failure to open Creed III 4K disc
Hello! Just received the 4K version of Creed III. I tried to rip it using makemkv as I use for all my discs but my makemkv fails to open the disc. The exact message I get is:
"MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\User/.MakeMKV/MKB20_v77_Creed_III_417E.tgz
Failed to open disc"
I had no problems ripping the HD version included. The 4k disc plays fine in my OPPO digital player but the previous and latest versions of makemkv can't open the disk. Has anyone else had this issue?
BobRod49
BobRod49
Re: failure to open Creed III 4K disc
Have you submitted the file yet?Saved AACS dump file as C:\Users\User/.MakeMKV/MKB20_v77_Creed_III_417E.tgz
dump files submitted earlier today. 4k Amazon disc
Another dump from Amazon purchased disk: unable to decrypt.
triplerinse
Anyone able to open move yet? Submitted on Tuesday. hash key still unkown.
tresnugget
Nopetriplerinse wrote: ↑Fri May 26, 2023 8:08 pmAnyone able to open move yet? Submitted on Tuesday. hash key still unkown.
triplerinse
i get that its a one man project. but would be nice to get it for the weekend
Stryker412
The guy does have a life and you can always play the movie off the disc for now.triplerinse wrote: ↑Fri May 26, 2023 9:20 pmi get that its a one man project. but would be nice to get it for the weekend
triplerinse
This is why I said. I get its a one man show.
tresnugget
My backup just decrypted
triplerinse
mine did as well thanks mike
what was the solution?
The OP needed to submit the generated dump file to svq@makemkv.com. A key was eventually created and then everyone was able to download it and decrypt the disc.
The UHD FAQ has a more detailed explanation.
Thank you.
