Debug log started at Sun Jun 5 08:57:22 2011 , written by MakeMKV v1.6.10 darwin(x86-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.6.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Garry/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVR-112D BC14" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE ASUS SBW-06C1S-U C101" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 2 at -N#YL4P(3f)A0CMS:121268719
001003:0020 DEBUG: Code 101019395 at ,[`\%E,AK"z#()E{Jg:29395678
001003:0020 DEBUG: Code 101019395 at ,[`\%E,AK"z#()E{Jg:121262049
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE ASUS SBW-06C1S-U C101' at offset '1048576'
003028:0000 Title #0 was added (5 cell(s), 0:22:08)
003028:0000 Title #1 was added (5 cell(s), 0:22:08)
003028:0000 Title #2 was added (5 cell(s), 0:22:05)
003028:0000 Title #3 was added (5 cell(s), 0:22:05)
003028:0000 Title #4 was added (5 cell(s), 0:22:04)
003028:0000 Title #5 was added (5 cell(s), 0:22:03)
003025:0000 Title #6 has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #7 was added (5 cell(s), 0:14:37)
003028:0000 Title #8 was added (2 cell(s), 0:04:21)
003028:0000 Title #9 was added (2 cell(s), 0:02:38)
003028:0000 Title #10 was added (2 cell(s), 0:05:24)
003028:0000 Title #11 was added (2 cell(s), 0:02:17)
003028:0000 Title #12 was added (2 cell(s), 0:03:12)
003028:0000 Title #13 was added (2 cell(s), 0:02:49)
003025:0000 Title #14 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #16 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003032:0000 Region setting of drive ASUS:SBW-06C1S-U does not match the region of currently inserted disc, trying to work around...
001003:0020 DEBUG: Code 0 at v][z3)}psfBTB:qS<:213130283
001003:0020 DEBUG: Code 0 at v][z3)}psfBTB:qS<:213133250
001003:0020 DEBUG: Code 1073741837 at )Cb.?d~[?2i`@"#*:29393953
001003:0020 DEBUG: Code 669 at Y'/Q/G2y`KkX'gJHx[0[I:121264257
001003:0020 DEBUG: Code 189 at Y'/Q/G2y`KkX'gJHx[0[I:121264257
001003:0020 DEBUG: Code 477 at Y'/Q/G2y`KkX'gJHx[0[I:121264257
001003:0020 DEBUG: Code 233 at QXkUl7uTSfjY2Ahl5CxP4Prq:0
001003:0020 DEBUG: Code 233 at WaAehkbJAFJ8Imd1L7M3LR9p:0
001003:0020 DEBUG: Code 233 at 1EWaGTdtZ1NMepFpLRzGheMo:0
001003:0020 DEBUG: Code 233 at EPBkc9O4WiDf7Xu/2iz8xcNI:0
001003:0020 DEBUG: Code 233 at kv8On5gElVnHhipakib05Ar7:0
001003:0020 DEBUG: Code 233 at F2kgi9Wd85GNf0Sf8C/mssL0:0
