problem to start the programm
regurge
#1 Post by regurge » Thu Aug 06, 2009 5:42 pm
after the installtion of the latest version i tried to start the programm but i received a windows fault message:
"MakeMKV found a problem and will be closed"
Any ideas? .. i am using Win XP .. do i need some extra software to start the programm?
Re: problem to start the programm
#2 Post by mike admin » Fri Aug 07, 2009 8:53 am
No, it should just work without any additional software or drivers. And it should work on XP.
regurge
#3 Post by regurge » Fri Aug 07, 2009 9:29 am
the programm woks fine on my laptop but on my desktop pc i receive the windows fault message ... maybe there is a programm in the background which blocks "makemkv" but i dont find it :(
regurge
#4 Post by regurge » Fri Aug 07, 2009 9:59 am
i found the programm which blocked "makemkv" .. it was the driver from my wacom tablet;
C:\WINDOWS\system32\Tablet.exe
i closed the programm and "makemkv" started
adrian
#5 Post by adrian » Fri Aug 14, 2009 12:18 pm
I have a Wacom Bamboo A6, and I can confirm this problem.
When the memory resident tablet software is running MakeMKV crashes on startup. Closing the Pen_Tablet.exe process solves the problem.
This is with MakeMKV version 1.46 on Windows XP SP3, and Wacom drivers version 5.11-1 RC.
Bumgy
#6 Post by Bumgy » Mon Aug 17, 2009 10:25 am
Thanks for this solution! I have the same problem. I have to close my wacom software before i can run MakeMKV. Otherwise it crashes at startup.
#7 Post by mike admin » Sat Aug 22, 2009 10:11 am
Thanks for reporting. Is this software publically available? Where can we get a copy to reproduce the problem and do we really need a tablet for this? Also, what happens if you run "makemkvcon info disc:0" from a command line - does it crash?
adrian
#8 Post by adrian » Mon Aug 24, 2009 10:00 am
Hi Mike!
You can download the software at:
http://www.wacom.eu/index2.asp?pid=29&l ... uct=MTE450
I'm not sure it can be installed without a Tablet present, but I think so.
Running the command line gives me:
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
Current action: Scanning CD-ROM devices
Current progress - 0%  , Total progress - 0%
Current progress - 100%  , Total progress - 0%
Current progress - 100%  , Total progress - 100%
Current progress - 0%  , Total progress - 100%
005010:000000:0000 Failed to open disc
Total 0 titles
I didn't have any disc in the drive - but it didn't crash like the GUI does.
adrian
#9 Post by adrian » Sun Sep 27, 2009 5:32 pm
This problem still exists with MakeMKV 1.47 and the new Wacom 5.20-6a drivers. Are you devs able to reproduce it?
#10 Post by mike admin » Thu Oct 01, 2009 6:05 am
adrian wrote:This problem still exists with MakeMKV 1.47 and the new Wacom 5.20-6a drivers. Are you devs able to reproduce it?
Please try attached version and post the result here. In order to try it:
  • * locate MakeMKV installation directory
    * rename makemkv.exe to makemkv.old
    * extract makemkv.exe from attached archive and put into installation directory
    * launch MakeMKV and see if it works
Tense
#11 Post by Tense » Fri Oct 02, 2009 3:17 am
I signed up just to say thank you. This solved the problem. Works fine now. :D
adrian
#12 Post by adrian » Mon Oct 05, 2009 12:08 pm
I can confirm that this private build works fine.
Thanks Mike!
