AV Sync Issues for "The Martian Extended Edition" UHD Disc
Apollo11
Post by Apollo11 »
I'm in the process of ripping "The Martian Extended Edition" UHD disc and am getting several "AV sync issue in stream" messages. Is this something to worry about for the final result?
The resultant file plays nice in VLC; my concern is that the messages could be symptom of something else that may affect future rips.
This is my first rip from a UHD disc which is why I am asking.
The messages are below:
MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Backing up disc into folder "D:/The Martian Extended Edition (2015)/THE MARTIAN EXTENDED EDITION"
Downloading latest HK to C:\Users\alexl/.MakeMKV ...
Backup done
Opening files on harddrive at D:/The Martian Extended Edition (2015)/THE MARTIAN EXTENDED EDITION
File 00020.mpls was added as title #0
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00604.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00605.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00606.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00607.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00608.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00609.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00610.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00611.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00612.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00613.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #1
File 00801.mpls was added as title #2
Title #00000.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.m2ts was added as title #3
Title #00101.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00103.m2ts was added as title #4
Title #00104.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00111.m2ts was added as title #5
File 00112.m2ts was added as title #6
Title #00113.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00114.m2ts was added as title #7
File 00115.m2ts was added as title #8
Title #00117.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 9 titles into directory D:/The Martian Extended Edition (2015)
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t00.mkv' (title #1)
AV sync issue in stream 2 at 0:01:10.278 with duration of 25.458ms : encountered overlapping frame, audio skew is +25.458ms
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t01.mkv' (title #2)
AV sync issue in stream 1 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
AV sync issue in stream 2 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
AV sync issue in stream 2 at 0:00:23.231 with duration of 32.313ms : encountered overlapping frame, audio skew is +32.98ms
AV sync issue in stream 2 at 0:00:23.264 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.98ms
AV sync issue in stream 2 at 0:18:12.048 with duration of 14.505ms : encountered overlapping frame, audio skew is +15.486ms
AV sync issue in stream 3,4,5,6 at 0:18:12.049 with duration of 14.25ms : encountered overlapping frame, audio skew is +14.708ms
AV sync issue in stream 2 at 0:19:42.055 with duration of 9.327ms : encountered overlapping frame, audio skew is +24.813ms
AV sync issue in stream 3,4,5,6 at 0:19:42.055 with duration of 9.416ms : encountered overlapping frame, audio skew is +24.125ms
AV sync issue in stream 2 at 0:20:22.971 with duration of 12.169ms : encountered overlapping frame, audio skew is +36.983ms
AV sync issue in stream 2 at 0:20:23.008 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.983ms
AV sync issue in stream 3,4,5,6 at 0:20:22.971 with duration of 12.125ms : encountered overlapping frame, audio skew is +36.25ms
AV sync issue in stream 3,4,5,6 at 0:20:23.008 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 2 at 0:20:55.503 with duration of 11.5ms : encountered overlapping frame, audio skew is +16.483ms
AV sync issue in stream 3,4,5,6 at 0:20:55.504 with duration of 11.5ms : encountered overlapping frame, audio skew is +15.75ms
AV sync issue in stream 2 at 0:35:57.154 with duration of 13.183ms : encountered overlapping frame, audio skew is +29.666ms
AV sync issue in stream 3,4,5,6 at 0:35:57.155 with duration of 13.25ms : encountered overlapping frame, audio skew is +29ms
AV sync issue in stream 2 at 0:37:08.934 with duration of 27.98ms : encountered overlapping frame, audio skew is +57.647ms
AV sync issue in stream 2 at 0:37:08.992 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +25.647ms