001003:0020 DEBUG: Code 233 at E17uJ+SlqMqrUzELq8J8ZPf7:0
001003:0020 DEBUG: Code 233 at 8I9d2JbrDxOvjrGGr5XIR2Zk:0
001003:0020 DEBUG: Code 233 at /sPtVYgB6N8dlnomnEX/4HbC:0
001003:0020 DEBUG: Code 233 at md4YWIUvFbif0D2i54PGNxzx:0
001003:0020 DEBUG: Code 233 at Y+0toM5YSdRIoPb3XY/0Wa21:0
001003:0020 DEBUG: Code 233 at ykp23pClYe8XOl0gCyaRzVrv:0
001003:0020 DEBUG: Code 233 at OKMYTQDgugQQKZfcTFyG8zhD:0
001003:0020 DEBUG: Code 233 at C2NbnS931ULzBoOEk//2kSQU:0
001003:0020 DEBUG: Code 233 at qXJE/WvLUGWk/o5iIaIUg8K5:0
005014:0000 Saving 13 titles into directory /Volumes/Definitely Maybe/New Decodes
001003:0020 DEBUG: Code 542 at -a-8ODSZTXzsq{hz.:29395839
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 0 to file /Volumes/Definitely Maybe/New Decodes/t00_Seinfeld_-_Vol_1_(Disc_1).mkv
001003:0020 DEBUG: Code 233 at fG9y4cu8616oQEbKrxW9xrfT:0
001003:0020 DEBUG: Code 233 at SJVDkqOaosclCnGJ1hqwwusP:0
001003:0020 DEBUG: Code 233 at YdKD1Mc5sgdBMsosFpLNBabr:0
001003:0020 DEBUG: Code 233 at yKybxzsiDs55g8zoFHHL3/OO:0
001003:0020 DEBUG: Code 233 at aYT1pHGY5w17psLgTW6Lehgc:0
001003:0020 DEBUG: Code 233 at +Al6PTGWQ3cY+eLUniuJ4cmf:0
001003:0020 DEBUG: Code 233 at ShOGkmCCOSGormpnW5ZwnCqR:0
001003:0020 DEBUG: Code 233 at Dolf4bRz/MmjatkdoBoairr6:0
001003:0020 DEBUG: Code 233 at Iy142Np3WLVNwSyfd8lGmPla:0
001003:0020 DEBUG: Code 233 at JEUqhIIQiW36QTXjATV3I6ZV:0
001003:0020 DEBUG: Code 233 at BsrYOz3LnQNkxFPxG0uKAjsB:0
001003:0020 DEBUG: Code 233 at ha3VObBU62CtdopKxT/d+zX5:0
001003:0020 DEBUG: Code 233 at W8PPrAlcso4SUf45Scrj8FKf:0
001003:0020 DEBUG: Code 233 at ZpVLB5jibWTZYQ8zIUFcqP53:0
001003:0020 DEBUG: Code 233 at PW6SvPyRPF4AV5l9oZKircH/:0
001003:0020 DEBUG: Code 233 at U2C9pqjbn7/9Lkx46KHkDvu7:0
005003:0000 Failed to save title 1 to file /Volumes/Definitely Maybe/New Decodes/title01.mkv
001003:0020 DEBUG: Code 233 at 6o9CldpI/F9Z5UffKkiobDDH:0
001003:0020 DEBUG: Code 233 at o23z15pyMlJP/kPPGQexeTkf:0
001003:0020 DEBUG: Code 233 at D2RVufFPiShEfrIZ5isKMP4r:0
001003:0020 DEBUG: Code 233 at 6MvLRoDhpmBOZpOdMgOVGGgq:0
001003:0020 DEBUG: Code 233 at N9kKrjMUHThTwhzSPCiOZgTN:0
001003:0020 DEBUG: Code 233 at zyU8JLgKmiG296PLxaEFjHcv:0
001003:0020 DEBUG: Code 233 at 6XcKePa0OiUgrgGPW8JRwh/D:0
001003:0020 DEBUG: Code 233 at dl1s1E1tuLEBJpMCzJaWCzsw:0
001003:0020 DEBUG: Code 233 at LPdY+1XKw5Y0im0Y3j+yqHk9:0
