Version 1.6.10 fails converting to MKV
jrnkoch
#1 Post by jrnkoch » Fri Jun 03, 2011 9:38 am
Having problems converting to MKV in version 1.6.10. Looks lig the converting runs fine, but in last second when finishing, the KV file is removed from the destination folder. Converting using the previous version: 1.6.4 worked fine. I pasted the "log" below:
Title #0 was added (16 cell(s), 0:04:31)
Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 was added (16 cell(s), 0:04:31)
Title #3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 3 in VTS 1 is equal to title 1 and was skipped
Saving 1 titles into directory D:/Video.MKV
Failed to save title 0 to file D:/Video.MKV/title00.mkv
0 titles saved, 1 failed
Ventura
Re: Version 1.6.10 fails converting to MKV
#2 Post by Ventura » Fri Jun 03, 2011 3:03 pm
You've got plenty of storage space on D:? Just checking. I had it fail twice on a drive before checking the size of the drive, at which time I noticed I was a couple gig short.
Outside of that, I'd suggest maybe renaming the directory you want to store it in, it may not like "Video.MKV". As a general rule I like to keep full stops out of directory names.
jrnkoch
#3 Post by jrnkoch » Fri Jun 03, 2011 4:41 pm
Thanks for your suggestion, but I've tried that (more than 80 Gb on D:-drive). My actual destination folder is without "." in the name.
For info, my OS: Microsoft® Windows Vista™ Home Premium, Version 6.0.6002 Service Pack 2 Build 6002
Br jrnkoch
#4 Post by mike admin » Sat Jun 04, 2011 11:33 pm
Please enable debug messages per http://www.makemkv.com/faq/item/8/catid/6 and post the debug log
jrnkoch
#5 Post by jrnkoch » Mon Jun 06, 2011 6:16 pm
Thanks Mike, I've now posted the documentation as requested. Hope that you can use it finding the error.
Br jrnkoch
