failure to open Creed III 4K disc
BobRod49
#1 Post by BobRod49 » Wed May 24, 2023 7:26 pm
Hello! Just received the 4K version of Creed III. I tried to rip it using makemkv as I use for all my discs but my makemkv fails to open the disc. The exact message I get is:
"MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\User/.MakeMKV/MKB20_v77_Creed_III_417E.tgz
Failed to open disc"
I had no problems ripping the HD version included. The 4k disc plays fine in my OPPO digital player but the previous and latest versions of makemkv can't open the disk. Has anyone else had this issue?
BobRod49
Re: failure to open Creed III 4K disc
#2 Post by Woodstock » Wed May 24, 2023 8:55 pm
Have you submitted the file yet?
scm1031
#3 Post by scm1031 » Wed May 24, 2023 9:57 pm
dump files submitted earlier today. 4k Amazon disc
edwolfe3
#4 Post by edwolfe3 » Thu May 25, 2023 11:39 am
Another dump from Amazon purchased disk: unable to decrypt.
triplerinse
#5 Post by triplerinse » Fri May 26, 2023 8:08 pm
Anyone able to open move yet? Submitted on Tuesday. hash key still unkown.
tresnugget
#6 Post by tresnugget » Fri May 26, 2023 8:13 pm
Nope
triplerinse
#7 Post by triplerinse » Fri May 26, 2023 9:20 pm
i get that its a one man project. but would be nice to get it for the weekend
Stryker412
#8 Post by Stryker412 » Fri May 26, 2023 9:27 pm
The guy does have a life and you can always play the movie off the disc for now.
triplerinse
#9 Post by triplerinse » Fri May 26, 2023 9:35 pm
This is why I said. I get its a one man show.
tresnugget
#10 Post by tresnugget » Fri May 26, 2023 10:32 pm
My backup just decrypted
triplerinse
#11 Post by triplerinse » Fri May 26, 2023 11:17 pm
mine did as well thanks mike
mdeguzman
#12 Post by mdeguzman » Tue Jun 27, 2023 4:12 pm
what was the solution?
#13 Post by dcoke22 » Tue Jun 27, 2023 4:56 pm
The OP needed to submit the generated dump file to svq@makemkv.com. A key was eventually created and then everyone was able to download it and decrypt the disc.
The UHD FAQ has a more detailed explanation.
mdeguzman
#14 Post by mdeguzman » Mon Jul 03, 2023 6:46 pm
Thank you.