AV sync issue in stream 3,4,5,6 at 0:37:08.935 with duration of 27.958ms : encountered overlapping frame, audio skew is +56.958ms
AV sync issue in stream 3,4,5,6 at 0:37:08.992 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.958ms
AV sync issue in stream 2 at 0:39:13.434 with duration of 12.002ms : encountered overlapping frame, audio skew is +37.65ms
AV sync issue in stream 2 at 0:39:13.472 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.65ms
AV sync issue in stream 3,4,5,6 at 0:39:13.434 with duration of 12.625ms : encountered overlapping frame, audio skew is +37.583ms
AV sync issue in stream 3,4,5,6 at 0:39:13.472 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.583ms
AV sync issue in stream 2 at 0:39:43.130 with duration of 32.166ms : encountered overlapping frame, audio skew is +37.816ms
AV sync issue in stream 2 at 0:39:43.168 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.816ms
AV sync issue in stream 3,4,5,6 at 0:39:43.130 with duration of 31.666ms : encountered overlapping frame, audio skew is +37.25ms
AV sync issue in stream 3,4,5,6 at 0:39:43.168 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.25ms
AV sync issue in stream 2 at 0:47:51.034 with duration of 31.85ms : encountered overlapping frame, audio skew is +37.666ms
AV sync issue in stream 2 at 0:47:51.072 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.666ms
AV sync issue in stream 3,4,5,6 at 0:47:51.034 with duration of 31.916ms : encountered overlapping frame, audio skew is +37.166ms
AV sync issue in stream 3,4,5,6 at 0:47:51.072 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.166ms
AV sync issue in stream 2 at 0:48:33.368 with duration of 1.819ms : encountered overlapping frame, audio skew is +7.486ms
AV sync issue in stream 3,4,5,6 at 0:48:33.368 with duration of 2.041ms : encountered overlapping frame, audio skew is +7.208ms
AV sync issue in stream 2 at 0:56:15.746 with duration of 21.661ms : encountered overlapping frame, audio skew is +29.147ms
AV sync issue in stream 3,4,5,6 at 0:56:15.747 with duration of 21.416ms : encountered overlapping frame, audio skew is +28.625ms
AV sync issue in stream 2 at 0:56:41.731 with duration of 31.852ms : encountered overlapping frame, audio skew is +61ms
AV sync issue in stream 2 at 0:56:41.792 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +29ms
AV sync issue in stream 3,4,5,6 at 0:56:41.731 with duration of 31.708ms : encountered overlapping frame, audio skew is +60.333ms
AV sync issue in stream 3,4,5,6 at 0:56:41.792 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +28.333ms
AV sync issue in stream 2 at 1:11:08.263 with duration of 27.5ms : encountered overlapping frame, audio skew is +56.5ms
AV sync issue in stream 2 at 1:11:08.320 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.5ms
AV sync issue in stream 3,4,5,6 at 1:11:08.264 with duration of 27.666ms : encountered overlapping frame, audio skew is +56ms
AV sync issue in stream 3,4,5,6 at 1:11:08.320 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24ms
AV sync issue in stream 2 at 1:11:43.006 with duration of 8.647ms : encountered overlapping frame, audio skew is +33.147ms
AV sync issue in stream 2 at 1:11:43.040 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +1.147ms
AV sync issue in stream 3,4,5,6 at 1:11:43.007 with duration of 8.958ms : encountered overlapping frame, audio skew is +32.958ms
AV sync issue in stream 3,4,5,6 at 1:11:43.040 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +0.958ms
AV sync issue in stream 2 at 1:13:32.157 with duration of 1.169ms : encountered overlapping frame, audio skew is +2.316ms
AV sync issue in stream 3,4,5,6 at 1:13:32.157 with duration of 1.291ms : encountered overlapping frame, audio skew is +2.25ms
AV sync issue in stream 2 at 1:13:59.434 with duration of 19.35ms : encountered overlapping frame, audio skew is +21.666ms
AV sync issue in stream 3,4,5,6 at 1:13:59.435 with duration of 18.75ms : encountered overlapping frame, audio skew is +21ms
AV sync issue in stream 2 at 1:14:46.189 with duration of 28.98ms : encountered overlapping frame, audio skew is +50.647ms
AV sync issue in stream 2 at 1:14:46.240 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +18.647ms
AV sync issue in stream 3,4,5,6 at 1:14:46.190 with duration of 28.958ms : encountered overlapping frame, audio skew is +49.958ms
AV sync issue in stream 3,4,5,6 at 1:14:46.240 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +17.958ms
