cpumdhb55
Time to give back here. I bought the LG WH16NS40 Super Multi Blue Internal SATA 16x Blu-ray Disc Rewriter from Amazon for $69.00 about a week ago. After first flashing the correct firmware found in the all in one file pack referenced in this forum I found that I did not tick all of the correct options in SDFTool. The drive survived this goof but all of my attempts to rip resulted in MakeMKV failures with multiple log errors and the rip process just stopping at roughly 1/3 to 1/2 way through. Some of the disks would not read at all. This also resulted in locking Windows up to the point of having to hard reset. This falls under RTFQ big time. I''m now getting 7.5X speeds after reflashing correctly with zero problems. I'm lucky that I did choose the right firmware and that it was a seemingly minor mistake. Obviously 0200 is not the right time to attempt these things!
No you can't flash it after Dec 2022 you would have to buy a preflashed one from usleo708 wrote: Mon May 29, 2023 1:28 pm If I get the BDR-S13U-X or BDR-S13UBK with firmware after Dec 2022, does it mean they're not flashable to version that can rip UHD Discs?
If so, I'll just get the Asus BW-16D1HT.
leo708
Understood, thanks.Billycar11 wrote: Mon May 29, 2023 9:30 pmNo you can't flash it after Dec 2022 you would have to buy a preflashed one from usleo708 wrote: Mon May 29, 2023 1:28 pm If I get the BDR-S13U-X or BDR-S13UBK with firmware after Dec 2022, does it mean they're not flashable to version that can rip UHD Discs?
SH0D4N
I have an ASUS BW-16D1HT drive, but DVD rip speeds is slow.
It went fast from 0.5x to 4x, but then from there it slowly climbed to 7.8x speed. (6.1GB + 61MB + 180MB took ~13.5 minutes)
Have I missed something?
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Firmware version: 3.10
Disc Information
Label: DVD
Timestamp: 2013-10-30 11:12:01
Data capacity: 6.46 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
Same guidance applies...SH0D4N wrote: Wed May 31, 2023 2:10 pm I have an ASUS BW-16D1HT drive, but DVD rip speeds is slow.
viewtopic.php?f=16&t=31071
SH0D4N
Tried cleaning the disc.d00zah wrote: Wed May 31, 2023 2:14 pmSame guidance applies...SH0D4N wrote: Wed May 31, 2023 2:10 pm I have an ASUS BW-16D1HT drive, but DVD rip speeds is slow.
I am using OWC Mercury Pro enclosure, if that affects the rip speed.
baneling
hey everyone, I've been ripping for the last few weeks and now when I launch makemkv it says the application is too old and tells me to download the newest version. but there is no newer version. I have version 1.17.4. so I uninstall it and reinstall it and enter the registration code but it says the same thing. What do I do?
The free beta key is expired it will be updated soon might take a few days.baneling wrote: Fri Jun 02, 2023 10:52 pm hey everyone, I've been ripping for the last few weeks and now when I launch makemkv it says the application is too old and tells me to download the newest version. but there is no newer version. I have version 1.17.4. so I uninstall it and reinstall it and enter the registration code but it says the same thing. What do I do?
If you buy it it won't have this issue https://www.makemkv.com/buy/
Wait for Mike to post the new beta key. This happens every ~2 months for users who haven't purchased a permanent key.
viewtopic.php?f=1&t=31101
baneling
ok thanksBillycar11 wrote: Fri Jun 02, 2023 10:59 pmThe free beta key is expired it will be updated soon might take a few days.baneling wrote: Fri Jun 02, 2023 10:52 pm hey everyone, I've been ripping for the last few weeks and now when I launch makemkv it says the application is too old and tells me to download the newest version. but there is no newer version. I have version 1.17.4. so I uninstall it and reinstall it and enter the registration code but it says the same thing. What do I do?
stikves
Double checking...
Since, I have recently bricked my previous drive: viewtopic.php?f=16&t=31107
I want to double check everything.
I got myself a replacement BP50NB40, and I am on the Mac. The drive is recognized correctly:
Seen from the command line
Are these the steps I should follow:
Anything else that I need to worry about? Is this encrypted?
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: <snip>
Firmware date: 2121-07-08 16:03
Harware support: Yes
Firmware support: No
Firmware version: 1.03
$ ./makemkvcon f -l
Found 1 drives(s)
00: /IOBDServices/6AA4CD8F
HL-DT-ST_BD-RE_BP50NB40_1.03_xxxxxxx_yyyyyy
$ ./makemkvcon f -d /IOBDServices/6AA4CD8F -f ~/Downloads/sdf.bin rawflash -i ~/Downloads/The\ all\ you\ need\ firmware\ pack/LG\ slim\ BP50NB40-NB50/HL-DT-ST-BD-RE_BP50NB40-NB50-1.03-NM00800-212005070917.bin
stikves
Update: Was finally able to replace the firmware on my BP50NB40
Followed the viewtopic.php?f=16&t=22896&start=705 on my older PC.
Unfortunately the UI is extremely confusing. The "recover" has the pull down clicked twice, first for the previous BIOS and then the new one. No wonder this thing did not work on the first try. (Seeing many others have the same issue, I have a minor sense of relief for not being the only one).
Anyway, if I could, I would recommend changing the UI to two separate pull downs on the recovery option. It will solve a lot of headache for a lot of people. Nevertheless thanks for the software.
eksine
It probably did have a blu ray disc in it, I can try again if this drive fails and I have to buy another one. What I ended up doing is paying $25 to billycar. he did great work making the 3.10 firmware to flash on my drive, he's fast tood00zah wrote: Wed May 24, 2023 1:51 pmIF this post is any indication, remove the disc from your drive. MUST be empty to flash.eksine wrote: Wed May 24, 2023 7:08 am I bought an asus bw-16d1ht , was able to successfully flash it to 3.10 MK, however it started producing read erros on blu-rays and a TON of errors reading DVD's, so I ordered a new drive on amazon like I did before however it is now made in January 2023 with firmware 3.11. I tried to flash it to 3.10 MK but it gives the error code 0xff056103, I cannot find any answers on here and I am completely lost. I am using the newest SDFtool flasher 1.3.5, there is no ENC checkbox, what do I do? also READ does not work on this drive, it is only able to dump the user files which is worthless
carpler
Hello everyone!
I am looking for a new blu-ray burner.
My previous model (a Pioneer from several years ago) suddenly 'died' despite very little use.
Despite having read several posts here on the forum, it's not clear to me which model to choose.
I'm interested in a 5.25 internal drive that is of decent quality in both read and write and that is as durable as possible.
LG models appear often, but I understand that they have reliability problems. I ask: is this the case for all models, or can some be considered?
I see that the BP50NB40 is often recommended, but is it really preferable to a 5.25 model?
Thank you to anyone who wants to answer me.
Moonlight4623
Hello. Having a hard time understanding the main page. I am looking to get a drive for UHD and the bottom section from what I understand seems compatible out of the box. The top section looks like we have to follow a update process to flash them correctly. Needing an external drive and the BP60NB10 doesn't seem like a bad price. Is it still currently flashable or are some of these now shipping with encrypted firmware preventing it?