001003:0020 DEBUG: Code 233 at ToPzpPFqmElHl9GlBc3VDr/p:0
001003:0020 DEBUG: Code 233 at JZlj7Qak7/3iZ+O8bXsXiSM9:0
001003:0020 DEBUG: Code 233 at A7ZPW+CgOD9we8OAn0TE+OMW:0
001003:0020 DEBUG: Code 233 at seBtZeuHqKzTUSsVAyeIWFpn:0
001003:0020 DEBUG: Code 233 at KUNm/Q9BnI5DBv2IPQCiiyYC:0
001003:0020 DEBUG: Code 233 at WqtegQUeF0pr8+Suf4mpWl+1:0
001003:0020 DEBUG: Code 233 at msl0sMLaq+p2DCgKv6ujfVgT:0
001003:0020 DEBUG: Code 233 at ACAt8fcadjd8uFCr0+3Bgfc6:0
001003:0020 DEBUG: Code 233 at GMrlKP7zW8ZHggjoOo19POY5:0
001003:0020 DEBUG: Code 233 at 80AsjzLG5lXhKjvWv7kb1cGG:0
001003:0020 DEBUG: Code 233 at L3NUVQ+buQMG6K96Jxj9xSDo:0
005003:0000 Failed to save title 2 to file /Volumes/Definitely Maybe/New Decodes/title02.mkv
001003:0020 DEBUG: Code 233 at zYQAY9DKIx546eL94APMrB1O:0
001003:0020 DEBUG: Code 233 at YLjLWETFHhK+srfD4L500SR9:0
001003:0020 DEBUG: Code 233 at UKa4X4QxHoD2Xw4MBKu4n9SX:0
001003:0020 DEBUG: Code 233 at sUWf/XRlG1d+dZDq9Fx1+8Ug:0
001003:0020 DEBUG: Code 233 at x9QPG1GLiser28vaa/TcVpZf:0
001003:0020 DEBUG: Code 233 at W9x4eML7bGfPG72lRUteIpkn:0
001003:0020 DEBUG: Code 233 at 7GtnCCnhahAKvLHsGYBCtcWK:0
001003:0020 DEBUG: Code 233 at S7u4RCGCCaNMYS7u+1EEdGo5:0
001003:0020 DEBUG: Code 233 at A3O/mxCPqV2TLgUG2HpxIhP8:0
001003:0020 DEBUG: Code 233 at Uc3ygf92Aybny1CVSAksqa67:0
001003:0020 DEBUG: Code 233 at 6ghGXwsU9ILOJ7r+gxeV3OEc:0
001003:0020 DEBUG: Code 233 at jsaiz7Dxc1B+SabkASD5rz43:0
001003:0020 DEBUG: Code 233 at mPZrxK+qxc5dIiTJkdOtHzdc:0
001003:0020 DEBUG: Code 233 at K7OihQuErr9rCb5wTZM8UCA3:0
001003:0020 DEBUG: Code 233 at jaeSk+ATaOLnCjwvVXH3MW20:0
001003:0020 DEBUG: Code 233 at d4IUVioGXyXd3VTY2whiMF2E:0
001003:0020 DEBUG: Code 233 at EYTFDcNcPsOR1CKwIi3b99LY:0
001003:0020 DEBUG: Code 233 at HEw2/pzRxYGPXff9u/HXK4Cd:0
001003:0020 DEBUG: Code 233 at RTvHmLB0ts0CsqKmgYkZLvVP:0
001003:0020 DEBUG: Code 233 at LqOjAKDxlLnV9xUhas1QO45S:0
001003:0020 DEBUG: Code 233 at 2LJgY8ELgGvrkTZE//FAoBm5:0
001003:0020 DEBUG: Code 233 at UvEeeiCPlNqablTR4V/ei3J+:0
001003:0020 DEBUG: Code 233 at eVkVXSfV7viLRFREX9N5KV6M:0
001003:0020 DEBUG: Code 233 at Y8k46BJf5IXrkLVYR02sXHGW:0
001003:0020 DEBUG: Code 233 at 9F2OjmNtJ8UlRC6+YXu4UJcw:0
001003:0020 DEBUG: Code 233 at 5E+4HAPx03CqTzyv2TAMXee+:0
001003:0020 DEBUG: Code 233 at /FmimbRASYgW+D/+TEfLWEgZ:0
001003:0020 DEBUG: Code 233 at Of/WiH8nHaUbM189FdCBfEbY:0
001003:0020 DEBUG: Code 233 at Ebc45Gjb7JsLC12pDBy0t3ls:0
001003:0020 DEBUG: Code 233 at hUcf+j2TLYA8B1QDWkCgarjU:0
001003:0020 DEBUG: Code 233 at 2TudK7XzfZTNJPQYhgEbp2zI:0
001003:0020 DEBUG: Code 233 at UsnU9WfdpWkVqMOdNyzRCjUU:0
005003:0000 Failed to save title 4 to file /Volumes/Definitely Maybe/New Decodes/title04.mkv
001003:0020 DEBUG: Code 233 at DH0mJdWgvCTaKjQMns+Mq9nd:0
001003:0020 DEBUG: Code 233 at hwceSX8eILvBOmm7o5fDC/gZ:0
001003:0020 DEBUG: Code 233 at wbQcDeZJsdI2WQsUUlPgdCf9:0
001003:0020 DEBUG: Code 233 at 4wUF7iC0Y0jw5cmbLda5Q8Ox:0
005003:0000 Failed to save title 5 to file /Volumes/Definitely Maybe/New Decodes/title05.mkv
001003:0020 DEBUG: Code 233 at pM5DCJZQYkiJ1cibKEOnFTKe:0
001003:0020 DEBUG: Code 233 at xnAHR7ZrcLMEPkOOcfRKEHAb:0
001003:0020 DEBUG: Code 233 at 7NKLuWVwvV8y9KV4KGfwgYmi:0
001003:0020 DEBUG: Code 233 at eLACA7SdhMDxcfl60WoK6Mwt:0
001003:0020 DEBUG: Code 233 at BEO7KTlYfCAyCOcupWmJkD0b:0
001003:0020 DEBUG: Code 233 at j4clRjcc2Wv1KeeY4H7RHrib:0
001003:0020 DEBUG: Code 233 at PIu2U6WdjOuIL1oMrT/QiZkW:0
001003:0020 DEBUG: Code 233 at YXnJxoLDkqlgSCNKiumlguO6:0
001003:0020 DEBUG: Code 233 at jtYd4QSdrJlaJQmQVV3oW4pL:0
001003:0020 DEBUG: Code 233 at 3fR53ovP4QL6WoLRdZ9NwFY7:0
001003:0020 DEBUG: Code 233 at ippLvqsFHryYHxBYH+2ouiGf:0
001003:0020 DEBUG: Code 233 at GyxXpEcJJdxFJmSASC+0v1wl:0
001003:0020 DEBUG: Code 233 at pbWwRFEPiWLTtv8Ih98I1fS6:0
001003:0020 DEBUG: Code 233 at NGQSRMVIIF0kjI2z+DVGT/Es:0
001003:0020 DEBUG: Code 233 at 3JpOs2fNCb2FoU5qAmUbYbtX:0
001003:0020 DEBUG: Code 233 at 3kiOoPIXIltEg2DF/bND+ixf:0
001003:0020 DEBUG: Code 233 at q9zUuDHr9XASVILIf4jiPJo3:0
001003:0020 DEBUG: Code 233 at LJ9KTjvxaf2m6MSe7oagPhdu:0
001003:0020 DEBUG: Code 233 at tsqS4G0p1GKsFj2nUiY4ANvj:0
001003:0020 DEBUG: Code 233 at GbRMgJG4XwojaOzc0El2X4gM:0
001003:0020 DEBUG: Code 233 at whVTLRBZ5x83k7QyqFfij9JM:0
001003:0020 DEBUG: Code 233 at JhzccQzSvN4K2STUvcxLVirO:0
001003:0020 DEBUG: Code 233 at ei7Ly/MkOXfSmo0gkB+IyYkK:0
001003:0020 DEBUG: Code 233 at hlq22gNTOr94OkInwcF98YUJ:0
001003:0020 DEBUG: Code 233 at 8AeaqT3iTrFaYd127L9FRs3l:0
001003:0020 DEBUG: Code 233 at rmI3FmVm5P7v5tromeT838sE:0
001003:0020 DEBUG: Code 233 at zmCzrCl0A80Q3apc7E+sf+cU:0
001003:0020 DEBUG: Code 233 at RxkBs5eDVDyJOPZHc7oOadCa:0
001003:0020 DEBUG: Code 233 at VhQAUubMTXJeW+ROD9okYbDY:0
001003:0020 DEBUG: Code 233 at vTR5dhOnCIRstb4hiuCiUq6T:0
001003:0020 DEBUG: Code 233 at S9d4E2W0ICJi1L6T52UfPy5j:0
001003:0020 DEBUG: Code 233 at o3IbY0/mCvxGu4Hz62gHZeyU:0
001003:0020 DEBUG: Code 233 at s9dSNeEHceh/GceYKG1mpVLQ:0
001003:0020 DEBUG: Code 233 at hGnlU8av2qTO6zJGl9Z8gkLG:0
001003:0020 DEBUG: Code 233 at tinmDz+fl+qCTv4BEbH9Pom2:0
001003:0020 DEBUG: Code 233 at BGnz+HuJ2CVjWaKJc+tMAH/g:0
001003:0020 DEBUG: Code 233 at NLE70r6t9BVfX4Xp4w1jiYoc:0
001003:0020 DEBUG: Code 233 at D8B3FzjXhlRHHL4AiVXo7DcX:0
001003:0020 DEBUG: Code 233 at yedaCIYuNzx3vG6Bb557Lk/J:0
001003:0020 DEBUG: Code 233 at eotWECx0oFQkdYQJ+iyI5Fb/:0
001003:0020 DEBUG: Code 233 at gahtRZGLFq0F96cqHJJ+hhAj:0
001003:0020 DEBUG: Code 233 at f+QFllacS3sB1jGYMSoTPyl4:0
001003:0020 DEBUG: Code 233 at UaCaqU4p+lysxk4LswZt7B+J:0
001003:0020 DEBUG: Code 233 at t+7XZVcC4p8c0jU8/ubjDuDs:0
001003:0020 DEBUG: Code 233 at HvxLjGyE9XhjBsFsjUMxtnJ4:0
001003:0020 DEBUG: Code 233 at gHfIiRvRz1qH1z6OFDFXk5um:0
001003:0020 DEBUG: Code 233 at VO4sDekbVRIEfAuCo4bivL31:0
001003:0020 DEBUG: Code 233 at JAKfR3HMSY77OR/18TZj5lXO:0
001003:0020 DEBUG: Code 233 at GpztiJ3BcU4hnGYuwwHzrIdd:0
001003:0020 DEBUG: Code 233 at sbV9LG9/2k2Ov49j41LCu97K:0
001003:0020 DEBUG: Code 233 at /kwtW8nWob1QhqrAdLGOgzea:0
001003:0020 DEBUG: Code 233 at ecmFzYsuYX4cUz67P60gD/Ln:0
001003:0020 DEBUG: Code 233 at sKIJduwnl1Yh/x+8uUWHhVyF:0
001003:0020 DEBUG: Code 233 at SmvFd+c6BscdC92+xiCTwa1R:0
001003:0020 DEBUG: Code 233 at dMlzgbfTj9pgIBwb7KuAAMMa:0
001003:0020 DEBUG: Code 233 at 1oQPAlyAeoXh2kGFLsbM9IoE:0
001003:0020 DEBUG: Code 233 at dJu1k8t1gYWe4cCH4q0wp7/u:0
001003:0020 DEBUG: Code 233 at XFz4WIk0DK9ub/Jte28D/NVo:0
001003:0020 DEBUG: Code 233 at xrYIPTBhZ/tXVoUQlHs+NvbX:0
001003:0020 DEBUG: Code 233 at 320lRFr3BzH0Pm4QpKbD3oWa:0
001003:0020 DEBUG: Code 233 at MEHAK0vvrZvS7cvnu90ecnuu:0
001003:0020 DEBUG: Code 233 at SdqwRu1d1sYEtj+Per8tsqSH:0
001003:0020 DEBUG: Code 233 at BzzHSipWXFxNbGzS1FOioy1q:0
001003:0020 DEBUG: Code 233 at uRDXtoTd2NAVYK2YSgLBcz3N:0
001003:0020 DEBUG: Code 233 at ZTcSO5T/QoUIN42sXZsApvHI:0
001003:0020 DEBUG: Code 233 at dYeZsszNcZcRV0KbZapbKrlK:0
001003:0020 DEBUG: Code 233 at SelXgdThISlhzFYP8v+R7Z0I:0
001003:0020 DEBUG: Code 233 at F2ekHRDl9LpWJ3i59Xj3dgeC:0
001003:0020 DEBUG: Code 233 at rIL1kqAssRAhCkQ5gq9EDwyu:0
001003:0020 DEBUG: Code 233 at qh4eq8RM77n1vXjGzLRhz25S:0
