Possible Bug (or perhaps just an oversight)?
Radiocomms237
#1 Post by Radiocomms237 » Fri May 05, 2023 1:26 am
When I "Open Files" in MakeMKV and drill-down through the backup folder to "STREAM", it won't allow me to open any transport stream (.m2ts) files? (.m2ts is not an option in the drop-down box, even under "All video files".)
This seems odd considering these are a valid video file (I can play them directly with VLC MP).
Could we please have the option to open (and rip) transport stream files individually and/or in batches?
Sunoo
Re: Possible Bug (or perhaps just an oversight)?
#2 Post by Sunoo » Fri May 05, 2023 1:31 am
Use MKVToolNix.
Radiocomms237
#3 Post by Radiocomms237 » Fri May 05, 2023 1:34 am
Yes I use MKXToolNix as well, but that won't resync tracks when muxing like MakeMKV does.
Radiocomms237
#4 Post by Radiocomms237 » Sat Jun 03, 2023 5:27 am
I really need either this or an "Open Blu-ray manually" option to be added to MakeMKV quite urgently. I had hoped that it might be an easy addition and may have been included in v1.17.4, but no such luck.
Almost every day I run across a disc where MakeMKV decides that I don't need to see certain tracks, so it denies me access to them (and no, this behaviour has nothing to do with the minimum duration setting).
I can mux these .m2ts files using other software, but that doesn't do everything MakeMKV does as far as re-syncing tracks etc.
Please, please, PLEASE add this option?!
