failure to open Creed III 4K disc
BobRod49
Post by BobRod49 »
Hello! Just received the 4K version of Creed III. I tried to rip it using makemkv as I use for all my discs but my makemkv fails to open the disc. The exact message I get is:
"MakeMKV v1.17.3 win(x64-release) started
Using LibreDrive mode (v06.3 id=64754CF46FCA)
Saved AACS dump file as C:\Users\User/.MakeMKV/MKB20_v77_Creed_III_417E.tgz
Failed to open disc"
I had no problems ripping the HD version included. The 4k disc plays fine in my OPPO digital player but the previous and latest versions of makemkv can't open the disk. Has anyone else had this issue?
BobRod49
Re: failure to open Creed III 4K disc
Have you submitted the file yet?
scm1031
Post by scm1031 »
dump files submitted earlier today. 4k Amazon disc
edwolfe3
Post by edwolfe3 »
Another dump from Amazon purchased disk: unable to decrypt.
triplerinse
Post by triplerinse »
Anyone able to open move yet? Submitted on Tuesday. hash key still unkown.
tresnugget
Post by tresnugget »
triplerinse wrote:
Fri May 26, 2023 8:08 pm
Nope
triplerinse
i get that its a one man project. but would be nice to get it for the weekend
Stryker412
Post by Stryker412 »
triplerinse wrote:
Fri May 26, 2023 9:20 pm
The guy does have a life and you can always play the movie off the disc for now.
triplerinse
This is why I said. I get its a one man show.
tresnugget
My backup just decrypted
triplerinse
mine did as well thanks mike
mdeguzman
Post by mdeguzman »
what was the solution?
mdeguzman wrote:
Tue Jun 27, 2023 4:12 pm
The OP needed to submit the generated dump file to svq@makemkv.com. A key was eventually created and then everyone was able to download it and decrypt the disc.
The UHD FAQ has a more detailed explanation.
mdeguzman
Post by mdeguzman »
Thank you.
