TiKiMaN1
Re: Pioneer firmware update February 2023
Post by TiKiMaN1 » Fri Jun 09, 2023 1:18 am
Billycar11 wrote: Thu Jun 08, 2023 1:26 pm
domvar wrote: Thu Jun 08, 2023 1:24 pm I'm a bit lost in these replies is there a solution to the 1.04 firmware issue yet ether by flashing or other? No problem if not but the thread seems to have drifted away form that.
No solution yet
Billycar11 is your auto flash kit a solution to this issue? Really hoping to get back to ripping 4K again as quickly as possible.
Post by Billycar11 » Fri Jun 09, 2023 1:54 am
TiKiMaN1 wrote: Fri Jun 09, 2023 1:18 am
No solution yet
no not yet for now it can only cross flash pioneers fron non UHD to UHD and also needs fw before dec 2022
bort420
Post by bort420 » Fri Jun 09, 2023 6:37 pm
Does the hex editing firmware version not work?
yamikawa
Post by yamikawa » Fri Jun 09, 2023 8:00 pm
Billycar11 wrote: Fri Jun 09, 2023 1:54 am
No solution yet
Hi Billicar11,
I own a Pioneer BDR-S12XLT.
Drive information:
OS device name: Z:
Producer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Firmware date: 2020-07-21
Bus Encryption Marks: 1B
Highest AACS version: 72
LibreDrive information
State: Enabled
Drive platform: RS8F00
Firmware version: 1.01/ID45
I want to upgrade my drive from non-UHD to UHD
switch
Does this work with your program?
can you provide it to me
Greetings Yamikawa
Post by Billycar11 » Fri Jun 09, 2023 10:13 pm
yamikawa wrote: Fri Jun 09, 2023 8:00 pm
Hi Billicar11,
Drive information:
OS device name: Z:
Producer: PIONEER
Revision: 1.01
State: Enabled
switch
Greetings Yamikawa
Email me this I should be able to do it
MKVtesterB
Post by MKVtesterB » Fri Jun 23, 2023 12:31 pm
I am just receiveing following drive:
PIONEER BD-RW BDR-UD04 USB Device
Date du pilote 21/06/2006
Version du pilote 10.0.22621.1
Fournisseur du pilote Microsoft
Fichier INF cdrom.inf
INF Section cdrom_install
Identification du matériel USBSTOR\CdRomPIONEER_BD-RW___BDR-UD041.14
I want use is to make backup of my UHD BD disque and use it on my TV via PLEX
is it useful to install the latest Freedrive compatible firmware?
Post by MartyMcNuts » Fri Jun 23, 2023 9:49 pm
MKVtesterB wrote: Fri Jun 23, 2023 12:31 pm Hi,
Test it for UHD first. If it works then do not change firmware.
pitcher27
Post by pitcher27 » Fri Jun 23, 2023 11:51 pm
Am I correct that the below drive (even though it has firmware 1.02) should be OK once the small firmware dump is uploaded and MakeMKV updated? I'm assuming that's the case based on LibreDrive "Possible, not yet enabled."
My return window is closing in a week or so, so if this drive is definitely NOT usable for UHD (in the long term), then I'll return it. If it IS indeed usable, even it might take a while for the MakeMKV update, then I'd just as well keep it.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CCDL300593UC
Firmware date: 2022-12-27
Highest AACS version: 76
Drive platform: Pioneer RS9331
Firmware version: ID05
Post by MartyMcNuts » Sat Jun 24, 2023 1:07 am
pitcher27 wrote: Fri Jun 23, 2023 11:51 pm Am I correct that the below drive (even though it has firmware 1.02) should be OK once the small firmware dump is uploaded and MakeMKV updated? I'm assuming that's the case based on LibreDrive "Possible, not yet enabled."
Revision: 1.02
Nope. The firmware is too new. It shows as 27 Dec 2022. Any firmware dated Dec 2022 or newer is no good. It could be months before we have a resolution.
Post by Billycar11 » Sat Jun 24, 2023 1:58 am
Revision: 1.02
return it and get a pioneer from me asmcom or marty depending on location we have ones that are flashed
MKVtesterB
Post by MKVtesterB » Sat Jun 24, 2023 12:21 pm
MartyMcNuts wrote: Fri Jun 23, 2023 9:49 pm
i'ts working with UHD too ;)
jcfrosty
Post by jcfrosty » Thu Jun 29, 2023 1:15 am
Recently bought a pioneer drive due to libredrive support (or so I thought), reliablility, and UHD. Sadly it came with 1.04 firmware which appears I'm in trouble as MakeMKV folks haven't figured out a solution yet. Should I return the drive or are we making headway to unlock the 1.04 firmware drives.
Post by Billycar11 » Thu Jun 29, 2023 7:05 am
jcfrosty wrote: Thu Jun 29, 2023 1:15 am Recently bought a pioneer drive due to libredrive support (or so I thought), reliablility, and UHD. Sadly it came with 1.04 firmware which appears I'm in trouble as MakeMKV folks haven't figured out a solution yet. Should I return the drive or are we making headway to unlock the 1.04 firmware drives.
if you cant wait return it and buy one of my pioneers if your in the usa.
but if you can wait i hear you may not even need to flash it with a future libredrive update
but i have mine here ready and waiting now ready to go out tomorrow
BigfootAUS
Post by BigfootAUS » Fri Jun 30, 2023 12:28 pm
Bought a fresh Pioneer BDRS12UHT from Amazon Australia this week, the drive arrived with 1.04. Info tab:
OS device name: H:
Product: BD-RW BDR-S12U
Revision: 1.04
Serial number: [serial number was here]
Firmware date: 2022-12-20
Highest AACS version: 78
Drive platform: Pioneer RS8F01
Firmware version: ID43
At least it's still working with regular blurays; I had a Verbatim 43888 mechanically fail after ripping just one 4K disc and 2 DVDs, couldn't even detect regular blurays once it started breaking. This Pioneer drive seems much more reliable and has gone through more content without issue already, so I'm keen to see a fix to use this drive. Just seems better overall.
Is there anything we can do to help? Logs of anything?
jcfrosty
Post by jcfrosty » Sun Jul 02, 2023 1:51 am
Billycar11 wrote: Thu Jun 29, 2023 7:05 am
I have no problem keeping it if we can get it working eventually. In the meantime, it benefits me to have 2 drives for separate machines. One stays connected to the server, so I just ordered a pioneer from you as well to keep me running since my LG desktop drive died after a year and 4 months.
Pioneer seems more reliable as my first pioneer BD (non UHD) drive lasted well over 5 years. Really dissatisfied with LG.
