zshguru
#1
Post
by zshguru » Tue May 30, 2023 1:51 pm
Hey
I'm looking at buying the LG BP50NB40 however according to the description it uses an old-fashioned USB-A cable. The computer I want to use this drive with is a Macbook Pro and only has USB-C. In my experience the dongles/adapters do not work well so I need a replacement cable. Which cable should I get? I don't have the BP50NB40 in my hands yet so I'm not sure what the connector it uses actually is other than micro-usb but which variety? I ask b/c some versions if micro-usb have a split/detent in them (like for hard drives).
Much appreciated to anyone who takes the time to answer me.
#2
Post
by MartyMcNuts » Tue May 30, 2023 3:46 pm
zshguru wrote: ↑Tue May 30, 2023 1:51 pm
Hey
USB-C to Micro B 2.0
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
acidred35
#4
Post
by acidred35 » Fri Apr 18, 2025 12:51 pm
zshguru, has the USB-C to Micro B 2.0 cable worked out for you? Even when burning a disc?
