DMDreview
#8386 Post by DMDreview » Wed Jun 07, 2023 6:13 pm
RESET_9999 wrote:
Wed Jun 07, 2023 2:54 pm
BTW i've compared the TV-LED rgb signal for the x700/x800m2 and its exactly the same.
And as you can see in the comparison , the shield has completely different tunneling colors. Black is supposed to be dark red in TV-LED tunneling but it's purple on the Shield. Even profile 5 seems to be wrong.
https://slow.pics/c/iJGQlcAS
All the other devices (dune, firetv max, firetv old, zidoo, appletv, oppo, x700, x800m2, Philips, chromecast) have a dark RED for black in TV-LED.
it's not purple, it's red and blue stripes yuv 422. As I understand it, this is due to the black level increase in shield tv, so at the bottom of the range on channel B, and even a little on channel R you can see vertical stripes.
So I think it has something to do with that.
tjreis2
#8387 Post by tjreis2 » Wed Jun 07, 2023 11:42 pm
Hello again!
Im facing a problem using the workflow 5 to convert a P8 hybrid TrueHD mkv to a ts file. i installed the necessary tools but it gives this error:
FINDSTR: Cannot open C:\Users\XXXX\AppData\Local\Tempaudio.format.txt
The output ts file works but has no audio.
Did i do something wrong?
#8388 Post by RESET_9999 » Thu Jun 08, 2023 12:06 am
Hello again!
the FINDSTR: error will be fixed in the next version (tomorrow) but it shouldn't be an issue for the muxing with THD...
It's working with the sample files I tested on my end.
Can you copy/upload the complete log of the script job and the mediainfo of your input file?
vanshady
#8389 Post by vanshady » Thu Jun 08, 2023 1:27 am
Does atv infuse still require DDP for profile 8, or is it not necessary after the “official” p8 support update?
tjreis2
#8390 Post by tjreis2 » Thu Jun 08, 2023 8:50 am
This is the complete mediainfo from the output file:
One thing i noticed different from you gif now is that media opens 3 times in my PC, and each time i have to close it so that the script continues. in your gif it didnt open once, could this be it?
General
Complete name : F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.ts
Format : MPEG-TS
File size : 39.7 GiB
Duration : 1 h 56 min
Overall bit rate mode : Variable
Overall bit rate : 48.7 Mb/s
Maximum Overall bit rate : 109 Mb/s
Frame rate : 23.976 FPS
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : 36
Bit rate : 46.3 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.233
Stream size : 37.7 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 9877 cd/m2
Maximum Frame-Average Light Level : 934 cd/m2
tjreis2
#8391 Post by tjreis2 » Thu Jun 08, 2023 8:53 am
This is the script job:
Drag and drop FILE #1 and press enter...F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv
Drag and drop FILE #2 and/or press enter...
FINDSTR: Cannot open C:\Users\Tiago\AppData\Local\Tempaudio.format.txt
A subdirectory or file F:\Movies\TEMP_folder already exists.
processing..."Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv"
reading input tracks format/id/language...
done.
tsMuxeR version git-de67de8. github.com/justdan96/tsMuxer
HEVC muxing fps is not set. Get fps from stream. Value: 23.976
0.0% complete
Processed 168071 video frames
100.0% complete
Flushing write buffer
Mux successful complete
Muxing time: 1 min 7 sec
The script has completed , no more file to process...
tjreis2
#8392 Post by tjreis2 » Thu Jun 08, 2023 8:56 am
This is the mediainfo from the input file:
General
Unique ID : 309952400007334840793798100813789433907 (0xE92EA92D85FC4B0EBC73B97094A29033)
Complete name : F:\Movies\Spider-Man.Into.the.Spider-Verse.2018.2160p.UHD.BDRemux.TrueHD.Atmos.7.1.HYBRID.DoVi-DVT.mkv
Format : Matroska
Format version : Version 4
File size : 43.1 GiB
Overall bit rate : 52.8 Mb/s
Movie name : Spider-Man: Into the Spider-Verse (2018)
Encoded date : 2022-04-18 20:37:17 UTC
Writing application : mkvmerge v66.0.0 ('Josie') 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Attachments : poster.jpg
IMDB : tt4633694
TMDB : movie/324857
Video
Format : HEVC
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 47.6 Mb/s
Frame rate mode : Constant
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.239
Stream size : 38.8 GiB (90%)
Title : Spider-Man Into the Spider-Verse (2018) - Release by Dolby Vision Torrents
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 374 MiB (1%)
Title : Dub, UHD Blu-Ray
Language : Russian
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 640 kb/s
Stream size : 535 MiB (1%)
Title : Dub, Blu-Ray
Language : Ukrainian
