tjreis2
#8386 Post by tjreis2 » Thu Jun 08, 2023 8:56 am
This is the mediainfo from the input file:
General
Unique ID : 309952400007334840793798100813789433907 (0xE92EA92D85FC4B0EBC73B97094A29033)
Complete name : F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv
Format : Matroska
Format version : Version 4
File size : 43.1 GiB
Duration : 1 h 56 min
Overall bit rate mode : Variable
Overall bit rate : 52.8 Mb/s
Frame rate : 23.976 FPS
Movie name : Spider-Man: Into the Spider-Verse (2018)
Encoded date : 2022-04-18 20:37:17 UTC
Writing application : mkvmerge v66.0.0 ('Josie') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Attachments : poster.jpg
IMDB : tt4633694
TMDB : movie/324857
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 47.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.239
Stream size : 38.8 GiB (90%)
Title : Spider-Man Into the Spider-Verse (2018) - Release by Dolby Vision Torrents
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 9877 cd/m2
Maximum Frame-Average Light Level : 934 cd/m2
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 374 MiB (1%)
Title : Dub, UHD Blu-Ray
Language : Russian
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Stream size : 535 MiB (1%)
Title : Dub, Blu-Ray
Language : Ukrainian
Default : No
Forced : No
Audio #3
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 267 kb/s
Maximum bit rate : 4 935 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 8 ms
Stream size : 2.67 GiB (6%)
Title : Original
Language : English
Default : No
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #4
Format : AC-3
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate : 640 kb/s
Title : Original
Language : English
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Delay relative to video : 32 ms
Stream size : 160 MiB (0%)
Title : Commentary by Writer/Producer Phil Lord, Actor Christopher Miller, Directors Bob Persichetti, Peter Ramsey and Rodney Rothman
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 55 min
Bit rate : 2 b/s
Frame rate : 0.009 FPS
Count of elements : 64
Stream size : 2.17 KiB (0%)
Title : Forced
Language : Russian
Default : Yes
Forced : No
Text #2
Format : UTF-8
Bit rate : 82 b/s
Frame rate : 0.210 FPS
Count of elements : 1461
Stream size : 70.1 KiB (0%)
Title : Full
Language : Russian
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 2 b/s
Stream size : 2.12 KiB (0%)
Title : Forced
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 81 b/s
Count of elements : 1462
Stream size : 68.8 KiB (0%)
Title : Full
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 71 b/s
Frame rate : 0.266 FPS
Count of elements : 1840
Stream size : 60.5 KiB (0%)
Title : Full
Language : English
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 81 b/s
Frame rate : 0.323 FPS
Count of elements : 2258
Stream size : 69.2 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 132 b/s
Frame rate : 0.328 FPS
Count of elements : 2301
Stream size : 113 KiB (0%)
Title : SDH-Colored
Language : English
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 113 b/s
Frame rate : 0.299 FPS
Count of elements : 2098
Stream size : 97.1 KiB (0%)
Title : Commentary
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:09:03.793 : en:Chapter 2
00:14:04.719 : en:Chapter 3
00:18:51.714 : en:Chapter 4
00:29:39.027 : en:Chapter 5
00:34:14.636 : en:Chapter 6
00:40:34.432 : en:Chapter 7
00:44:22.827 : en:Chapter 8
00:48:06.884 : en:Chapter 9
00:58:45.856 : en:Chapter 10
01:06:04.460 : en:Chapter 11
01:09:55.483 : en:Chapter 12
01:20:00.004 : en:Chapter 13
01:24:54.923 : en:Chapter 14
01:33:33.399 : en:Chapter 15
01:55:26.920 : en:Chapter 16
#8387 Post by RESET_9999 » Thu Jun 08, 2023 11:07 am
tjreis2 wrote:
Thu Jun 08, 2023 8:53 am
This is the script job:
it looks like your path to the tool ''jq.exe'' is not right or missing.
here's the folder for all the tools:
https://drive.google.com/file/d/1qavvq_ ... sp=sharing
tjreis2
#8388 Post by tjreis2 » Thu Jun 08, 2023 11:34 am
It works now with your tool pack, clearly it was a missing tool somewhere, thank you so much!
deadchip12
#8389 Post by deadchip12 » Thu Jun 08, 2023 3:07 pm
RESET_9999 wrote:
Wed Jun 07, 2023 2:39 pm
deadchip12 wrote:
Wed Jun 07, 2023 2:37 pm
st use tsmuxer to remux the mkv file into bluray folder and play via usb?
because the x800m2 5ghz wifi is fast enough to play high bitrate bluray.
bluray folder playback is not supported via the network
Hmm ok
But is it advisable to remux the mkv file into bluray folder and play via usb? Or we should always remux the original bluray folders?
