LG BP60NB10
ammy53
LG BP60NB10
Post by ammy53 »
Trying to figure out how to flash this drive. It says it is MT1959 and FW 1.02. What should I read as there are no GOOD guides anywhere. They are all convoluted. The videos don’t do a good job either. I have read through the forums, some say you have to downgrade some say your fine. Which is it? Is there a tool? Is it all through the command line? Any help here would be immensely appreciated.
Re: LG BP60NB10
ammy53 wrote: Sun May 21, 2023 8:27 pm Trying to figure out how to flash this drive. It says it is MT1959 and FW 1.02. What should I read as there are no GOOD guides anywhere. They are all convoluted. The videos don’t do a good job either. I have read through the forums, some say you have to downgrade some say your fine. Which is it? Is there a tool? Is it all through the command line? Any help here would be immensely appreciated.
ouch i though my guide is pretty good it says to flash your drive to bp60nb10 1.02mk with enc
Re: LG BP60NB10
On Windows there's the SDFtool. On Linux or Mac it is command line.