AV sync issue in stream 2 at 1:16:03.391 with duration of 13.519ms : encountered overlapping frame, audio skew is +32.166ms
AV sync issue in stream 3,4,5,6 at 1:16:03.392 with duration of 13.875ms : encountered overlapping frame, audio skew is +31.833ms
AV sync issue in stream 2 at 1:22:52.466 with duration of 13ms : encountered overlapping frame, audio skew is +45.166ms
AV sync issue in stream 2 at 1:22:52.512 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.166ms
AV sync issue in stream 3,4,5,6 at 1:22:52.467 with duration of 12.666ms : encountered overlapping frame, audio skew is +44.5ms
AV sync issue in stream 3,4,5,6 at 1:22:52.512 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +12.5ms
AV sync issue in stream 2 at 1:27:15.354 with duration of 24.486ms : encountered overlapping frame, audio skew is +37.652ms
AV sync issue in stream 2 at 1:27:15.392 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +5.652ms
AV sync issue in stream 3,4,5,6 at 1:27:15.355 with duration of 24.375ms : encountered overlapping frame, audio skew is +36.875ms
AV sync issue in stream 3,4,5,6 at 1:27:15.392 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.875ms
AV sync issue in stream 2 at 1:30:39.183 with duration of 10.83ms : encountered overlapping frame, audio skew is +16.483ms
AV sync issue in stream 3,4,5,6 at 1:30:39.183 with duration of 11.375ms : encountered overlapping frame, audio skew is +16.25ms
AV sync issue in stream 2 at 1:30:59.996 with duration of 19.497ms : encountered overlapping frame, audio skew is +35.98ms
AV sync issue in stream 2 at 1:31:00.032 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.98ms
AV sync issue in stream 3,4,5,6 at 1:30:59.996 with duration of 19.541ms : encountered overlapping frame, audio skew is +35.791ms
AV sync issue in stream 3,4,5,6 at 1:31:00.032 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.791ms
AV sync issue in stream 2 at 1:46:13.575 with duration of 20.833ms : encountered overlapping frame, audio skew is +24.813ms
AV sync issue in stream 3,4,5,6 at 1:46:13.575 with duration of 20.666ms : encountered overlapping frame, audio skew is +24.458ms
AV sync issue in stream 2 at 1:46:51.279 with duration of 23.833ms : encountered overlapping frame, audio skew is +48.647ms
AV sync issue in stream 2 at 1:46:51.328 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +16.647ms
AV sync issue in stream 3,4,5,6 at 1:46:51.279 with duration of 23.666ms : encountered overlapping frame, audio skew is +48.125ms
AV sync issue in stream 3,4,5,6 at 1:46:51.328 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +16.125ms
AV sync issue in stream 2 at 1:49:29.604 with duration of 11ms : encountered overlapping frame, audio skew is +27.647ms
AV sync issue in stream 3,4,5,6 at 1:49:29.604 with duration of 11.166ms : encountered overlapping frame, audio skew is +27.291ms
AV sync issue in stream 2 at 1:51:39.984 with duration of 20.005ms : encountered overlapping frame, audio skew is +47.652ms
AV sync issue in stream 2 at 1:51:40.032 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.652ms
AV sync issue in stream 3,4,5,6 at 1:51:39.984 with duration of 19.75ms : encountered overlapping frame, audio skew is +47.041ms
AV sync issue in stream 3,4,5,6 at 1:51:40.032 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.041ms
AV sync issue in stream 8 at 0:00:00 : Forced subtitles track #8 turned out to be empty and was removed from output file
AV sync issue in stream 14 at 0:00:00 : Forced subtitles track #14 turned out to be empty and was removed from output file
AV sync issue in stream 16 at 0:00:00 : Forced subtitles track #16 turned out to be empty and was removed from output file
AV sync issue in stream 18 at 0:00:00 : Forced subtitles track #18 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t02.mkv' (title #3)
AV sync issue in stream 3,4,5 at 0:18:12.049 with duration of 14.25ms : encountered overlapping frame, audio skew is +14.708ms
AV sync issue in stream 2 at 0:20:03.409 with duration of 30.661ms : encountered overlapping frame, audio skew is +46.147ms
AV sync issue in stream 2 at 0:20:03.456 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +14.147ms
AV sync issue in stream 3,4,5 at 0:20:03.410 with duration of 30.75ms : encountered overlapping frame, audio skew is +45.458ms
AV sync issue in stream 3,4,5 at 0:20:03.456 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +13.458ms
AV sync issue in stream 1 at 0:20:03.409 with duration of 1.161ms : encountered overlapping frame, audio skew is +1.813ms
AV sync issue in stream 1 at 0:20:03.410 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.98ms
AV sync issue in stream 2 at 0:20:44.326 with duration of 11.836ms : encountered overlapping frame, audio skew is +25.983ms
AV sync issue in stream 3,4,5 at 0:20:44.326 with duration of 12.125ms : encountered overlapping frame, audio skew is +25.583ms
AV sync issue in stream 1 at 0:20:44.325 with duration of 0.502ms : encountered overlapping frame, audio skew is +1.483ms
AV sync issue in stream 2 at 0:21:19.944 with duration of 29.416ms : encountered overlapping frame, audio skew is +55.4ms
AV sync issue in stream 2 at 0:21:20 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +23.4ms
AV sync issue in stream 3,4,5 at 0:21:19.945 with duration of 29.083ms : encountered overlapping frame, audio skew is +54.666ms
AV sync issue in stream 3,4,5 at 0:21:20 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +22.666ms
AV sync issue in stream 1 at 0:21:19.943 with duration of 1.416ms : encountered overlapping frame, audio skew is +2.9ms
AV sync issue in stream 1 at 0:21:19.946 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +1.233ms
AV sync issue in stream 2 at 0:36:21.596 with duration of 12.583ms : encountered overlapping frame, audio skew is +35.983ms
AV sync issue in stream 2 at 0:36:21.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.983ms
AV sync issue in stream 3,4,5 at 0:36:21.596 with duration of 13.25ms : encountered overlapping frame, audio skew is +35.916ms
AV sync issue in stream 3,4,5 at 0:36:21.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +3.916ms
AV sync issue in stream 1 at 0:36:21.595 with duration of 0.25ms : encountered overlapping frame, audio skew is +1.483ms
AV sync issue in stream 2 at 0:38:03.655 with duration of 20.33ms : encountered overlapping frame, audio skew is +24.313ms
AV sync issue in stream 3,4,5 at 0:38:03.656 with duration of 19.708ms : encountered overlapping frame, audio skew is +23.625ms
AV sync issue in stream 1 at 0:38:03.654 with duration of 1.163ms : encountered overlapping frame, audio skew is +2.647ms
AV sync issue in stream 1 at 0:38:03.657 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.98ms
AV sync issue in stream 2 at 0:40:08.155 with duration of 12.502ms : encountered overlapping frame, audio skew is +36.816ms
AV sync issue in stream 2 at 0:40:08.192 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.816ms
AV sync issue in stream 3,4,5 at 0:40:08.155 with duration of 12.625ms : encountered overlapping frame, audio skew is +36.25ms
AV sync issue in stream 3,4,5 at 0:40:08.192 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +4.25ms
AV sync issue in stream 1 at 0:40:08.154 with duration of 1.336ms : encountered overlapping frame, audio skew is +2.316ms
AV sync issue in stream 1 at 0:40:08.156 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.65ms
AV sync issue in stream 2 at 0:41:09.674 with duration of 16.208ms : encountered overlapping frame, audio skew is +21.025ms
AV sync issue in stream 3,4,5 at 0:41:09.675 with duration of 16.208ms : encountered overlapping frame, audio skew is +20.458ms
AV sync issue in stream 1 at 0:41:09.674 with duration of 1.041ms : encountered overlapping frame, audio skew is +1.691ms
AV sync issue in stream 1 at 0:41:09.675 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.858ms
AV sync issue in stream 2 at 0:49:17.579 with duration of 31.627ms : encountered overlapping frame, audio skew is +52.652ms
AV sync issue in stream 2 at 0:49:17.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +20.652ms
AV sync issue in stream 3,4,5 at 0:49:17.579 with duration of 31.916ms : encountered overlapping frame, audio skew is +52.375ms
AV sync issue in stream 3,4,5 at 0:49:17.632 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +20.375ms
AV sync issue in stream 1 at 0:49:17.578 with duration of 0.627ms : encountered overlapping frame, audio skew is +1.486ms
AV sync issue in stream 1 at 0:49:17.580 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.652ms
AV sync issue in stream 2 at 0:50:21.017 with duration of 17.625ms : encountered overlapping frame, audio skew is +38.277ms
AV sync issue in stream 2 at 0:50:21.056 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +6.277ms
AV sync issue in stream 3,4,5 at 0:50:21.018 with duration of 17.625ms : encountered overlapping frame, audio skew is +38ms
AV sync issue in stream 3,4,5 at 0:50:21.056 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +6ms
