Ignore my quote. But answering “yes” to your PM. I don’t have permissions to respond yet.Coopervid wrote: Tue May 09, 2023 8:03 pm Not interesting. Normal. Makemkv tells you to close the application after entering the key and restart the program.
LibreDrive for Pioneer drives
GDMFS0B
GDMFS0B
SUCCESS!! Thanks for the help!
tacorama
cannot seem to rip UHD discs with this external drive on MakeMKV v1.17.4 linux(x64-release)
SDF v098: PIONEER_BD-RW___BDR-XS06_1.01_OLDL004417UC
Is there anything I can do to fix this?
Don't think the xs06 does uhdtacorama wrote: Thu Jun 08, 2023 12:20 am cannot seem to rip UHD discs with this external drive on MakeMKV v1.17.4 linux(x64-release)
vanshady
Is there any update on firmware downgrade? I need an internal drive but no seller is selling it yet, unless you are willing to do it?Billycar11 wrote: Thu May 25, 2023 12:21 amfor now its only safe to buy a pioneer that has been flashed from sellers like me marty or asmcomKrawk wrote: Wed May 24, 2023 11:15 pm So, at this stage is there even a point in trying to buy a Pioneer drive, knowing that the firmware cannot be downgraded and Libre is not supported on post 12/22 drives?
you dont need an internal you want itvanshady wrote: Thu Jun 08, 2023 1:25 amIs there any update on firmware downgrade? I need an internal drive but no seller is selling it yet, unless you are willing to do it?Billycar11 wrote: Thu May 25, 2023 12:21 amfor now its only safe to buy a pioneer that has been flashed from sellers like me marty or asmcomKrawk wrote: Wed May 24, 2023 11:15 pm So, at this stage is there even a point in trying to buy a Pioneer drive, knowing that the firmware cannot be downgraded and Libre is not supported on post 12/22 drives?
uhd ripping on pioneer internal or external is the same
vanshady
Yes sorry I want an internal, I bought a pc case that specifically had external 5.25 slost that I prepared to get an internal drive for, but then can't really buy a pioneer one now.Billycar11 wrote: Thu Jun 08, 2023 2:29 amyou dont need an internal you want itvanshady wrote: Thu Jun 08, 2023 1:25 amIs there any update on firmware downgrade? I need an internal drive but no seller is selling it yet, unless you are willing to do it?Billycar11 wrote: Thu May 25, 2023 12:21 am
Bumbuliuz
I'm a bit of a newbie here and and wanted to check something. I have a External Verbatim USB-C 3.2 Gen1 Blu-ray writer. This below is the info I see in the MakeMKV program about the drive I have.
OS device name: L:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: AF********
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
I can rip Dvd's and Blu-Ray's fine, I'm just curious if I can rip UHD discs. I know it can't play UHD discs, I was just curious about this and if it could be upgraded or flashed to rip UHD discs. It's fine if it's not possible, I bought it as a Blu-Ray burner anyway.
OS device name: L:
Revision: 1.14
No. The UD03 will not read UHDs. You would need an UD04. Like the one in the Verbatim 43888 if you are located in EU.
Bumbuliuz
Ok thanks for the reply, I thought so, just wanted to be sureCoopervid wrote: Sat Jun 10, 2023 9:53 am No. The UD03 will not read UHDs. You would need an UD04. Like the one in the Verbatim 43888 if you are located in EU.
Pjunkm
Pioneer BDR-XD08UMB-S no longer works for 4K. Firmware 1.2 is on this drive from the factory
zaqqaz6917
I wonder in Amazon USA, if one were to order using Prime from a third party seller, they might still have the old fw drives and the price is the same as well. If you use the Amazon as seller option then the drives come from Pioneer directly and will most like have the new fwPjunkm wrote: Fri Jun 16, 2023 5:38 pm Pioneer BDR-XD08UMB-S no longer works for 4K. Firmware 1.2 is on this drive from the factory
MKVtesterB
Hi i have new owner of:
Description du pilote PIONEER BD-RW BDR-UD04 USB Device
Date du pilote 21/06/2006
Version du pilote 10.0.22621.1
Fournisseur du pilote Microsoft
Fichier INF cdrom.inf
INF Section cdrom_install
Identification du matériel USBSTOR\CdRomPIONEER_BD-RW___BDR-UD041.14
I'am testing creation of BD+ MKV.
And soon i will test UHD.
is it useful to install the latest Libredrive compatible firmware?
There is no public way to flash pioneers currentlyMKVtesterB wrote: Fri Jun 23, 2023 12:24 pm Hi i have new owner of:
is it used to install the latest Libredrive compatible firmware?
