new update problems ?
Niddik
Post by Niddik »
is anyone else having problems ripping DVDs and blu-rays since the update to v.1.17.4 ?
Re: new update problems ?
People always have "problems". What SORT of "problems" do you think are endemic to this version?
I've ripped DVDs and blu-rays on 1.17.4. Seems to be working fine.
Niddik
Post by Niddik »
I can open the disc but wont save files or wont read the disc. I also get
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '0'
I have even bought a new player thinking my old one was going bad. the disc also plays just fine on the same player. I had no problems till the update. that's when this all started. Also on DVD's if I run it enough times. I can get it to save. Make no sense to me. Thanks in advance
Reinstalling MKV helps and a restart. Then sometimes it will work
Niddik
Post by Niddik »
I just got a different one now
Error 'Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '0'
Niddik
Post by Niddik »
BD+ code processed but no FUTs were obtained, errors may follow
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Error 'OS error - This device does not exist' occurred while reading '/AACS/Content000.cer' at offset '0'
crosis
Post by crosis »
I am also having all of these issues. I haven't been able to successfully rip a disc since updating to 1.17.4. I even tried the brand new discs I just ripped 2 days ago on 1.17.3 and I can't get through them without getting tons of SCSI and OS errors
I'm using macOS Monterey (12.6.5) on Intel and things are working fine. What OS are you using? Maybe there's something specific to the OS.
stemll
Post by stemll »
Niddik
I have seen that error on Mac on and off for years and across many, many versions. Are you using a USB powered drive by any chance?
I think, in my case at least, it is a drive/Mac issue rather than MakeMKV and it is the Mac no longer seeing the drive (I couldn't view the content in Finder either). To fix I had to remove the drive, exit MakeMKV, reattach the drive and then restart MakeMKV once the drive shows up in Finder.
I can go months without seeing it but similarly can spend a day ripping a new box-set and never see it.
jhayden2000
Post by jhayden2000 »
im having similar issues.
first, i cant download the 17.4 update. everytime i go to the link, i get a "page is not working" error
Second, Im getting the errors mentioned above as well as this:
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
This has never been something ive seen in the past.
Post by d00zah »
jhayden2000 wrote:
Sun Jun 18, 2023 5:12 pm
Until site issues are completely sorted, try this:
viewtopic.php?p=137213#p137213
Some discs have "Fake playlist" protection. Installing Java can help.
viewtopic.php?f=1&t=16791
viewtopic.php?f=8&t=14330
ac0mputerguru
Post by ac0mputerguru »
I'm on Windows 10 Pro, using two optical drives: (A:) DVD and (B:) Blu-ray. Yes, I miss my floppy drives A: and B:. Anyways, I have always had the "ask for single drive mode" option checked and run MakeMKV with Administrator privileges. I fire up on copy, approve the UAC, select A:, and it begins to read the disc. I do that same thing again, except I select B:, and (again) it begins to read the disc. Everything is fine, so far.
In previous versions, if one drive ran into a disc error of any type, only the offending copy of the app was affected. Meaning, if the Blu-Ray aborted the copy because of too many errors, the DVD copy process would continue, as if nothing had happened. Some times, the Blu-Ray error would cause the system to fail to recognize ANY disc inserted, until a system reboot.
Now, if either instance of the app has a disc error, BOTH drives disappear from the system. Well, they are still listed in Explorer, however, neither drive shows updates when discs are inserted or removed. Again, that is until I reboot.
