May Key is bad
May Key is bad
Is there a new code for June? Im trying to copy a Blu ray and it wont let me
Re: May Key is bad
Setting your system date to 5/30/2023 to start the program should work.
Re: May Key is bad
Is there any info on when the New key will be uploaded please?
Re: May Key is bad
Best way is to check the MakeMKV is free while in beta message, which is updated periodically. Usually within a few days.
Re: May Key is bad
Says my evaluation period has ended still after I changed to 5 /30
Re: May Key is bad
I hope new key for june is posted soon. currently unable to use makemkv at all as it removes key and wont start up.
Re: May Key is bad
Come on yall, I gotta turn in these library blurays soon!
Re: May Key is bad
You could set-up a virtual machine. I tested it with microsoft hyper-v software and it works, you just need the virtual machine to see the drive and that's it. You could potentially do infinite rips, once the 30 days trial is over, you can just delete the virtual machine and remake it, and it would be like brand new.Frost7177 wrote: Thu Jun 01, 2023 1:06 am Is there a new code for June? Im trying to copy a Blu ray and it wont let me
Imagine doing it over and over, yeah.
I also tested it with DvdFab but there's seem to be some kind of protection and it won't open the disk, so makemkv it's the only one that works!
Fortyniner
Re: May Key is bad
Adding my voice to this chorus. Technically, the May key is not "bad". It's just expired, and has been so for three days as I write this. For the future, it would be useful to post a new key before the old one expires. Hoping that someone is listening...
Re: May Key is bad
You're kidding, right? You're not really going to copy Blu-Rays from the library, are you? Are they at least out-of-print?
