8:03 pm
Not interesting. Normal. Makemkv tells you to close the application after entering the key and restart the program.
Ignore my quote. But answering “yes” to your PM. I don’t have permissions to respond yet.
GDMFS0B
Post by GDMFS0B » Sat Jun 03, 2023 3:52 pm
Coopervid wrote:
Mon May 08, 2023 9:35 pm
Enable internet access in Makemkv.
SUCCESS!! Thanks for the help!
Post by Coopervid » Sat Jun 03, 2023 7:24 pm
U are welcome!
tacorama
Post by tacorama » Thu Jun 08, 2023 12:20 am
cannot seem to rip UHD discs with this external drive on MakeMKV v1.17.4 linux(x64-release)
SDF v098: PIONEER_BD-RW___BDR-XS06_1.01_OLDL004417UC
Is there anything I can do to fix this?
Post by Billycar11 » Thu Jun 08, 2023 12:59 am
Don't think the xs06 does uhd
vanshady
Post by vanshady » Thu Jun 08, 2023 1:25 am
Billycar11 wrote:
Thu May 25, 2023 12:21 am
Krawk wrote:
Wed May 24, 2023 11:15 pm
So, at this stage is there even a point in trying to buy a Pioneer drive, knowing that the firmware cannot be downgraded and Libre is not supported on post 12/22 drives?
for now its only safe to buy a pioneer that has been flashed from sellers like me marty or asmcom
Is there any update on firmware downgrade? I need an internal drive but no seller is selling it yet, unless you are willing to do it?
Post by Billycar11 » Thu Jun 08, 2023 2:29 am
you dont need an internal you want it
uhd ripping on pioneer internal or external is the same
vanshady
Post by vanshady » Thu Jun 08, 2023 3:06 am
Yes sorry I want an internal, I bought a pc case that specifically had external 5.25 slost that I prepared to get an internal drive for, but then can't really buy a pioneer one now.
Bumbuliuz
Post by Bumbuliuz » Sat Jun 10, 2023 7:22 am
I'm a bit of a newbie here and and wanted to check something. I have a External Verbatim USB-C 3.2 Gen1 Blu-ray writer. This below is the info I see in the MakeMKV program about the drive I have.
OS device name: L:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: AF********
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
I can rip Dvd's and Blu-Ray's fine, I'm just curious if I can rip UHD discs. I know it can't play UHD discs, I was just curious about this and if it could be upgraded or flashed to rip UHD discs. It's fine if it's not possible, I bought it as a Blu-Ray burner anyway.
Post by Coopervid » Sat Jun 10, 2023 9:53 am
No. The UD03 will not read UHDs. You would need an UD04. Like the one in the Verbatim 43888 if you are located in EU.
Bumbuliuz
Post by Bumbuliuz » Sat Jun 10, 2023 3:52 pm
Ok thanks for the reply, I thought so, just wanted to be sure :)
Pjunkm
Post by Pjunkm » Fri Jun 16, 2023 5:38 pm
Pioneer BDR-XD08UMB-S no longer works for 4K. Firmware 1.2 is on this drive from the factory
zaqqaz6917
Post by zaqqaz6917 » Sat Jun 17, 2023 11:24 am
I wonder in Amazon USA, if one were to order using Prime from a third party seller, they might still have the old fw drives and the price is the same as well. If you use the Amazon as seller option then the drives come from Pioneer directly and will most like have the new fw
MKVtesterB
Post by MKVtesterB » Fri Jun 23, 2023 12:24 pm
Hi i have new owner of:
Description du pilote PIONEER BD-RW BDR-UD04 USB Device
Date du pilote 21/06/2006
Version du pilote 10.0.22621.1
Fournisseur du pilote Microsoft
Fichier INF cdrom.inf
INF Section cdrom_install
Identification du matériel USBSTOR\CdRomPIONEER_BD-RW___BDR-UD041.14
I'am testing creation of BD+ MKV.
And soon i will test UHD.
is it useful to install the latest Libredrive compatible firmware?
Post by Billycar11 » Fri Jun 23, 2023 1:13 pm
is it used to install the latest Libredrive compatible firmware?
There is no public way to flash pioneers currently