001003:0020 DEBUG: Code 233 at EkLQLqaO7XzeuGIDwJ0XS7TM:0
001003:0020 DEBUG: Code 233 at erdAdfO/9y2Dz09wOQ0QF4kI:0
001003:0020 DEBUG: Code 233 at 5y/oHtIEmgkkautz/LbjnTUr:0
001003:0020 DEBUG: Code 233 at E42iLyk4HS7lxRtOFJLFbDq1:0
001003:0020 DEBUG: Code 233 at v5ATlNdWzUq8sW3qYUhq3mjG:0
001003:0020 DEBUG: Code 233 at 3Rvv688ac/YuICFHmHLwzRIB:0
001003:0020 DEBUG: Code 233 at 9b1XkA0OforlREl5WHZ9vPiz:0
001003:0020 DEBUG: Code 233 at KV8sqMOtuVM/VldA84eXPury:0
001003:0020 DEBUG: Code 233 at SxXcNH+n4BwID2P4Dlt0IjSy:0
001003:0020 DEBUG: Code 233 at Mr3d55zomFhUjUfGUP9yE65V:0
001003:0020 DEBUG: Code 233 at T0Avbq/KB9IpBeLWovbgjuCK:0
001003:0020 DEBUG: Code 233 at zJyIgAvIRc1F/98sGJsdeMdU:0
001003:0020 DEBUG: Code 233 at G8fQcoit/XFyjWEFmQss2pNq:0
001003:0020 DEBUG: Code 233 at mzr9/7qyZ+JnVQTVUfAyaiGI:0
001003:0020 DEBUG: Code 233 at aiovpMwCP9lcSGRNzgwORKYo:0
001003:0020 DEBUG: Code 233 at nt+80iu4na2zsUIcRuyiY7Vn:0
001003:0020 DEBUG: Code 233 at trykGE3Ht5mqkqdbpHJT7ft7:0
001003:0020 DEBUG: Code 233 at M/ZXwAVt0KNtR3WGac6ZRDab:0
001003:0020 DEBUG: Code 233 at wXSYZZiKTtaM8jkbLWHvO1n+:0
001003:0020 DEBUG: Code 233 at XtcMgAdd/KZcLjcDHxEsBlmK:0
001003:0020 DEBUG: Code 233 at OMXXh48w1PRF7wh0EYP8LLf1:0
001003:0020 DEBUG: Code 233 at Vk2pz12eQf+SWsaNB9eQvQvT:0
001003:0020 DEBUG: Code 233 at ATojLDBEnpYEDGNWWfSWZTF+:0
001003:0020 DEBUG: Code 233 at cQoKmwqhHRLA/iH2IaGa8Xur:0
001003:0020 DEBUG: Code 233 at xoXwTFOCXvrHHl8es3T8jJUH:0
001003:0020 DEBUG: Code 233 at JiIbdWiNCjz5YFgrUhBqIk6v:0
001003:0020 DEBUG: Code 233 at 5f1preS1scnd/ZIfBsW+6AFI:0
001003:0020 DEBUG: Code 233 at EfZchZGz48AlzP5wohchrYBF:0
001003:0020 DEBUG: Code 233 at FZooRz8+RbTL4Ya9LTvlkiqk:0
001003:0020 DEBUG: Code 233 at XeIS/jPhGisbcHh2ihHLSm4D:0
001003:0020 DEBUG: Code 233 at mwyTwzuai1RdlY3IMymvhaCW:0
001003:0020 DEBUG: Code 233 at wi9k+qWhyTvcQ2iX7Fkm42eO:0
001003:0020 DEBUG: Code 233 at QUMt3jk3aKUxY6kwNl+mP3h0:0
001003:0020 DEBUG: Code 233 at f++tQuZFFGZ/LMNRoreYqZmq:0
001003:0020 DEBUG: Code 233 at lZrKss1hlSCcTj/S9HCpCFj7:0
001003:0020 DEBUG: Code 233 at s6iFbHNRimz0Qf0TDXSBisD5:0
001003:0020 DEBUG: Code 233 at fVGifJEFqwKUmHB12prAi+xU:0
001003:0020 DEBUG: Code 233 at p+VzpNDwZKavbGTbrnQr0XcV:0
001003:0020 DEBUG: Code 233 at 1IxQ5ofU7FHMMhXshU/O6VNY:0
001003:0020 DEBUG: Code 233 at NIBalvQjfHsmSI2PkbTP9cCj:0
001003:0020 DEBUG: Code 233 at 25+adyNz6sNCtb/aeQTdfPjs:0
