Into The Blue - all tracks rip fine except the main track
captain
#1 Post by captain » Sat Jun 04, 2011 1:49 am
edit: Oh !@#$! I am out of disk space again, but why doesn't MakeMKV *say that* instead of these cryptic Debug Codes?
It seems that MakeMKV is constantly failing because of two main reasons, neither of which is made clear to the user by MakeMKV:
1) out of disk space
2) bad DVD/blu-ray disc.
original post:
I don't understand why the makemkv "console" log (not the System syslog "console") is different from the makemkv logfile. but whatever.
DEBUG: Code 0 at -a-8ODSZTXzsq{hz.:121263728
LIBMKV_TRACE: Exception: EOF in writeFully
Failed to save title 3 to file /Volumes/makemkv_rips/Into The Blue/title03.mkv
10 titles saved, 1 failed
logfile:
001003:0020 DEBUG: Code 131072 at poHE\4t66*O+v|y`;2_'{7:121262325
001003:0020 DEBUG: Code 4294967295 at poHE\4t66*O+v|y`;2_'{7:29394137
001003:0020 DEBUG: Code 28 at poHE\4t66*O+v|y`;2_'{7:213130352
001003:0020 DEBUG: Code 0 at -a-8ODSZTXzsq{hz.:121263728
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 3 to file /Volumes/makemkv_rips/Into The Blue/title03.mkv
So, here is a prime example of what I was asking about earlier. MakeMKV spends something like an hour ripping data for this 18gb track, saving saving saving saving.... and then after saving GBs of data it suddenly decides to bail, leaving NO DATA SAVED AT ALL. IMHO, the default should be to pop up a dialog box saying something like "Oh noes! MakeMKV encountered a <specific?> error, the data saved is not complete! Do you want to keep what we managed to rip, or delete it?"
captain
Re: Into The Blue - all tracks rip fine except the main trac
#2 Post by captain » Sat Jun 04, 2011 12:23 pm
PS: and a really cool feature would be for MakeMKV to do several things re. space:
1) Predict the amount of HD space that will be needed and FOREwarn the user to clear out enough space before MakeMKV rips enough to fill the drive.
2) PAUSE, rather than quit or crash, when the drive gets full; then pop up a message telling the user that the drive is full and he needs to delete some stuff before MakeMKV can continue (maybe offer the OPTION of deleting the rip in progress, but NOT throw out an hour's worth of work! ;-)
Thanks for reading.
#3 Post by mike admin » Sat Jun 04, 2011 11:51 pm
captain wrote:1) Predict the amount of HD space that will be needed and FOREwarn the user to clear out enough space before MakeMKV rips enough to fill the drive.
This is exactly what it does ( or at least supposed to do). Did you get an error because your drive was full or because the drive was formatted as FAT and couldn't hold data bigger than 4 GB? What OS are you using?
