May Key is bad
Frost7177
May Key is bad
Post by Frost7177 » Thu Jun 01, 2023 1:06 am
Is there a new code for June? Im trying to copy a Blu ray and it wont let me
Re: May Key is bad
Post by Woodstock » Thu Jun 01, 2023 1:40 am
Setting your system date to 5/30/2023 to start the program should work.
ancient
Re: May Key is bad
Post by ancient » Thu Jun 01, 2023 2:42 pm
Is there any info on when the New key will be uploaded please?
Re: May Key is bad
Post by Woodstock » Thu Jun 01, 2023 4:04 pm
Best way is to check the MakeMKV is free while in beta message, which is updated periodically. Usually within a few days.
Frost7177
Re: May Key is bad
Post by Frost7177 » Thu Jun 01, 2023 10:40 pm
Says my evaluation period has ended still after I changed to 5 /30
bobby2478
Re: May Key is bad
Post by bobby2478 » Sat Jun 03, 2023 3:54 pm
I hope new key for june is posted soon. currently unable to use makemkv at all as it removes key and wont start up.
theshakl
Re: May Key is bad
Post by theshakl » Sat Jun 03, 2023 6:33 pm
Come on yall, I gotta turn in these library blurays soon! 😅
P13r_
Re: May Key is bad
Post by P13r_ » Sat Jun 03, 2023 6:45 pm
You could set-up a virtual machine. I tested it with microsoft hyper-v software and it works, you just need the virtual machine to see the drive and that's it. You could potentially do infinite rips, once the 30 days trial is over, you can just delete the virtual machine and remake it, and it would be like brand new.
Imagine doing it over and over, yeah. :roll: :roll:
I also tested it with DvdFab but there's seem to be some kind of protection and it won't open the disk, so makemkv it's the only one that works!
Fortyniner
Re: May Key is bad
Post by Fortyniner » Sat Jun 03, 2023 10:22 pm
Adding my voice to this chorus. Technically, the May key is not "bad". It's just expired, and has been so for three days as I write this. For the future, it would be useful to post a new key before the old one expires. Hoping that someone is listening...
Faber
Re: May Key is bad
Post by Faber » Mon Jun 05, 2023 5:41 pm
You're kidding, right? You're not really going to copy Blu-Rays from the library, are you? Are they at least out-of-print?
