There is no BW-16D1HT 3.11-MK only 3.10-MK.leo708 wrote: Tue May 30, 2023 8:02 amThanks for the reply, but after I flash 3.11 to 3.11 MK, is it possible to then flash it to 3.10 MK? From what I read, 3.10 MK is more consistent on speed.Billycar11 wrote: Mon May 29, 2023 9:09 pmYes it works with amd cpus 3.11 is flashable.leo708 wrote: Mon May 29, 2023 1:00 pm and one stupid question, if I want to use the Asus BW-16D1HT to RIP UHD Discs, even computers with AMD CPU would work right, rocking 7950X3D![]()
If you have trouble email me or Marty for an automated flasher
Re: SDFtool Flasher
Re: SDFtool Flasher
just follow the guide i never said to flash to 3.11 i said it was flashable the guide says 3.10 for asusleo708 wrote: Tue May 30, 2023 8:02 amThanks for the reply, but after I flash 3.11 to 3.11 MK, is it possible to then flash it to 3.10 MK? From what I read, 3.10 MK is more consistent on speed.Billycar11 wrote: Mon May 29, 2023 9:09 pmYes it works with amd cpus 3.11 is flashable.leo708 wrote: Mon May 29, 2023 1:00 pm and one stupid question, if I want to use the Asus BW-16D1HT to RIP UHD Discs, even computers with AMD CPU would work right, rocking 7950X3D![]()
Re: SDFtool Flasher
OK got you.MartyMcNuts wrote: Tue May 30, 2023 9:24 amThere is no BW-16D1HT 3.11-MK only 3.10-MK.leo708 wrote: Tue May 30, 2023 8:02 amThanks for the reply, but after I flash 3.11 to 3.11 MK, is it possible to then flash it to 3.10 MK? From what I read, 3.10 MK is more consistent on speed.Billycar11 wrote: Mon May 29, 2023 9:09 pm
Re: SDFtool Flasher
OK just realized another post was mentioning 3.11 MK for another model, my fault, first time dealing with all these model numbers are exhausting.Billycar11 wrote: Tue May 30, 2023 9:35 amjust follow the guide i never said to flash to 3.11 i said it was flashable the guide says 3.10 for asusleo708 wrote: Tue May 30, 2023 8:02 amThanks for the reply, but after I flash 3.11 to 3.11 MK, is it possible to then flash it to 3.10 MK? From what I read, 3.10 MK is more consistent on speed.Billycar11 wrote: Mon May 29, 2023 9:09 pm
office_icarus
Re: SDFtool Flasher
brilliant. Yeah no saw 2016-requisite [hence why didn't even bother attempting on Pioneer BDR-206D], but also saw this particular model was illustrated multiple times
sux
thanks for prompt response. obliged
- compounded by confirming How-to video's requisite: '...do not proceed unless Drive platform: MT1959...' (in MakeMKV's LibreDrive Information),
- compounded by Why would manufacture even produce multiple iterations of the exact same model #?).
- compounded by aforementioned 2020-correspondence (addressing same LG drive model)
sux
Billycar11 wrote: Tue May 30, 2023 3:23 amyou killed it obviously did not read the guide clearly says 2016 + yours is 2014 rip the only fix now is dos flashoffice_icarus wrote: Tue May 30, 2023 12:54 am
Is this bricked now?
Utilized SDFtool Flasher (via Windows 10 64-bit machine) for my LG WH16NS40 1.02; patching fw WH16NS60 1.02-MK -- after following MiKeeVid/MMN 2020 correspondence below, with same hardware.
After re-installing drive back into mid-2012 mac pro blue light on the front panel (of optical drive) continuously blinks, drive is totally unresponsive (via macOS 10.14 & makeMKV commands; likewise physically pressing front panel eject button).
Help?
fyi: attempted flashing natively on macOS machine (outlined in Mac/linux commands to flash on Ultimate Guide 2023) but couldn't get beyond final step #7 unfortunately
(aforementioned 2020 post...)
MartyMcNuts wrote: Sat Aug 29, 2020 1:04 am
OK, if you want to flash to WH16NS60 1.02-MK, why are you trying to flash firmware WH16NS40-NS50 1.03 MK????
Your drive is on WH16NS40 1.02 so you should be able to directly flash WH16NS60 1.02-MK firmware and be done!
Re: SDFtool Flasher
I dumped the original encrypted 1.04 firmware of my BU40N.
I then flashed the 1.03 firmware. Flashing worked fine.
How can I now restore the old 1.04 firmware? I have an archive with several .bin files. Which of these do I need to use?
Kind regards
Kind regards
Re: SDFtool Flasher
you dont restore from the backup it only cal data not FW if you want to go back to the original firmware use the official LG updater but i do not recommend that in any situation if your returning it they dont care or check.YFYqeR wrote: Wed May 31, 2023 8:27 pm Hi,
Kind regards
Re: SDFtool Flasher
Hi, I’m new to the forum and have just started to make a media server. I have read through the forums and seen that a pioneer flash tool isn’t publicly available. I have already bought the pioneer bdr-xd07ts and it has been working perfectly for my hd Blu-rays but I am enquiring if there is a way that maybe one of the sellers here would be able to flash my drive for me, like the $25 flash for lg & ASUS that is available, so I can start copying my 4k Blu-rays. I’m based in the uk, any help would be great thanks
BlackChakram
Re: SDFtool Flasher
Hey guys. Trying to flash my WH16NS40 and am encountering some problems. Hoping someone can tell me what's going on here.
Drive specs from makeMKV
I checked the sticker on the drive. Manufactured late 2019 and has the "SVC Code: NS50" on it.
I downloaded the SDFlasher (v 1.3.5) tool, and grabbed the "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" file from the "all you need firmware pack".
I leave "encrypted firmware" off, load the bin file, and hit write and get the following error:
"Command produced error code 0x82000000"
No idea if it's relevant, but my mobo is a Z590 Aorus Elite AX
Product: BD-RE WH16NS40
Revision: 1.04
Serial number: KLZJCGG1745
Firmware date: 2119-01-04 13:48
Highest AACS version: 76
Drive platform: MT1959I downloaded the SDFlasher (v 1.3.5) tool, and grabbed the "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" file from the "all you need firmware pack".
BlackChakram
Re: SDFtool Flasher
Solved it. SATA cable was going bad!
computerfreak
Re: SDFtool Flasher
How do i flash the firmware dump, which I have created with the flash utility back on to the drive, if for example I want to send the drive to RMA?
Re: SDFtool Flasher
You don't. That dump is just the important user info from the firmware. It is not the complete firmware. If you need to return the drive, you can flash a lower version of the firmware then use the original flasher to return to stock. For example, if you have a WH16NS40 that has been flashed to WH16NS60 1.02-MK firmware, you could flash the drive with WH16NS40 1.02 then use the original WH16NS40 1.05 flasher (viewtopic.php?f=16&t=24443) to return the drive to the stock firmware.computerfreak wrote: Thu Jun 29, 2023 10:59 pm How do i flash the firmware dump, which I have created with the flash utility back on to the drive, if for example I want to send the drive to RMA?
computerfreak
Re: SDFtool Flasher
Why exactly do I have to flash a lower firmware version and not the same version, than the current "wrong" firmware? Does the firmware got an internal version check, which would otherwise prevent me from flashing it or is it to prevent bricking?
Re: SDFtool Flasher
It has version check of sorts really it's the boot codecomputerfreak wrote: Fri Jun 30, 2023 12:40 pm Why exactly do I have to flash a lower firmware version and not the same version, than the current "wrong" firmware? Does the firmware got an internal version check, which would otherwise prevent me from flashing it or is it to prevent bricking?
Re: SDFtool Flasher
Worked perfectly and was very easy to use. I love you, man!