AV sync issue in stream 1 at 0:50:21.016 with duration of 0.791ms : encountered overlapping frame, audio skew is +1.444ms
AV sync issue in stream 2 at 0:58:03.396 with duration of 21.705ms : encountered overlapping frame, audio skew is +27.983ms
AV sync issue in stream 3,4,5 at 0:58:03.396 with duration of 21.416ms : encountered overlapping frame, audio skew is +27.416ms
AV sync issue in stream 1 at 0:58:03.395 with duration of 0.872ms : encountered overlapping frame, audio skew is +2.316ms
AV sync issue in stream 1 at 0:58:03.397 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.65ms
AV sync issue in stream 2 at 0:58:42.852 with duration of 32.016ms : encountered overlapping frame, audio skew is +60ms
AV sync issue in stream 2 at 0:58:42.912 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +28ms
AV sync issue in stream 3,4,5 at 0:58:42.852 with duration of 31.916ms : encountered overlapping frame, audio skew is +59.333ms
AV sync issue in stream 3,4,5 at 0:58:42.912 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +27.333ms
AV sync issue in stream 1 at 0:58:42.852 with duration of 0.683ms : encountered overlapping frame, audio skew is +1.333ms
AV sync issue in stream 2 at 1:13:09.384 with duration of 27.666ms : encountered overlapping frame, audio skew is +55.666ms
AV sync issue in stream 2 at 1:13:09.440 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +23.666ms
AV sync issue in stream 3,4,5 at 1:13:09.385 with duration of 27.666ms : encountered overlapping frame, audio skew is +55ms
AV sync issue in stream 3,4,5 at 1:13:09.440 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +23ms
AV sync issue in stream 1 at 1:13:09.383 with duration of 1ms : encountered overlapping frame, audio skew is +2.333ms
AV sync issue in stream 1 at 1:13:09.385 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 2 at 1:14:16.201 with duration of 30.772ms : encountered overlapping frame, audio skew is +54.438ms
AV sync issue in stream 2 at 1:14:16.256 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +22.438ms
AV sync issue in stream 3,4,5 at 1:14:16.201 with duration of 31.25ms : encountered overlapping frame, audio skew is +54.25ms
AV sync issue in stream 3,4,5 at 1:14:16.256 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +22.25ms
AV sync issue in stream 2 at 1:16:05.351 with duration of 1.713ms : encountered overlapping frame, audio skew is +24.152ms
AV sync issue in stream 3,4,5 at 1:16:05.352 with duration of 1.291ms : encountered overlapping frame, audio skew is +23.541ms
AV sync issue in stream 1 at 1:16:05.351 with duration of 1.38ms : encountered overlapping frame, audio skew is +2.319ms
AV sync issue in stream 1 at 1:16:05.353 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +0.652ms
AV sync issue in stream 2 at 1:16:37.383 with duration of 32.055ms : encountered overlapping frame, audio skew is +56.208ms
AV sync issue in stream 2 at 1:16:37.440 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +24.208ms
AV sync issue in stream 1 at 1:16:37.382 with duration of 1.388ms : encountered overlapping frame, audio skew is +2.041ms
AV sync issue in stream 1 at 1:16:37.385 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +1.208ms
AV sync issue in stream 2 at 1:17:24.139 with duration of 28.458ms : encountered overlapping frame, audio skew is +52.666ms
AV sync issue in stream 2 at 1:17:24.192 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +20.666ms
AV sync issue in stream 3,4,5 at 1:17:24.139 with duration of 28.958ms : encountered overlapping frame, audio skew is +52.5ms
AV sync issue in stream 3,4,5 at 1:17:24.192 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +20.5ms
AV sync issue in stream 1 at 1:17:24.138 with duration of 0.291ms : encountered overlapping frame, audio skew is +1.5ms
AV sync issue in stream 1 at 1:17:24.140 with duration of 0.833ms : 1 frame(s) dropped to reduce audio skew to +0.666ms
AV sync issue in stream 2 at 1:19:30.640 with duration of 26.791ms : encountered overlapping frame, audio skew is +47.458ms
AV sync issue in stream 2 at 1:19:30.688 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.458ms
AV sync issue in stream 3,4,5 at 1:19:30.640 with duration of 26.625ms : encountered overlapping frame, audio skew is +47.125ms
AV sync issue in stream 3,4,5 at 1:19:30.688 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +15.125ms
AV sync issue in stream 1 at 1:19:30.640 with duration of 0.458ms : encountered overlapping frame, audio skew is +1.125ms
