Hello
I have two Pioneer bd04 drives. Individually boith work fine to rip bluray and UHd disks but cant use both together.
Any ideas how i set up so both can run together?
Ripping with Two drives
Re: Ripping with Two drives
Are you trying to run separate copies of MakeMKV, each talking to one drive, to use them "together"?
cybergools
I have one MKV account and two drivescybergools wrote: ↑Thu Jun 08, 2023 1:18 pmHello
If you want to rip more than one disk at a time, you can start MakeMKV in "single drive mode", which will ask you which drive to assign to the "running copy" as you start it. MakeMKV only extracts one copy at a time, but you can run more than one copy.
When you have more than one drive available, the Preferences>IO page will have a checkbox, "Ask for single drive mode". Check it, and you'll get the question each time MakeMKV starts.
I use two drives myself, at the same time, and yes it can be problematic at times. To date I haven't decided if there is an actual MakeMKV issue, a Linux issue, a LibreDrive or firmware issue, or a simple mechanical one from having two drives above/below each other spinning for an extended period of time.
Some notes:
Some notes:
- Start two instances of MakeMKV, select an exclusive drive each, before opening discs in either instance.
- Let one start to rip "in earnest" before starting the second one. I seem to have better success if I avoid "rocking the boat", though this is not consistent.
- If one fails, don't do anything with it until the other one finishes, it seems to increase the likelihood that that one will fail too.
- I only have issues if it's a BD, DVDs never fail. I can go to town with these.
