DragonSlayer (1981){imdb=tt0082288} 4K dump files
pkmpkm
Post by pkmpkm »
Hello, I tried to add the tgz file [MKB20_v77_DRAGONSLAYER_CF36.tgz] here 5.1M (too big), then I tried max compression 7zip against the tar file, still too big (4.8M).. any other options to upload the dump file here for addition?
Kind Regards,
Patrick
Re: DragonSlayer (1981){imdb=tt0082288} 4K dump files
Your email program will not accept them? Posting them here delays processing; you're supposed to email them to svQ@makemkv.com for processing.
(address corrected)
pkmpkm
Post by pkmpkm »
Thank you Woodstock, Will do. Not sure how I missed that.
Patrick
Psychospark
Post by Psychospark »
Woodstock wrote:
Sat May 20, 2023 8:19 pm
Your email program will not accept them? Posting them here delays processing; you're supposed to email them to svc@makemkv.com for processing.
I just wanted to ask for clarification, is it "svc" or "svq"? Your sticky post here states "svq". Thanks
You are correct - SVQ@makemkv.com. I'll zap this post to correct it.
It was made at a time that I was about to go in hospital, so I'll use that excuse. :)
Psychospark
Okay, thank you.
