Panasonic 820 BD XL
Tomas
Panasonic 820 BD XL
Post by Tomas » Mon May 29, 2023 8:09 pm
I'll try to ask here. Has anyone tried playing a burned BDXL disc on a Panasonic 820 to see if it works. Thank you
Re: Panasonic 820 BD XL
Post by Coopervid » Mon May 29, 2023 8:34 pm
Forget to burn discs as it is too expensive compared to hard disk backup. The only player was the Panasonic UB-900 that could play BDR100 discs..
BonJavi
Post by BonJavi » Sun Jun 18, 2023 3:40 am
Hello.
Well, there are people who really like to record in physical format. If you are looking for life, it is not as expensive as it seems at first.
The UB-900 doesn't have Dolby Vision, so it's a half-baked option.
I'll tell you which player does play BDXL, UB450. Strangely, it plays >66GB but not <66GB. But it has an easy solution. You fill it with a file of the size you need to make it >66GB.
The UB450 has Dolby Vision and covers all the Bluray ranges. BD25GB, BD50GB, BDXL.
All the best.