001003:0020 DEBUG: Code 233 at gVOK20rw0zYyPJ3X9OTM4suj:0
001003:0020 DEBUG: Code 233 at /DJ4wUqwHRyiskk6vdHrjLaC:0
001003:0020 DEBUG: Code 233 at wudzRY8a8GmF2LRm3dDK+039:0
001003:0020 DEBUG: Code 233 at UHyG09P6qB2pZ2sT3N8LnIOG:0
001003:0020 DEBUG: Code 233 at pox4BaccQ4dYuCXC6ykJ+gGQ:0
001003:0020 DEBUG: Code 233 at wXmxkKCwUVGfAFxbI/st2WHJ:0
001003:0020 DEBUG: Code 233 at SKf/987o8X1UqZf+QoSehIZP:0
001003:0020 DEBUG: Code 233 at G7aCqlSmGqq9EX+rhuGRT08Q:0
001003:0020 DEBUG: Code 233 at mxhkoUAPsTvdXGAQZ69in9sX:0
001003:0020 DEBUG: Code 233 at 7s2Tzo9ZaVDzFBKG2kQaYGGU:0
001003:0020 DEBUG: Code 233 at k7e/hzWOrBF76ffEr3gZwaY5:0
001003:0020 DEBUG: Code 233 at bbdBahbPKjEp/PPHvsXuTHt4:0
001003:0020 DEBUG: Code 233 at lkKXURg+QV6jgW8kEJg5qI58:0
001003:0020 DEBUG: Code 233 at 8WlgpfrTDUUsf41EH1tkUwu6:0
001003:0020 DEBUG: Code 233 at CQBfy0fPPIqJc7w4jo5VUU7P:0
001003:0020 DEBUG: Code 233 at P1xZipocLg/NcHnDJ4c7MKVA:0
001003:0020 DEBUG: Code 233 at uWaEcXIU27DSKR4L+VE8TMty:0
001003:0020 DEBUG: Code 233 at UrGwtiKrmHiEqA0XklD8FnAa:0
001003:0020 DEBUG: Code 233 at 2OqAfBco2yz4efJGiQAScM/C:0
001003:0020 DEBUG: Code 233 at 0q1cxrIXYl3mvEF8dnvvhWC6:0
001003:0020 DEBUG: Code 233 at Juii83Ip6Z6ssiC3iq/YHlTB:0
001003:0020 DEBUG: Code 233 at PaG5wTfk+vr7zCkcH8MeeQpF:0
001003:0020 DEBUG: Code 233 at dl9FOaj7ykBjS59gcGGWGd6k:0
001003:0020 DEBUG: Code 233 at XoSObhpeZdFWgoQnjT9C5kTa:0
001003:0020 DEBUG: Code 233 at tbud3LEXTyTdTCHnW1zktgSs:0
001003:0020 DEBUG: Code 233 at MdLmuIrovQXpGbLC024oprs6:0
001003:0020 DEBUG: Code 233 at Eh9n3JNKDy1pxuiehFQEroFV:0
001003:0020 DEBUG: Code 233 at sc5t5+XhmS4c+QLLuo9HclQv:0
001003:0020 DEBUG: Code 233 at prjsLgMA+Qpy8rxrj28RNqW4:0
001003:0020 DEBUG: Code 233 at flmAX6t9e8r7Zx7KcwIhEdUk:0
001003:0020 DEBUG: Code 233 at S5jZffHGQu6A2Uf7SCD4Tbpe:0
001003:0020 DEBUG: Code 233 at +wRdbiielPq3L/1MSKpQMdOa:0
001003:0020 DEBUG: Code 233 at GwjEN1UZ9mC69zYRfxK3F04R:0
001003:0020 DEBUG: Code 233 at GQT+lmxyVO3czEvN7oFnrnV2:0
001003:0020 DEBUG: Code 233 at PrddQifMCvb40mmiiOCjJxl7:0
001003:0020 DEBUG: Code 233 at 4TXrOB0cV86xxjtmzpzaKPwp:0
001003:0020 DEBUG: Code 233 at r/2wq2pDqoL2jQ1cWxphBMW+:0
001003:0020 DEBUG: Code 233 at xXjHU1wXVhtRnll2fRFQ0Zlv:0
001003:0020 DEBUG: Code 233 at Fsazuo1MJP1vfwK1RR0WpJuK:0
005004:0080 8 titles saved, 5 failed
005037:0204 Copy complete. 8 titles saved, 5 failed.
