Post
by RESET_9999 » Thu Jun 01, 2023 11:20 am
RESET_9999 wrote: ↑Wed May 31, 2023 1:00 pm
try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
TL private tracker is open right now.
Hellboy.
Post
by Hellboy. » Thu Jun 01, 2023 2:05 pm
RESET_9999 wrote: ↑Thu Jun 01, 2023 11:20 am
Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
Edit: Thanks
Hellboy. on Thu Jun 01, 2023 6:42 pm, edited 1 time in total.
Post
by RESET_9999 » Thu Jun 01, 2023 2:08 pm
Hellboy. wrote: ↑Thu Jun 01, 2023 2:05 pm
torrentleech. (org)
valington
Post
by valington » Thu Jun 01, 2023 5:34 pm
RESET_9999 wrote: ↑Thu Jun 01, 2023 2:08 pm
torrentleech. (org)
But on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a great
LV8HD
Post
by LV8HD » Thu Jun 01, 2023 6:01 pm
valington wrote: ↑Thu Jun 01, 2023 5:34 pm
torrentleech. (org)
There's plenty of those on TL, but if you want more you should join some trackers like PHD, PTP, BHD,HDT, ecc...
I'm pretty shure they sometimes open sign-ups via donations.
SMD88
Post
by SMD88 » Fri Jun 02, 2023 7:41 am
Sorry for the horribly noob question, but I am trying to work this DV thing out. I will be watching on a shield or my SONY TV, with KODI or VLC. Does MakeMKV allow DV with those programs yet? Or is it still a matter of combining them separately?
I only have my 10 year old laptop at the moment, so I cannot test the UHD rips I have made.
Tjanks!
kazuma
Post
by kazuma » Fri Jun 02, 2023 7:23 pm
LV8HD wrote: ↑Thu Jun 01, 2023 6:01 pm
torrentleech. (org)
what are the full names of those websites?
Mrmorrison
Post
by Mrmorrison » Tue Jun 06, 2023 5:15 pm
@RESET_9999
Hello Chief!
I don't know exactly when this problem started, if it depends on the bat version or the recent tools update you made available for a few days.
But with path 4-3 it often happens that the output TS file is incomplete.
Sometimes it's incomplete for 30 minutes, sometimes more, sometimes less.
My x800m2 freezes in these files (that's how I noticed it) at the last second. With other devices, however, the video simply stops as if it had come to an end. Do you know anything about it?
It's never happened to me before, yet I've been using your tool for a long time. I know it would be much better if there is the iso file as input but I am often forced to use mkv ST DL.
I tried to use tsmuxer separately with the BL and EL files that the tool generates, adding the original mkv file, but it ends with an error (which unfortunately I didn't write) maybe it depends on the final mux. What can I do? deThe last three films, two have had this problem
Post
by RESET_9999 » Tue Jun 06, 2023 5:32 pm
Mrmorrison wrote: ↑Tue Jun 06, 2023 5:15 pm
@RESET_9999
Hello Chief!
Most likely some SRT subtitles with invalid timing.
I had this issue with a lot of MAX web-dl and the solution is to uncheck the problematic subs.
When the ts muxing fails, the script is made to not delete the final processed HEVC file so you don't have to start over.
Mrmorrison
Post
by Mrmorrison » Tue Jun 06, 2023 6:48 pm
RESET_9999 wrote: ↑Tue Jun 06, 2023 5:32 pm
What bat version can I use to be able to run tsmuxer at the end of the script, like it was a while ago?
Post
by RESET_9999 » Tue Jun 06, 2023 6:55 pm
it has nothing to do with the script.
as I said, the problem is some specific SRT that have invalid timing. So deselect the subs and mux manually.
It could also be caused by THDmerge, because sometimes it fails to merge an empty core for some reason.
tjayz
Post
by tjayz » Tue Jun 06, 2023 9:48 pm
torrentleech. (org)
For torrents that existed before rarbg went down use their proxies. Complete list can be found by going to 1337x > Movies > RARBG.
RESET_9999 wrote: ↑Fri Feb 24, 2023 8:19 pm
dom61 wrote: ↑Fri Feb 24, 2023 7:47 pm
I have exported HDR 10+ and Dolby Vison metadata via DaVinci Resolve.
you can use the script in my signature (workflow 1-1) to inject both metadata. Or use the Dovi_tool and HDR10plus_tool to inject manually, you can find these tools on quietvoid's GitHub.
Dinst wrote: ↑Thu Feb 16, 2023 6:24 pm
Has anybody got a link to a decent tutorial for generating Dolby Vision using Davinci Resolve?
see my youtube channel (link in my signature), i made a video tutorial a while ago.
if you want to save some time, I already generated DV in resolve for most of the movies, here are over 600 RPU files ready to be injected
https://mega.nz/folder/CjYWyaZR#tSlKPhdblAd8shSaYoiOWA
Sorry to have to be the 5th or so person to ask but could I also be sent a link for this in PM? Much appreciated.
UBP-X800M2 / LG OLED CX / NAD M17 V2i
Post
by RESET_9999 » Tue Jun 06, 2023 11:05 pm
tjayz wrote: ↑Tue Jun 06, 2023 9:48 pm
No worries, anyone that wants a link, just ask me...
Mrmorrison
Post
by Mrmorrison » Wed Jun 07, 2023 7:30 am
RESET_9999 wrote: ↑Tue Jun 06, 2023 6:55 pm
I was asking this because I could remove the subtitles that were not necessary for me before the mux and, perhaps, in this way I would have already been able to remove the faulty ones without even knowing it and without having to restart the mux process.
Anyway... stupidly I had deleted the EL and BL files so I was forced to repeat the procedure in order to get to the moment of the error and manually use tsmuxer with the two files your script would have left (undeleted) instead, to my amazement, this time there was no mistake and the film is complete. How is it possible? How come a subtitle that was annoying before, now hasn't given any problems? Yet I'm sure that tsmuxer encountered the problem towards the end of the mux, when working on subtitles..
