tjreis2
Post by tjreis2 »
Thank You again!
Just to see if i understood everything correctly:
If I have a P7 FEL TrueHD REMUX.mkv and want to convert to .ts to play on the x800m2: Workflow 4-3 without changing the mux line in the bat.
If I have a P7 MEL TrueHD REMUX.mkv and want to convert to .ts to play on the x800m2: Workflow 4-3 or 4-2-1 without changing the mux line in the bat.
If I have a P8 hybrid TrueHD .mkv and want to convert to .ts to play on the x800m2: Workflow 5 without changing the mux line in the bat.
Is this correct?
An outside question: I also have a couple of REMUX TrueHD mkv files that are in HDR and not DV, that suffer from the same audio track problem. Can I use your workflow 3-2 to add the silent core and convert to ts to play on the x800m2?
tjreis2 wrote: Wed Jun 07, 2023 12:39 pm Thank You again!
Is this correct?
yes
yes all the workflow that mux to TS will automatically add a silent core to TrueHD.
(3) will add DV from madvr which is not great though.
you can use (5) to just mux the mkv and the script will add the ac3 core.
valington
Post by valington »
RESET_9999 wrote: Tue Jun 06, 2023 5:32 pm
Mrmorrison wrote: Tue Jun 06, 2023 5:15 pm @RESET_9999
Hello Chief!
I don't know exactly when this problem started, if it depends on the bat version or the recent tools update you made available for a few days.
But with path 4-3 it often happens that the output TS file is incomplete.
Sometimes it's incomplete for 30 minutes, sometimes more, sometimes less.
My x800m2 freezes in these files (that's how I noticed it) at the last second. With other devices, however, the video simply stops as if it had come to an end. Do you know anything about it?
It's never happened to me before, yet I've been using your tool for a long time. I know it would be much better if there is the iso file as input but I am often forced to use mkv ST DL.
I tried to use tsmuxer separately with the BL and EL files that the tool generates, adding the original mkv file, but it ends with an error (which unfortunately I didn't write) maybe it depends on the final mux. What can I do? deThe last three films, two have had this problem
Most likely some SRT subtitles with invalid timing.
I had this issue with a lot of MAX web-dl and the solution is to uncheck the problematic subs.
When the ts muxing fails, the script is made to not delete the final processed HEVC file so you don't have to start over.
Thank you for TL info RESET ,TL is awesome !
deadchip12
Post by deadchip12 »
Is this correct?
Why not just use tsmuxer to remux the mkv file into bluray folder and play via usb?
deadchip12 wrote: Wed Jun 07, 2023 2:37 pm st use tsmuxer to remux the mkv file into bluray folder and play via usb?
because the x800m2 5ghz wifi is fast enough to play high bitrate bluray.
bluray folder playback is not supported via the network
BTW i've compared the TV-LED rgb signal for the x700/x800m2 and its exactly the same.
And as you can see in the comparison , the shield has completely different tunneling colors. Black is supposed to be dark red in TV-LED tunneling but it's purple on the Shield. Even profile 5 seems to be wrong.
https://slow.pics/c/iJGQlcAS
All the other devices (dune, firetv max, firetv old, zidoo, appletv, oppo, x700, x800m2, Philips, chromecast) have a dark RED for black in TV-LED.
rodrigo081089
Post by rodrigo081089 »
Im using dovi tools to convert a profile 7 remux to a profile 8. When I use the command to get the hevc the result file has lower bitrate
deadchip12
Nevermind
deadchip12
tjreis2 wrote: Wed Jun 07, 2023 10:42 am I have a x800m2 as well and I have quite a few DV movies that are in a .mkv format with TrueHD audio. However, when I convert them to .ts using tsmuxer, the TrueHD track doesnt play in the sony because there is no core in the original mkv file (which is normal behavior for this format).
In which movies do you see this?
DMDreview
Post by DMDreview »
RESET_9999 wrote: Wed Jun 07, 2023 2:54 pm BTW i've compared the TV-LED rgb signal for the x700/x800m2 and its exactly the same.
it's not purple, it's red and blue stripes yuv 422. As I understand it, this is due to the black level increase in shield tv, so at the bottom of the range on channel B, and even a little on channel R you can see vertical stripes.
So I think it has something to do with that.
tjreis2
Post by tjreis2 »
Hello again!
Im facing a problem using the workflow 5 to convert a P8 hybrid TrueHD mkv to a ts file. i installed the necessary tools but it gives this error:
FINDSTR: Cannot open C:\Users\XXXX\AppData\Local\Tempaudio.format.txt
The output ts file works but has no audio.
Did i do something wrong?
tjreis2 wrote: Wed Jun 07, 2023 11:42 pm Hello again!
the FINDSTR: error will be fixed in the next version (tomorrow) but it shouldn't be an issue for the muxing with THD...
It's working with the sample files I tested on my end.
Can you copy/upload the complete log of the script job and the mediainfo of your input file?
vanshady
Post by vanshady »
Does atv infuse still require DDP for profile 8, or is it not necessary after the “official” p8 support update?
tjreis2
Post by tjreis2 »
This is the complete mediainfo from the output file:
One thing i noticed different from you gif now is that media opens 3 times in my PC, and each time i have to close it so that the script continues. in your gif it didnt open once, could this be it?
General
Complete name : F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.ts
Format : MPEG-TS
File size : 39.7 GiB
Duration : 1 h 56 min
Overall bit rate mode : Variable
Overall bit rate : 48.7 Mb/s
Maximum Overall bit rate : 109 Mb/s
Frame rate : 23.976 FPS
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 46.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.233
Stream size : 37.7 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 9877 cd/m2
Maximum Frame-Average Light Level : 934 cd/m2
tjreis2
Post by tjreis2 »
This is the script job:
Drag and drop FILE #1 and press enter...F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv
Drag and drop FILE #2 and/or press enter...
FINDSTR: Cannot open C:\Users\Tiago\AppData\Local\Tempaudio.format.txt
A subdirectory or file F:\Movies\TEMP_folder already exists.
processing..."Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv"
reading input tracks format/id/language...
done.
tsMuxeR version git-de67de8. github.com/justdan96/tsMuxer
HEVC muxing fps is not set. Get fps from stream. Value: 23.976
0.0% complete
Processed 168071 video frames
100.0% complete
Flushing write buffer
Mux successful complete
Muxing time: 1 min 7 sec
The script has completed , no more file to process...
