valington
Post by valington »
RESET_9999 wrote:
Mon May 08, 2023 1:58 am
9700PRO wrote:
Sun May 07, 2023 11:13 pm
I did as you said. Disabled mux in bat.
If i take a mkv 7 profile dolby vision then i mux it in tsmuxer and then gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages which was in previous mkv 7 profele dolby vision ?
9700PRO wrote:
Mon May 08, 2023 6:01 am
Is it possible to convert Profile 8 to Profile 7 st-dl? (Blu-ray UHD standart).
no, and st-dl is not bluray standard
valington wrote:
Mon May 08, 2023 8:49 am
gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages ?
yes, see the link in my signature for what the x800m2 support or not
Yes, it is. Here is a crude tutorial how to do it.
https://forum.redfox.bz/threads/create- ... mkv.87159/
renvan
Post by renvan »
Is it possible to change maxfall and maxcll values with the script?
renvan wrote:
Wed May 10, 2023 2:42 pm
For L6 DV yes: workflow 2-1-1
For the BL: no, not with my script.
valington
Post by valington »
RESET_9999 wrote:
Wed May 10, 2023 6:27 pm
Hi , is it possible to mux with your script MKV 7 PROFILE DOLVY VISION to
MKV HDR10+ and remove dolby vision metadate, cause i m asking it for qd-oled samsung
valington wrote:
Thu May 11, 2023 11:24 am
Yes you can remove the DV metadata/layer with 6-1-2 but you will have to mux the new HEVC file to MKV yourself with mkvtoolnix.
jkatchy2
Post by jkatchy2 »
RESET_9999 wrote:
Thu May 11, 2023 12:09 pm
So with Tool its possible to remove DV metadata , is there a way to convert that DV metadata to HDR10+ metadata ?
NiCE77
Post by NiCE77 »
@RESET_9999
Can you give me some guidance on DoViBaker?
Let's assume this is the starting script:
bl=DGSource("blclip.dgi")
el=DGSource("elclip.dgi")
DoViBaker(bl,el,rpu="RPU.bin")
If I recompress this with e.g. Handbrake, I get a 10 bit HEVC HDR10 stream containing the FEL data, to which I can add the RPU converted to Profile 8 with dovi_tool.
So why does DoViBaker need the RPU?
In this case, in which mode should the RPU be converted to P8 (preserving mapping or not)?
quietvoid
Post by quietvoid »
NiCE77 wrote:
Fri May 12, 2023 6:24 am
@RESET_9999
You use the original profile 7 RPU for DoViBaker.
And for the encode you convert to profile 8.1 (mode 2).
You have to be careful with DoViBaker as it outputs RGB by default, and a later conversion could make the colours wrong when encoding.
NiCE77
Post by NiCE77 »
quietvoid wrote:
Fri May 12, 2023 10:34 am
@RESET_9999
Thanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
So the result will not be good if we inject the RPU because double processing. But then I don't really understand what this tool is for?
quietvoid
Post by quietvoid »
NiCE77 wrote:
Fri May 12, 2023 10:55 am
Reinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.
As long as you don't tonemap using the trims in DoViBaker.
DoViBaker uses the mapping metadata and NLQ metadata to reconstruct the FEL image.
All this metadata is removed by profile 8.1 conversion (for FEL).
NiCE77
Post by NiCE77 »
quietvoid wrote:
Fri May 12, 2023 11:03 am
Many thanks!
danbez
Post by danbez »
What would be a good FFMPEG command line to create the new base layer with as close to lossless quality as possible? I am playing with two at the moment, but not sure if those are the best options if I want to focus on quality.
ffmpeg -i "example.avs" -c:v libaom-av1 -crf 23 -pix_fmt yuv444p12le av1_test.mkv --> AV1 output
ffmpeg -i "example.avs" -x265-params "hdr10-opt=1:chromaloc=2:range=limited:output-depth=10:profile=main10:level-idc=5.1:colorprim=bt2020:colormatrix=bt2020nc:transfer=smpte2084:hdr10=1:max-cll=0,0:master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" "out10.hevc"
Hellboy.
Post by Hellboy. »
If i convert a DV movie to mkv (using HandBrake or DVDFab, without DV, just normal HDR), and then put the movie in tsMuxer, add the DV video, and then create a Bluray folder or ISO, the DV works?
