xcoaster1
#1
Post
by xcoaster1 » Thu May 11, 2023 12:11 am
Various discs are returning various errors, tried to rip to a slower drive (USB, SATA) as opposed to the NVMe drive and still return the errors:
Saving 1 titles into directory E:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00066.m2ts' at offset '171896832'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '171896832'
Failed to save title 0 to file E://Turning Red_t00.mkv
Encountered 39 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Saving 1 titles into directory F:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00147.m2ts' at offset '0'
Failed to save title 1 to file F://Turning Red_t01.mkv
Encountered 5 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
#2
Post
by Woodstock » Thu May 11, 2023 1:02 am
Looks remarkably like the errors one gets when a drive is not getting sufficient power to run at full speed. How is your Bluray drive powered?
xcoaster1
#3
Post
by xcoaster1 » Thu May 11, 2023 12:25 pm
switched up all connections and power and seems to have helped but still encountering errors. Not all discs are returning errors
aving 1 titles into directory D:/video
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00110.m2ts' at offset '194064384'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '194064384'
Failed to save title 0 to file D:/video/Turning Red_t00.mkv
Encountered 34 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
#4
Post
by dcoke22 » Thu May 11, 2023 3:25 pm
Have you seen this thread?
If you're experiencing rip errors, please read here first!
MEDIUM ERROR:L-EC UNCORRECTABLE ERROR usually means the optical drive could not correctly read the disc for some reason.
STATUS_DEVICE_DATA_ERROR often means the drive went offline for some reason, usually not enough power in the case of being powered by USB.
That those errors are all at the same offset probably means there's something the drive is struggling with at that spot. A gentle disc cleaning is a good first step. Trying the disc in a different drive is also a reasonable course of action.
xcoaster1
#5
Post
by xcoaster1 » Thu May 11, 2023 7:47 pm
this has to be an issue with MakeMKV as HandBrake is working as well as LeLeawo software. I prefer to use MakeMKV due to simplicity.
#6
Post
by Woodstock » Thu May 11, 2023 8:04 pm
Then it would seem that moving SLOWER doesn't overwhelm the drive's power. It's running out of energy the faster MakeMKV tries to spin it.
So your choices would be either slowing the writing down, so that MakeMKV doesn't try to read at full speed, or providing enough power to keep the drive from shutting down.
Handbrake cannot run a BD or UHD drive, so it isn't going to spin it fast enough to shut down.
xcoaster1
#7
Post
by xcoaster1 » Thu May 11, 2023 8:20 pm
outside of running it on a slower drive (aka USB) is there any other way to make MakeMKV run at lets say 1x or 2x?
