Decrypt/convert from a local directory
kaschey
#1 Post by kaschey » Wed Jun 07, 2023 1:21 pm
Apologies if it's a dumb question, I haven't found an answer for this question.
I have a regular encrypted Blu-ray files copy (just files in my local filesystem). Can I use makemkv to convert these encrypted files to MKV?
And if I have decrypted Blu-ray files copy, can I convert them to MKV?
Re: Decrypt/convert from a local directory
#2 Post by dcoke22 » Wed Jun 07, 2023 10:19 pm
kaschey wrote: Wed Jun 07, 2023 1:21 pm I have a regular encrypted Blu-ray files copy (just files in my local filesystem). Can I use makemkv to convert these encrypted files to MKV?
How did you make this copy?
If you use MakeMKV to create a backup (either encrypted or decrypted) then for sure MakeMKV can open that backup and create .mkv files.
If you do something else, the answer is maybe but probably not.
