#8341 Post by MartyMcNuts » Sat May 27, 2023 7:38 am
So does anyone know what DV profiles the TCL C835 Google TV can play??
I have tried a DV profile 7 MKV created using MakeMKV and a DV profile 8 MKV using the script from @RESET_9999. I tried both MKV's in the TV's internal player, also in Kodi installed on the TV and also my HTPC running LibreELEC (which I already knew wouldn't work).
All playing options I tried show both MKV files as HDR10.
Any ideas?
#8342 Post by RESET_9999 » Sat May 27, 2023 2:17 pm
Any ideas?
Did you try the TS/M2TS container?
https://github.com/justdan96/tsMuxer/releases
#8343 Post by MartyMcNuts » Sat May 27, 2023 9:38 pm
Any ideas?
Not yet but I will. Are there any issues affecting playback with either container? Which is the preferred container?
Oh yeah, I am streaming the files from my NAS if that makes any difference.
#8344 Post by RESET_9999 » Sat May 27, 2023 11:58 pm
I dont know about TCL TVs but TS has better DV support on devices usually.
valington
#8345 Post by valington » Mon May 29, 2023 4:38 pm
Can you pm the RPUs to me as well ? Thank you RESET for everything
#8346 Post by RESET_9999 » Mon May 29, 2023 4:55 pm
Done.
#8347 Post by RESET_9999 » Mon May 29, 2023 4:59 pm
I dont know if you guys heard but @DMDreview did a great video showing that some Android boxes are actually doing fake TV-LED rgb tunneling (the player still does the rpu processing).
It also explains why many devices have different L1/L2 responses. Happy to confirm that the X700 and x800m2 don't have this problem.
https://www.youtube.com/watch?v=TO9uwkjTXbQ
The video is very technical so I made a quick example easy to understand:
https://www.youtube.com/watch?v=z8sgHR78Rdw
#8348 Post by MartyMcNuts » Tue May 30, 2023 9:50 am
So after a bit of testing, the TS seems to work best on the TCL 8-series TV’s player. DV works good with profile 8. With Kodi on the TV, only MP4’s show DV. I’ll stick with the TS as the audio is better.
My current (8 year old receiver) only has ARC so I’m only getting DD+ instead of ATMOS but only for DV movies. Everything else I watch through my HTPC so I can get ATMOS and DTS:X audio. The TV does have EARC so I’ll have to look at upgrading my receiver sooner rather than later then I can have DV and HD audio.
#8349 Post by RESET_9999 » Tue May 30, 2023 12:07 pm
good to know.
Did you try Profile 7 fel? I read the TCL has the same chip as the oppo players.
#8350 Post by MartyMcNuts » Tue May 30, 2023 12:50 pm
good to know.
I did try profile 7 TS. It did work but was a bit glitchy. Not sure if was MEL or FEL. I was using Top Gun Maverick as my test movie.
#8351 Post by MartyMcNuts » Wed May 31, 2023 2:57 am
Hey @RESET_9999,
How to extract the RPU when the movie contains multiple m2ts files? Using 2-2 do I have to do each m2ts file separately? Is there an option to add multiple m2ts's at once or merge them into one file for processing? I couldn't find one.
#8352 Post by RESET_9999 » Wed May 31, 2023 10:56 am
You have to merge them first with tsmuxer, makemkv or dgdemux
#8353 Post by MartyMcNuts » Wed May 31, 2023 11:04 am
Ah, yes. Easy peasy.
valington
#8354 Post by valington » Wed May 31, 2023 12:52 pm
Hi my question is not about dv but RARBG tracker is down where we could get dolby vision torents now may be you know or maybe we could download it from you RESET if it s possible?
#8355 Post by RESET_9999 » Wed May 31, 2023 1:00 pm
try to get in private trackers. The most popular(TL and IPT) one accepts a donation to get in.
