I did try profile 7 TS. It did work but was a bit glitchy. Not sure if was MEL or FEL. I was using Top Gun Maverick as my test movie.RESET_9999 wrote: Tue May 30, 2023 12:07 pmgood to know.MartyMcNuts wrote: Tue May 30, 2023 9:50 am So after a bit of testing, the TS seems to work best on the TCL 8-series TV’s player. DV works good with profile 8. With Kodi on the TV, only MP4’s show DV. I’ll stick with the TS as the audio is better.
My current (8 year old receiver) only has ARC so I’m only getting DD+ instead of ATMOS but only for DV movies. Everything else I watch through my HTPC so I can get ATMOS and DTS:X audio. The TV does have EARC so I’ll have to look at upgrading my receiver sooner rather than later then I can have DV and HD audio.
Did you try Profile 7 fel? I read the TCL has the same chip as the oppo players.
Hey @RESET_9999,
How to extract the RPU when the movie contains multiple m2ts files? Using 2-2 do I have to do each m2ts file separately? Is there an option to add multiple m2ts's at once or merge them into one file for processing? I couldn't find one.
You have to merge them first with tsmuxer, makemkv or dgdemux
Ah, yes. Easy peasy.RESET_9999 wrote: Wed May 31, 2023 10:56 am You have to merge them first with tsmuxer, makemkv or dgdemux
valington
Hi my question is not about dv but RARBG tracker is down where we could get dolby vision torents now may be you know or maybe we could download it from you RESET if it s possible?RESET_9999 wrote: Wed May 31, 2023 10:56 am You have to merge them first with tsmuxer, makemkv or dgdemux
try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.valington wrote: Wed May 31, 2023 12:52 pm Hi my question is not about dv but RARBG tracker is down where we could get dolby vision torents now may be you know or maybe we could download it from you RESET if it s possible?
sw5163
TL private tracker is open right now.RESET_9999 wrote: Wed May 31, 2023 1:00 pm try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
Hellboy.
Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.RESET_9999 wrote: Thu Jun 01, 2023 11:20 amTL private tracker is open right now.RESET_9999 wrote: Wed May 31, 2023 1:00 pm try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
Edit: Thanks
torrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
valington
But on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a greatRESET_9999 wrote: Thu Jun 01, 2023 2:08 pmtorrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
LV8HD
There's plenty of those on TL, but if you want more you should join some trackers like PHD, PTP, BHD,HDT, ecc...valington wrote: Thu Jun 01, 2023 5:34 pmBut on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a greatRESET_9999 wrote: Thu Jun 01, 2023 2:08 pmtorrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
I'm pretty shure they sometimes open sign-ups via donations.
SMD88
Sorry for the horribly noob question, but I am trying to work this DV thing out. I will be watching on a shield or my SONY TV, with KODI or VLC. Does MakeMKV allow DV with those programs yet? Or is it still a matter of combining them separately?
I only have my 10 year old laptop at the moment, so I cannot test the UHD rips I have made.
Tjanks!
Tjanks!
kazuma
what are the full names of those websites?LV8HD wrote: Thu Jun 01, 2023 6:01 pmThere's plenty of those on TL, but if you want more you should join some trackers like PHD, PTP, BHD,HDT, ecc...valington wrote: Thu Jun 01, 2023 5:34 pmBut on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a great
Mrmorrison
@RESET_9999
Hello Chief!
I don't know exactly when this problem started, if it depends on the bat version or the recent tools update you made available for a few days.
But with path 4-3 it often happens that the output TS file is incomplete.
Sometimes it's incomplete for 30 minutes, sometimes more, sometimes less.
My x800m2 freezes in these files (that's how I noticed it) at the last second. With other devices, however, the video simply stops as if it had come to an end. Do you know anything about it?
It's never happened to me before, yet I've been using your tool for a long time. I know it would be much better if there is the iso file as input but I am often forced to use mkv ST DL.
I tried to use tsmuxer separately with the BL and EL files that the tool generates, adding the original mkv file, but it ends with an error (which unfortunately I didn't write) maybe it depends on the final mux. What can I do? deThe last three films, two have had this problem
Hello Chief!
