I was getting 1 MKV file out of my backups before but over the last couple of days i seem to be getting a no of files.
Initially they worked fine but no my WD media player tells me they dont support them.
Any ideas
Thank you
MKV files not working
Re: MKV files not working
What MakeMKV version and what OS are you using?
nkhan
I am using Windows 7 and the latest version of makeMKV.
I can still make a MKV file out of the main film and play.
I generally always made a back up of the whole disc so i had all the extras
Icetrips
WD media player doesn't support MKV with more than 1 audiotrack.
Remove audiotrack and retry.
MakeMKV registered
System: Windows 7 x64 SP1, LG WH10LS30
Playback Devices: Media Player Classic, Samsung DLNA
nkhan
So what your saying is if more than 1 audio track is selected it wont work
Icetrips
Yes. WD Media player limitation.
Some website talk about it.
Most media player have that kind of limitation even if they write *SUPPORT .MKV* (they can't choose the correct audiotrack).
MakeMKV registered
crowfax
I have the WD TV Live and it supports more than one audio track.Icetrips wrote:WD media player doesn't support MKV with more than 1 audiotrack.
Works on mine.Icetrips wrote:Yes. WD Media player limitation.
They're wrong, you should let them know. Spreading bad press about products isn't very nice!Icetrips wrote:Some website talk about it.
I have 3 media players (2 that are connected to TV's and 1 portable). None of them have any limitations regarding MKV and picking audio streams.Icetrips wrote:Most media player have that kind of limitation even if they write *SUPPORT .MKV* (they can't choose the correct audiotrack).
Icetrips
crowfax: Check by yourself before trashing on someone else please.
http://www.amazon.co.uk/Western-Digital ... B002KQ2JKQ
Perhaps it's fix by a firmwire patch.
And it's not because it's work on yours with work on every WD media player.
If I remember correctly they have at least 3 different model.
nkhan: Just try MKV with only one audiotrack if it's fix your issue or check for a firmware update.
This issue was still there at begin of 2011, it's basicly why I don't buy it.As far as file support goes it will play anything unless it is an MKV or the audio is DTS, (it will only do AC3 at the moment).
MakeMKV registered
crowfax
Hard for me to check when I wasn't provided links.Icetrips wrote:Check by yourself before trashing on someone else please.
They have 5:Icetrips wrote:If I remember correctly they have at least 3 different model.
WD TV (1st and 2nd generation)
WD TV Live
WD TV Live Plus
WD TV Live Hub
WD TV Mini
They all have the same internals for playback, aside from the mini, which uses a slower CPU, as highlighted by the fact that it is limited to 1080i. Also the "plus" and the "hub" have an extra chip in them for DRM, which satisfies Netflix for their streaming features.Icetrips wrote:And it's not because it's work on yours with work on every WD media player.
Romansh
According to Wikipedia, the 1st gen. WD TV doesn't use the same SoC as the 2nd gen. and the Live:crowfax wrote:They have 5:Icetrips wrote:If I remember correctly they have at least 3 different model.
WD TV Live
WD TV Live Plus
WD TV Live Hub
WD TV Mini
http://en.wikipedia.org/wiki/WD_TV
(the Live Plus and Live Hub also use a different SoC, though as I understand it it's identical to the one used in the 2nd gen. WD TV and the Live aside from DRM support)
That being said, the Live handles HandBrake's MKV output (which, by default, uses variable framerate) with ease, whereas there have been reports (on the HandBrake forums) of A/V desync on the 2nd gen. WD TV for the same files: the same hardware, even with similar software, doesn't guarantee the exact same capabilities.
All I know for sure is that the WD TV Live (with firmware 1.05.04, and some older firmwares which I didn't bother to note down) does handle multiple AAC and AC3 audio tracks without issues.
nkhan
Ok thanks guys
I will give it a go but there is a few options of audio to choose I tend to just select the main film and leave everything how is it now and works