#8390 Post by RESET_9999 » Thu Jun 08, 2023 4:26 pm
Hmm ok
it's always safer to remux from the original/untouched BD folders but I do sometimes use MKV P7 source when I can't find the bluray (no seed) and it plays fine on my x800m2.
Trees
#8391 Post by Trees » Thu Jun 08, 2023 8:25 pm
Quick question, when using dovi_tool mode 3 to extract the RPU from a P5 file, is any from the RPU data lost? I'm asking because the other day, I read someone claiming both chroma and luma data being lost when using mode 3; apparently, only dynamic metadata is being carried over from the P5 files to the P8.1 files.
Is this true? Just curious.
deadchip12
#8392 Post by deadchip12 » Fri Jun 09, 2023 6:12 am
Hmm ok
sometimes remux may not have AC3 core in the truehd track so atmos won't work if we remux it into bluray folder and play via usb right?
quietvoid
#8393 Post by quietvoid » Fri Jun 09, 2023 11:37 am
Yes, the mapping metadata contained in profile 5 is not usable in profile 8.1.
It wouldn't make sense to keep it.
#8394 Post by RESET_9999 » Fri Jun 09, 2023 12:05 pm
THD in MKV remux will never have an ac3 core. My script will add a core when you process it.
deadchip12
#8395 Post by deadchip12 » Fri Jun 09, 2023 4:30 pm
ok so if I don't use your script then atmos won't work right?
codeXRes
#8396 Post by codeXRes » Mon Jun 12, 2023 2:36 pm
Did anyone test the new CoreELEC DV build for Minix U22X-J (Max) and Ugoos AM6b?
https://discourse.coreelec.org/t/amlogi ... sion/24738
Looks like they're struggling with FL playback though.
You’re not right, this Kodi APK just use the underlay system with OMX awesome decoder including Mediacodec. Both are closed source blobs. FEL works flawlessly under Android with these components.
The Nova player does even work better than this Kodi version.
It’s something about the FL layer decoder. It sometimes works, sometimes not and this cause the frames stuck.
No, all is there. Someone can debug it and tell us how to handle the FL layer decoder that he is able to proper decode all frames. We don’t know (yet).
https://discourse.coreelec.org/t/coreel ... n/21473/31
rudemario
#8397 Post by rudemario » Mon Jun 12, 2023 2:48 pm
Injecting DV from Spiderman: Into the Spider-Verse WEB-DL into the UHD Blu Ray (which only includes HDR10)
Hey there!
So, I've been stopping through the thread and been reading various posts and screenshotting relevant ones, and I think I'm ready to begin this.
I believe I understand that converting DV Profile 5 into Profile 8.1 is not necessary to get an MP4 to have active DV detected for LG TVs (I have a C1), and it's moreso to avoid having no video/green video displaying when played on a display/player that does not support DV.
I also believe I understand that DV Profile 5 can be inferior to a Profile 7 DV if a Profile 7 DV of the same movie includes a FEL? Which would mean even if a Profile 7 FEL wasn't present, among a few other things, mapping a Profile 5 to a UHD Blu Ray video source might produce inaccuracies/grading problems (I've seen mention of using PQ to check for inaccuracies, not sure how to go about that or if it's even necessary)
Into the Spider-Verse was never released on Disc with Dolby Vision, that was reserved exclusively for streaming platforms. Streaming platforms offer UHD streams, so in theory, WEB-DLs would be UHD streams with UHD mapped Profile 5 Dolby Vision.
So, two questions, and then a closer.
  • 1. If I had a copy of a raw, muxed, unmodified WEB-DL, and a raw, muxed UHD Blu Ray, would it be as simple as using a few tools to inject the Profile 5 into the UHD Blu Ray and simply sync the beginnings of the video file with the Blu Ray? I understand Blu Rays usually have a blank video stream with the data mapped, and Profile 5 for streaming services has a text file instead. I assume the programs take care of this discrepancy, no issues? And, I'm assuming because the Profile 5 is for streaming services and I noticed some people said that there are some oddities or inaccuracies when applied to Blu Ray, let me know if I'm mistaken, I assume the colors will be off.