Default : No
Forced : No
Audio #3
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 267 kb/s
Maximum bit rate : 4 935 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Delay relative to video : 8 ms
Stream size : 2.67 GiB (6%)
Title : Original
Language : English
Default : No
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Audio #4
Format : AC-3
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate : 640 kb/s
Title : Original
Language : English
Default : No
Forced : No
Audio #5
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Delay relative to video : 32 ms
Stream size : 160 MiB (0%)
Title : Commentary by Writer/Producer Phil Lord, Actor Christopher Miller, Directors Bob Persichetti, Peter Ramsey and Rodney Rothman
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 55 min
Bit rate : 2 b/s
Frame rate : 0.009 FPS
Count of elements : 64
Stream size : 2.17 KiB (0%)
Title : Forced
Language : Russian
Default : Yes
Forced : No
Text #2
Format : UTF-8
Bit rate : 82 b/s
Frame rate : 0.210 FPS
Count of elements : 1461
Stream size : 70.1 KiB (0%)
Title : Full
Language : Russian
Default : No
Forced : No
Text #3
Format : UTF-8
Bit rate : 2 b/s
Stream size : 2.12 KiB (0%)
Title : Forced
Default : No
Forced : No
Text #4
Format : UTF-8
Bit rate : 81 b/s
Count of elements : 1462
Stream size : 68.8 KiB (0%)
Title : Full
Default : No
Forced : No
Text #5
Format : UTF-8
Bit rate : 71 b/s
Frame rate : 0.266 FPS
Count of elements : 1840
Stream size : 60.5 KiB (0%)
Title : Full
Language : English
Default : No
Forced : No
Text #6
Format : UTF-8
Bit rate : 81 b/s
Frame rate : 0.323 FPS
Count of elements : 2258
Stream size : 69.2 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #7
Format : UTF-8
Bit rate : 132 b/s
Frame rate : 0.328 FPS
Count of elements : 2301
Stream size : 113 KiB (0%)
Title : SDH-Colored
Language : English
Default : No
Forced : No
Text #8
Format : UTF-8
Bit rate : 113 b/s
Frame rate : 0.299 FPS
Count of elements : 2098
Stream size : 97.1 KiB (0%)
Title : Commentary
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:09:03.793 : en:Chapter 2
00:14:04.719 : en:Chapter 3
00:18:51.714 : en:Chapter 4
00:29:39.027 : en:Chapter 5
00:34:14.636 : en:Chapter 6
00:40:34.432 : en:Chapter 7
00:44:22.827 : en:Chapter 8
00:48:06.884 : en:Chapter 9
00:58:45.856 : en:Chapter 10
01:06:04.460 : en:Chapter 11
01:09:55.483 : en:Chapter 12
01:20:00.004 : en:Chapter 13
01:24:54.923 : en:Chapter 14
01:33:33.399 : en:Chapter 15
01:55:26.920 : en:Chapter 16
#8393 Post by RESET_9999 » Thu Jun 08, 2023 11:07 am
it looks like your path to the tool ''jq.exe'' is not right or missing.
here's the folder for all the tools:
https://drive.google.com/file/d/1qavvq_ ... sp=sharing
tjreis2
#8394 Post by tjreis2 » Thu Jun 08, 2023 11:34 am
It works now with your tool pack, clearly it was a missing tool somewhere, thank you so much!
deadchip12
#8395 Post by deadchip12 » Thu Jun 08, 2023 3:07 pm
RESET_9999 wrote:
Wed Jun 07, 2023 2:39 pm
deadchip12 wrote:
Wed Jun 07, 2023 2:37 pm
st use tsmuxer to remux the mkv file into bluray folder and play via usb?
because the x800m2 5ghz wifi is fast enough to play high bitrate bluray.
bluray folder playback is not supported via the network
Hmm ok
But is it advisable to remux the mkv file into bluray folder and play via usb? Or we should always remux the original bluray folders?
#8396 Post by RESET_9999 » Thu Jun 08, 2023 4:26 pm
Hmm ok
it's always safer to remux from the original/untouched BD folders but I do sometimes use MKV P7 source when I can't find the bluray (no seed) and it plays fine on my x800m2.
Trees
#8397 Post by Trees » Thu Jun 08, 2023 8:25 pm
Quick question, when using dovi_tool mode 3 to extract the RPU from a P5 file, is any from the RPU data lost? I'm asking because the other day, I read someone claiming both chroma and luma data being lost when using mode 3; apparently, only dynamic metadata is being carried over from the P5 files to the P8.1 files.
Is this true? Just curious.
deadchip12
#8398 Post by deadchip12 » Fri Jun 09, 2023 6:12 am
Hmm ok
sometimes remux may not have AC3 core in the truehd track so atmos won't work if we remux it into bluray folder and play via usb right?
quietvoid
#8399 Post by quietvoid » Fri Jun 09, 2023 11:37 am
Yes, the mapping metadata contained in profile 5 is not usable in profile 8.1.
It wouldn't make sense to keep it.
#8400 Post by RESET_9999 » Fri Jun 09, 2023 12:05 pm
THD in MKV remux will never have an ac3 core. My script will add a core when you process it.
