VLC Blu-Ray Menus Not Working
Apollo11
Post by Apollo11 »
I'm having trouble getting VLC to play my UHD discs with the menu despite having the JDK SE version 20.0.1 installed and the JAVA_HOME path variable set:
I can compile and run Java code in my IDE so there's no technical issues on that end. What I don't understand is why VLC isn't seeing my Java install and showing me the disc's menu(s).
The VLC error:
I've also included the log file below:
https://drive.google.com/file/d/1Hp0_Kw ... sp=sharing
EDIT 0: Should I enable a more detailed logging level and try again?
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
Apollo11
Re: VLC Blu-Ray Menus Not Working
Post by Apollo11 »
I have now tested it by removing the JAVA_HOME variable and now VLC can't find any Java installation. I think this confirms that it's something with VLC since the log file keeps complaining about a "stale plugins cache" etc.
Could that be something?
PC:
use 64bit vlc and java
Apollo11
Post by Apollo11 »
Billycar11 wrote: Sat Jun 03, 2023 9:56 am use 64bit vlc and java
Which is what I’m doing.
If VLC were 32-bit it would shows as such in Task Manager in Windows 10 which it does not do. My Java version is 64-bit and is as stated in OP OpenJDK 20.0.1.
PC:
Try having both 32 and 64 bit java
Apollo11
Post by Apollo11 »
Billycar11 wrote: Sat Jun 03, 2023 12:42 pm Try having both 32 and 64 bit java
How do I make sure it doesn't interfere with my 64-bit install which I use for development purposes?
PC:
