Divergent Series
todd3835
Divergent Series
Post by todd3835 »
Fairly new to ripping. I've done 70 or so movies in the last few weeks since getting my drive (LG WP50NB40). I had Billy do a remote unlock (he was awesome!).
Having some problems with the Divergent Series. The first movie ripped. Insurgent and Allegiant struggle to play even in PowerDVD and only work part of the time. Does anyone know some tricks to get them to read? Got the 3 pack on Amazon.
Re: Divergent Series
Divergent uses copy protection involving multiple incompatible copies of the video. Did you extract the correct title?
Last time I tried it, the DVD had over a dozen possible titles. The BD version had several dozen. Unless you pick the correct title, scenes jump all over the place.
todd3835
Post by todd3835 »
I tried the title listed in the forums here, and there's no errors, it just says it failed.
Honestly, half the times I try with even just PowerDVD to play it, it doesn't want to play and the drive sounds like it's choking. It *only* does that on the Divergent discs. I've ripped over 70 other movies without issues.
