MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_9EE8.tgz dump submitted
Submitted the dump for the Steelbook of The Super Mario Bros. Movie.
Re: MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_9EE8.tgz dump submitted
I have the same dump file. Glad this was already submitted but if in case Admin needs it, let me know. As of June 5th, 2023. We still can't decrypt The Super Mario Bros Movie. Crossing fingers it will be done.
sephirothkefka
I noticed this dump was different than my regular copy which i ordered via target (MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_57F0). I submitted mine earlier. Hopefully it won't be too long.
internetenjoyer
Came here to check status on this, but I have been curious, how do you create and then submit a dump for these new discs to help out? Is it helpful to submit a dump if someone else has already done it?
Suggested reading... UHD FAQ. If you still have questions, please ask.internetenjoyer wrote: ↑Wed Jun 07, 2023 1:11 amCame here to check status on this, but I have been curious, how do you create and then submit a dump for these new discs to help out? Is it helpful to submit a dump if someone else has already done it?
FWIW (and for future reference) I was able to rip this as of 27 hours ago. Can't say if it was available earlier than that, but I know the day prior it was not so... ¯\_(ツ)_/¯
Worked for me 2 days ago. US BB SB.
As of 6/8/2023, this 4K movie is rippable now. Thanks again to the Admin!
slickslack
Did you ever get your version to rip? I have the same Target version with that same dump file name and it still does not rip for me as of today. I also submitted that dump file just now, but wondering if it's another issue I might be having.sephirothkefka wrote: ↑Tue Jun 06, 2023 5:42 pmI noticed this dump was different than my regular copy which i ordered via target (MKB20_v77_The_Super_Mario_Bros_Movie_(2023)_57F0). I submitted mine earlier. Hopefully it won't be too long.
Tried ripping the Super Mario Bros 4K movie today and couldn't got failed to open disc. I've attached the dump file, anybody else gettig this?
idisagree2
I get this debug code, and it says it is going to take 36 hours to make the MKV.
DEBUG: Code 1 at KGL@su><&j8)^3 D_G(VT:121262371
.... same message hundreds of times ..........
The dump file I'm getting is MKB20_v77_The_Super_Mario_Bros_Movie(2023)_57F0. Tried again this morning still comes up The volume key is unknown for this disc - video can't be decrypted.
You've got to submit that dump to svq@makemkv.com. That 4 digit hash at the end of the dump file name is important. If the hash is different, then a different key needs to be created to unlock your disc. It is not uncommon for a high profile 4K UHD release to have multiple keys.
I wonder if some problems are because it's a 3 layer disc. My WH14NS40 drive always errors out right at the end with read errors and ends up failing after copying 99% of the main feature. When I use my BU40N slimline that supports 4K without patching it reads without a problem.
Uploading the dump file now. I got this disc from Target, still can't rip the 4K disc.