    But does that mean there is also a way I can make a modification or two to improve the oddities? Maybe I can view a stream off of a streaming service and take photos of the differences, maybe? Pardon my absolute naivete and inexperience, my problem is likely one you guys have heard a bunch before, but I really love the two Spider-Verse movies and want to see them in UHD Blu Ray sources + Dolby vision on my LG C1.
    2. I am having difficulty finding WEB-DLs that actually include the DV. This is strange to me and I don't really understand it. I have only found a Hybrid made for the Italian audio, which appears to have converted the DV to 8.1. Would this source be usable? Can I verify nothing has been modified somehow, and just isolate/separate that out and apply that DV to the English UHD Blu Ray?
Final: All of that is assuming I can play the files IN Dolby Vision. I have a Windows PC with a RTX 3080 hooked up to my TV with an optical HDMI 2.1, but as I understand it Windows only supports HDR10. I have an LG C1, and a fast internal SSD>USB 3.1 enclosure to play high bitrate content off of from the USB port (assuming 2.0), and so that leaves my options to my LG C1s internal player, as far as I'm aware (other than buying something like an Nvidia Shield). This is okay, I don't mind using the internal player as I'm not a heavy movie digester, more of a visual quality enjoyer, lol (so the effort is worth it to me if only for a few movies).
So, assuming that a Profile 5 DV added to a UHD Blu Ray source is fine and dandy, based on what I'm seeing in the thread and elsewhere, I SHOULD be able to view Dolby Vision content on my C1s internal player simply by using ffmpeg to move a .mkv muxed UHD Blu Ray into a .mp4 container, provided it has DV Profile 5, 7, or 8.1 right? That would be all that's needed? If that's the case, would, in theory, that odd converted DV profile 8.1 DV source, when muxed into an MKV, work fine when wrapped in a .mp4 container? or do .mp4 containers require a certain DV version? I believe that the consensus is that when rewrapping as .mp4s, you have to sacrifice the UHD's Lossless Dolby audio (for reasons I don't understand. if there's a workaround or if somebody could explain to me why we can't have the best of both worlds I would really really appreciate it,) which might mean other considerations/sacrifices have to be made.
Sorry if anything I've written/asked is annoying or been repeated ad nauseum, I don't mind being told to go back to a specific page or post and re-read, I can try to follow a previously outlined process and ask any questions about what I'm stuck on. It would just really help if someone noticed if I was on the wrong track or made some false conclusions from what I've read so far, because I'm not sure if I'm grasping everything.
Thanks so much for the help!
tjayz
#8398 Post by tjayz » Tue Jun 13, 2023 3:00 am
tjreis2 wrote:
Thu Jun 08, 2023 8:50 am
One thing i noticed different from you gif now is that media opens 3 times in my PC, and each time i have to close it so that the script continues. in your gif it didnt open once, could this be it?
For other people who have this problem, do not use mediainfo gui, use mediainfo cli in tools folder
UBP-X800M2 / LG OLED CX / NAD M17 V2i
tjayz
#8399 Post by tjayz » Tue Jun 13, 2023 3:37 am
Injecting DV from Spiderman: Into the Spider-Verse WEB-DL into the UHD Blu Ray (which only includes HDR10)...
https://docs.google.com/spreadsheets/d ... =427220017
If you are not willing to buy another player and rely solely on your C1 then follow the path in the link above for LG CX or newer. You need the latest dovi ts script from here: https://drive.google.com/drive/u/1/fold ... J2M9DvOQRu
C1 will not play profile 7 so you are limited to 8 or 5 and pretty sure you would then lose FEL for MEL and DDP w/ Atmos would be your best audio it can play. Anything that is P5 TV shows, usually just DL as is from internet. Movies I go after BDMV and convert to my desires, which in your case would be workflow 4-1-1 from the dovi script linked above. Just need to read the top part of the script and set everything to YES or NO to your desired output. When you hit the part that says don't change anything below this point you are done.
I would recommend getting plex or jellyfin installed on both your pc and C1 to avoid having to use the usb. You can cast from windows but is definitely not elegant, is only means I found that can cast P7 dual stream though so is not obsolete for some people.
jkatchy2
#8400 Post by jkatchy2 » Tue Jun 13, 2023 3:31 pm
I have remuxed from my original BD disc , but when I try to fast forward on my x800m2 its shows Operation is prohibited , anything I am doing wrong ? I use your tool to create m2ts version.
