I dont know if you guys heard but @DMDreview did a great video showing that some Android boxes are actually doing fake TV-LED rgb tunneling (the player still does the rpu processing).
It also explains why many devices have different L1/L2 responses. Happy to confirm that the X700 and x800m2 don't have this problem.
https://www.youtube.com/watch?v=TO9uwkjTXbQ
The video is very technical so I made a quick example easy to understand:
https://www.youtube.com/watch?v=z8sgHR78Rdw
So after a bit of testing, the TS seems to work best on the TCL 8-series TV’s player. DV works good with profile 8. With Kodi on the TV, only MP4’s show DV. I’ll stick with the TS as the audio is better.RESET_9999 wrote: Sat May 27, 2023 11:58 pm I dont know about TCL TVs but TS has better DV support on devices usually.
My current (8 year old receiver) only has ARC so I’m only getting DD+ instead of ATMOS but only for DV movies. Everything else I watch through my HTPC so I can get ATMOS and DTS:X audio. The TV does have EARC so I’ll have to look at upgrading my receiver sooner rather than later then I can have DV and HD audio.
good to know.MartyMcNuts wrote: Tue May 30, 2023 9:50 am So after a bit of testing, the TS seems to work best on the TCL 8-series TV’s player. DV works good with profile 8. With Kodi on the TV, only MP4’s show DV. I’ll stick with the TS as the audio is better.
Did you try Profile 7 fel? I read the TCL has the same chip as the oppo players.
I did try profile 7 TS. It did work but was a bit glitchy. Not sure if was MEL or FEL. I was using Top Gun Maverick as my test movie.RESET_9999 wrote: Tue May 30, 2023 12:07 pmgood to know.MartyMcNuts wrote: Tue May 30, 2023 9:50 am So after a bit of testing, the TS seems to work best on the TCL 8-series TV’s player. DV works good with profile 8. With Kodi on the TV, only MP4’s show DV. I’ll stick with the TS as the audio is better.
Hey @RESET_9999,
How to extract the RPU when the movie contains multiple m2ts files? Using 2-2 do I have to do each m2ts file separately? Is there an option to add multiple m2ts's at once or merge them into one file for processing? I couldn't find one.
You have to merge them first with tsmuxer, makemkv or dgdemux
Ah, yes. Easy peasy.RESET_9999 wrote: Wed May 31, 2023 10:56 am You have to merge them first with tsmuxer, makemkv or dgdemux
Hi my question is not about dv but RARBG tracker is down where we could get dolby vision torents now may be you know or maybe we could download it from you RESET if it s possible?RESET_9999 wrote: Wed May 31, 2023 10:56 am You have to merge them first with tsmuxer, makemkv or dgdemux
try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.valington wrote: Wed May 31, 2023 12:52 pm Hi my question is not about dv but RARBG tracker is down where we could get dolby vision torents now may be you know or maybe we could download it from you RESET if it s possible?
TL private tracker is open right now.RESET_9999 wrote: Wed May 31, 2023 1:00 pm try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.RESET_9999 wrote: Thu Jun 01, 2023 11:20 amTL private tracker is open right now.RESET_9999 wrote: Wed May 31, 2023 1:00 pm try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
Edit: Thanks
torrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
But on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a greatRESET_9999 wrote: Thu Jun 01, 2023 2:08 pmtorrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
There's plenty of those on TL, but if you want more you should join some trackers like PHD, PTP, BHD,HDT, ecc...valington wrote: Thu Jun 01, 2023 5:34 pmBut on torrentleech there is no M2TS , BDMV dolby vision blu ray 2160p only remuxes mkv 7 profile , Rarbg was a greatRESET_9999 wrote: Thu Jun 01, 2023 2:08 pmtorrentleech. (org)Hellboy. wrote: Thu Jun 01, 2023 2:05 pm Can you share a link. I did a google search but i don't find anything related to TL private tracker. The only torrent i always used was rarbg.
I'm pretty shure they sometimes open sign-ups via donations.
