Transsiberian total fail
captain
Post by captain » Sat May 28, 2011 5:08 am
here is the log:
Debug log started at Sat May 28 04:57:56 2011 , written by MakeMKV v1.6.8 darwin(x86-release)
001005:0000 MakeMKV v1.6.8 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHH" opened in DASPI v1.2 mode.
002014:0000 Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in DASPI v1.2 mode.
DCE=zTC6BRA9k8JwNY3PUMeLbORpY5ho0TY3aSBKvdBo4R3tNpPlA568oqmeYKDkDy1ku6EwTp1A4/aLB+a6XOayasw2/z7obevecfHbpalbXmgVVpBUtts1z3kTIiOJYs0hrIcff6YvIjfQy0xxuN2aRZqwvwdFSkvmCA==
DISCID=A42D4E265505DAA0189844640D42CE33A3B56D99
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #00003.mpls has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.mpls was added as title #1
003025:0000 Title #00001.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 2 titles into directory /Volumes/Blu-Ray_rips/TRANSSIBERIAN
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001003:0020 DEBUG: Code 131072 at ?9j1L.sl)vqMZS.OAsa%)G:121262325
001003:0020 DEBUG: Code 4294967295 at ?9j1L.sl)vqMZS.OAsa%)G:29394137
001003:0020 DEBUG: Code 28 at ?9j1L.sl)vqMZS.OAsa%)G:213130352
001003:0020 DEBUG: Code 0 at #er8^V3&{z8gq1#Sf:121263728
001002:0020 LIBMKV_TRACE: Exception: EOF in writeFully
005003:0000 Failed to save title 0 to file /Volumes/Blu-Ray_rips/TRANSSIBERIAN/title00.mkv
005003:0000 Failed to save title 1 to file /Volumes/Blu-Ray_rips/TRANSSIBERIAN/title01.mkv
005004:0080 0 titles saved, 2 failed
005037:0204 Copy complete. 0 titles saved, 2 failed.
Re: Transsiberian total fail
Post by mike admin » Sat May 28, 2011 12:08 pm
Your error has nothing to do with the disc - You're saving a large MKV file to a volume that either has no space left or doesn't support files longer than 4GB. Normally MakeMKV would print a warning but in your case it didn't. Please provide details about the target volume - it's size, free space and how it's formatted. Screenshot from disc utility would be helpful.
captain
Post by captain » Sat May 28, 2011 6:47 pm
Oh, duh! Sorry. 38MB left, not GB. :-P
captain
Post by captain » Sat May 28, 2011 7:43 pm
However, now I have 71GB free. (it's HFS+, journal on, GUID formatted) I restarted the iMac, powercycled the blu-ray drive... Now I get the errors:
MakeMKV v1.6.9 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHH" opened in DASPI v1.3 mode.
Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in DASPI v1.3 mode.
DEBUG: Code 100864261 at fa)R!D4q3:f>Uk<*F-:29395678
DEBUG: Code 100864261 at fa)R!D4q3:f>Uk<*F-:121262049
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM PLEXTOR BDDVDR PX-B310U 1.07' at offset '24645400576'
which repeats over and over again.
Oh, wait, that was on a different blu-ray disc.
Now TransSiberian is ripping fine. Maybe this is just a long series of unrelated compounding problems, and ultimately a bad disc?
Oh, and just to befuddle the mess, I got the latest version of MakeMKV and the direct drive plugin thing. I'm sure I'll have a new report on the disc that just failed.... coming up
crowfax
Post by crowfax » Sun May 29, 2011 12:52 am
captain wrote:Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM PLEXTOR BDDVDR PX-B310U 1.07' at offset '24645400576'
Damaged/poorly manufactured disc, or failing drive.
captain
Post by captain » Mon May 30, 2011 1:50 am
Ah ha! I now see that there is a .75cm crack on the outside edge of the disc that returned those errors, and still refuses to rip with the new NEW version of MakeMKV. Damn, Mike, you're churning out revisions fast this month! ;-)
Odd, though, I thought that blu-ray discs were like DVDs, in that they start at the center and data is added from center to outer edge. So this crack should only affect the last 2% of the data, not cause a total failure to rip.... Or does MakeMKV read the entire disc first, and refuse to rip it if any errors are found? Why then, would it act like it is ripping, get 20% of the way through, and then fail? Is there a key to error messages so I can stop bugging you about bad discs?
Does the "DEBUG: Code" mean nothing, but it's the "Scsi error" that I should recognize as a bad disc, bad player error?
Anwyay, now I get this on the outer-cracked disc:
DEBUG: Code 100864261 at ,[`\%E,AK"z#()E{Jg:29395678
DEBUG: Code 100864261 at ,[`\%E,AK"z#()E{Jg:121262049
(repeats a few times, then succeeds)
DEBUG: Code 1073741829 at ,[`\%E,AK"z#()E{Jg:29395678
DEBUG: Code 1073741829 at ,[`\%E,AK"z#()E{Jg:121262049
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk12' at offset '24645400576'
File 00010.mpls was added as title #0
File 00011.mpls was added as title #1
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00023.m2ts was added as title #2
File 00024.m2ts was added as title #3
File 00025.m2ts was added as title #4
and... it starts ripping....
PS: if it's the case that MakeMKV is discovering that the last 2% of data on the disc cannot be reliably read, could there be a dialog box that pops up saying so, and offering the chance to rip the other 98%? This is *exactly* why I want to rip my discs in the first place! If one starts to crack, I'll want to back up as much as possible and either store the data on a new blu-ray-R or some other medium before the expensive one goes belly up.
Post by mike admin » Tue May 31, 2011 10:10 am
captain wrote:PS: if it's the case that MakeMKV is discovering that the last 2% of data on the disc cannot be reliably read, could there be a dialog box that pops up saying so, and offering the chance to rip the other 98%?
This is exactly what it does - it tries to read the file ignoring damaged part. The problem is that if if too much is damaged then entire conversion would fail.
For backup, there is a hidden setting to ignore read errors, so you can copy everything that is still readable. The question is, what to do next with this copy, as any conversion tool will likely fail on it.
captain
Re: Transsiberian total fail - resolved
Post by captain » Wed Jun 01, 2011 9:25 pm
well... I got a new Transsiberian blu-ray disc and it ripped just fine. Mark this thread as RESOLVED. :-)
