Asus BW-16D1X-U
Rebo0ot
Re: Asus BW-16D1X-U
Post by Rebo0ot »
Thanks - that makes sense. One more question. I noticed different files available.
HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010
DE_LG_WH16NS60_1.02_MK
DE_LG_WH16NS60_1.00
Which of the above would you recommend?
Re: Asus BW-16D1X-U
See guide
Rebo0ot
Re: Asus BW-16D1X-U
Post by Rebo0ot »
Thanks. I did some more reading as you suggested and finally updated both my external ASUS_BW-16D1X-U and
my internal LG BD-RE WH16NS40 to HL-DT-ST-BD-RE_WH16NS60-1.03. Both are working on 4k UHD media.
saturn2888
Re: Asus BW-16D1X-U
Post by saturn2888 »
I have 4 of these drives and flashed the to the `HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin` firmware version (the one for LG 5.25" drives).
This worked fine for most discs, but certain UHD discs seem to have trouble; showing CDB errors: "Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB'".
There could be a number of issues. I made sure to wipe each disc before reading them, but this isn't the same kind of error I see when ripping questionable DVDs, so I'm thinking something else went wrong.
And I get an error trying to write the ASUS firmware on the drives: 0xff05c103. So I'm not sure what to do now.
Exrill
Re: Asus BW-16D1X-U
Post by Exrill »
Hello i am new to this so sorry if stupid.
Just got myself a "ASUS BW-16D1X-U"
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Disc Information
Label: HARRY_POTTER_7_PART_1
Timestamp: 2011-02-25 21:33:08
Protection: AACS v19
Data capacity: 38.24 Gb
Disc type: BD-ROM
Number of layers: 2
However if i try to flash with SDFtool to "ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin" i get this error code: "0xff056103"
Re: Asus BW-16D1X-U
Exrill wrote:
Fri May 12, 2023 3:01 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Disc Information
Disc type: BD-ROM
Number of layers: 2
Try with enc
Exrill
Re: Asus BW-16D1X-U
Post by Exrill »
Billycar11 wrote:
Fri May 12, 2023 6:58 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Disc Information
Disc type: BD-ROM
Number of layers: 2
Try with enc
what is "enc"? :)
Re: Asus BW-16D1X-U
Exrill wrote:
Sun May 14, 2023 6:36 am
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Disc Information
Disc type: BD-ROM
Number of layers: 2
Try with enc
what is "enc"? :)
See guide it for encrypted fw
Backup2023
Re: Asus BW-16D1X-U
Post by Backup2023 »
Hello All,
Im very new to this community. I have read through a few select threads that are particular to my drive which is the external BW-16D1X-U. I have a few questions. I would like to flash my drive to a firmware that will make it capable of becoming a Libredrive/UHD but I am getting this message in the lower box of the MakeMKV app "Automatic SDF downloading is disabled or failed." I have Xfinity and I dont know how to fix this error in the Xfinity router as I do believe it is a DNS error. I have the "Enable Internet Acecss" in the pref/general selected. I have tried changing Windows to use the Google DNS 8.8.8.8/8.8.4.4 and it still gives me the error. Well anyway my question is. Can I still flash my drive with the SDFTool Flasher to downgrade my firmware?
Also, I was going to choose either the ASUS-BW-16D1HT-3.10-WM01601-211901041014 firmware -or- the ASUS-BW-16D1H-U-A204-WM01001-211901041044 firmware mostly because it is from the same maker of my drive. Is there a better of the two? Which one is the better firmware for the Asus BW-16D1X-U?
And one more thing. I would still like to use the features of the drive like M-Disk. Is this possible when downgrading firmware?
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: ************
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
MakeMKV v1.17.4 win(x64-release) started
Downloading latest SDF to C:\Users\*****/.MakeMKV ...
Please be kind. I am new and I want to learn/set up my drive. Anything that I wrote in error was not to troll or done with malice but written in ignorance. Thank you :-)
and_guazu
Re: Asus BW-16D1X-U
Post by and_guazu »
Hello so I am having an issue, I have chosen to flash to HL-DT-ST-BD-RE WH16NS60 revision 1.03 but it says that no disc is inserted when there is, is there a reason that it thinks there is no disc? Thank you for the response.
Re: Asus BW-16D1X-U
and_guazu wrote:
Thu Jul 27, 2023 5:41 am
whats your drive info look like?
and_guazu
Re: Asus BW-16D1X-U
Post by and_guazu »
OS device name: /dev/sr1
Product: BD-RE WH16NS60
Revision: 1.03
Serial number:
Firmware date: 2120-05-08 10:10
Firmware version: 1.03
Hopefully this is what you were looking for
Re: Asus BW-16D1X-U
and_guazu wrote:
Thu Jul 27, 2023 6:48 am
Revision: 1.03
Serial number: KL4LB7D3041
info look right but it could be a mt1939 drive not mt1959.
does the drive see any discs?
try cleaning the disc with a damp lint free microfiber and dry with another
and_guazu
Re: Asus BW-16D1X-U
Post by and_guazu »
Billycar11 wrote:
Thu Jul 27, 2023 6:53 am
Revision: 1.03
Drive does not appear to see any other disks but it is brand new. Before flashing it said it was mt1959 and after flashing as well
Re: Asus BW-16D1X-U
and_guazu wrote:
Thu Jul 27, 2023 6:58 am
was the drive tested before flashing?
