Yes you can remove the DV metadata/layer with 6-1-2 but you will have to mux the new HEVC file to MKV yourself with mkvtoolnix.
So with Tool its possible to remove DV metadata , is there a way to convert that DV metadata to HDR10+ metadata ?RESET_9999 wrote: ↑Thu May 11, 2023 12:09 pmYes you can remove the DV metadata/layer with 6-1-2 but you will have to mux the new HEVC file to MKV yourself with mkvtoolnix.
@RESET_9999
Can you give me some guidance on DoViBaker?
Let's assume this is the starting script:
bl=DGSource("blclip.dgi")
el=DGSource("elclip.dgi")
DoViBaker(bl,el,rpu="RPU.bin")
If I recompress this with e.g. Handbrake, I get a 10 bit HEVC HDR10 stream containing the FEL data, to which I can add the RPU converted to Profile 8 with dovi_tool.
So why does DoViBaker need the RPU?
In this case, in which mode should the RPU be converted to P8 (preserving mapping or not)?
You use the original profile 7 RPU for DoViBaker.NiCE77 wrote: ↑Fri May 12, 2023 6:24 am@RESET_9999
And for the encode you convert to profile 8.1 (mode 2).
You have to be careful with DoViBaker as it outputs RGB by default, and a later conversion could make the colours wrong when encoding.
Thanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741quietvoid wrote: ↑Fri May 12, 2023 10:34 amYou use the original profile 7 RPU for DoViBaker.NiCE77 wrote: ↑Fri May 12, 2023 6:24 am@RESET_9999
So the result will not be good if we inject the RPU because double processing. But then I don't really understand what this tool is for?
Reinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.NiCE77 wrote: ↑Fri May 12, 2023 10:55 amThanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
As long as you don't tonemap using the trims in DoViBaker.
DoViBaker uses the mapping metadata and NLQ metadata to reconstruct the FEL image.
All this metadata is removed by profile 8.1 conversion (for FEL).
Many thanks!quietvoid wrote: ↑Fri May 12, 2023 11:03 amReinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.NiCE77 wrote: ↑Fri May 12, 2023 10:55 amThanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
What would be a good FFMPEG command line to create the new base layer with as close to lossless quality as possible? I am playing with two at the moment, but not sure if those are the best options if I want to focus on quality.quietvoid wrote: ↑Fri May 12, 2023 11:03 amReinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.NiCE77 wrote: ↑Fri May 12, 2023 10:55 amThanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
ffmpeg -i "example.avs" -c:v libaom-av1 -crf 23 -pix_fmt yuv444p12le av1_test.mkv --> AV1 output
ffmpeg -i "example.avs" -x265-params "hdr10-opt=1:chromaloc=2:range=limited:output-depth=10:profile=main10:level-idc=5.1:colorprim=bt2020:colormatrix=bt2020nc:transfer=smpte2084:hdr10=1:max-cll=0,0:master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" "out10.hevc"
If i convert a DV movie to mkv (using HandBrake or DVDFab, without DV, just normal HDR), and then put the movie in tsMuxer, add the DV video, and then create a Bluray folder or ISO, the DV works?
I don't know but you need to stick with HEVC if you want to reinject the RPU.danbez wrote: ↑Fri May 12, 2023 5:40 pmWhat would be a good FFMPEG command line to create the new base layer with as close to lossless quality as possible? I am playing with two at the moment, but not sure if those are the best options if I want to focus on quality.
If the device will play Profile 7 MEL, would there be an advantage to choosing mode 1 (converts the RPU to be MEL compatible)?quietvoid wrote: ↑Fri May 12, 2023 11:03 amReinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.NiCE77 wrote: ↑Fri May 12, 2023 10:55 amThanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
Will this also remove the mapping metadata and NLQ? If not, how will the end result still be good?
Another question:
Dune / Zidoo / Zappiti will also play the Profile 7 FEL files with the EL skipped, but I see RPU response in the test file (blinking colors). Is this also the wrong method used by these vendors?
Conversion to MEL doesn't remove anything.
So if the title is FEL the result can be wrong.
Probably.
It's only an issue when FEL has mapping metadata that affects the image a lot, because the intermediate image is not correct without the EL.
Roadwarrior980
Is the FEL issue with Saving Private Ryan limited to just the US release or does it impact all the other regions (like UK, Australia, Canada)? Curious if trying another disc from a different country would produce similar results
Thank you, can you give me some movie titles where FEL has mapping metadata?