AV sync issue in stream 2 at 1:26:19.716 with duration of 12.522ms : encountered overlapping frame, audio skew is +27.98ms
AV sync issue in stream 3,4,5 at 1:26:19.716 with duration of 12.666ms : encountered overlapping frame, audio skew is +27.791ms
AV sync issue in stream 1 at 1:26:19.715 with duration of 0.355ms : encountered overlapping frame, audio skew is +1.48ms
AV sync issue in stream 2 at 1:33:57.047 with duration of 12.713ms : encountered overlapping frame, audio skew is +40.694ms
AV sync issue in stream 2 at 1:33:57.088 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +8.694ms
AV sync issue in stream 3,4,5 at 1:33:57.048 with duration of 12.125ms : encountered overlapping frame, audio skew is +39.916ms
AV sync issue in stream 3,4,5 at 1:33:57.088 with duration of 32ms : 1 frame(s) dropped to reduce audio skew to +7.916ms
AV sync issue in stream 1 at 1:33:57.046 with duration of 1.213ms : encountered overlapping frame, audio skew is +2.694ms
AV sync issue in stream 1 at 1:33:57.049 with duration of 1.666ms : 2 frame(s) dropped to reduce audio skew to +1.027ms
AV sync issue in stream 2 at 1:37:20.876 with duration of 11.286ms : encountered overlapping frame, audio skew is +19.98ms
AV sync issue in stream 3,4,5 at 1:37:20.876 with duration of 11.375ms : encountered overlapping frame, audio skew is +19.291ms
Too many AV synchronization issues in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t02.mkv' (title #3) , future messages will be printed only to log file
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t03.mkv' (title #4)
AV sync issue in stream 9 at 0:00:00 : Forced subtitles track #9 turned out to be empty and was removed from output file
AV sync issue in stream 11 at 0:00:00 : Forced subtitles track #11 turned out to be empty and was removed from output file
AV sync issue in stream 13 at 0:00:00 : Forced subtitles track #13 turned out to be empty and was removed from output file
AV sync issue in stream 15 at 0:00:00 : Forced subtitles track #15 turned out to be empty and was removed from output file
AV sync issue in stream 17 at 0:00:00 : Forced subtitles track #17 turned out to be empty and was removed from output file
AV sync issue in stream 19 at 0:00:00 : Forced subtitles track #19 turned out to be empty and was removed from output file
AV sync issue in stream 21 at 0:00:00 : Forced subtitles track #21 turned out to be empty and was removed from output file
AV sync issue in stream 23 at 0:00:00 : Forced subtitles track #23 turned out to be empty and was removed from output file
AV sync issue in stream 25 at 0:00:00 : Forced subtitles track #25 turned out to be empty and was removed from output file
AV sync issue in stream 27 at 0:00:00 : Forced subtitles track #27 turned out to be empty and was removed from output file
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t04.mkv' (title #5)
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t05.mkv' (title #6)
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t06.mkv' (title #7)
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t07.mkv' (title #8)
AV synchronization issues were found in file 'D:/The Martian Extended Edition (2015)/The Martian - Extended Edition_t08.mkv' (title #9)
9 titles saved
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
tresnugget
Re: AV Sync Issues for "The Martian Extended Edition" UHD Disc
Post by tresnugget »
I believe it’s normal with the extended edition. I just ripped the same discs not long ago and ripped only the extended edition and got the same messages. I have seen others mentioning audio sync issues in the added scenes. I haven’t watched the movie to confirm but I did skip around and didn’t notice anything but there’s a solid chance I didn’t land on one of the new scenes.
It is mostly an informational message that comes from the seamless branching used on the disc. It shouldn't be something to worry about. See my post below for a longer explanation.
viewtopic.php?f=12&t=22903&p=94894#p94894
Apollo11
Post by Apollo11 »
dcoke22 wrote: Fri May 26, 2023 4:50 am It is mostly an informational message that comes from the seamless branching used on the disc. It shouldn't be something to worry about. See my post below for a longer explanation.
Fantastic; thanks for the explainer!
Now I’m just going to get the Blu-Ray menus working in VLC. I still have to set my JRE path in environment variables on Windows 10.
PC:
