Mystery DVD won't rip but will play in DVD player
JustSomeGuy
Post by JustSomeGuy » Mon May 08, 2023 3:57 pm
I have a DVD I purchased before 2015, maybe 2010. MKV tries for a bit, then fails, and says 'no disc'. I tried playing it and the apple DVD Player also says 'no disc' so I assumed it was a bad dvd.
However, I can play it in my DVD player. It seems to play fine, with no skipping or freezes. Anyone have any suggestions on how to get it to rip?
Here is the output from MakeMKV when I try:
DEBUG: Code 101000192 at LHLd>,:XQ hoYXW(uJ:213132445
DEBUG: Code 101000192 at LHLd>,:XQ hoYXW(uJ:121262302
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE BUFFALO Optical Drive BN14 MOEM5A80855' at offset '0'
DEBUG: Code 3 at A6J`{yh*d8]Z1s:29400232
DEBUG: Code 3 at A6J`{yh*d8]Z1s:29393631
DEBUG: Code 0 at L!cv]s?~R#@-9jA^p:121263245
DEBUG: Code 0 at *t=7,'<i.uT>97wf:121262302
DEBUG: Code 101000192 at LHLd>,:XQ hoYXW(uJ:121263429
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading 'BD-RE BUFFALO Optical Drive BN14 MOEM5A80855' at offset '688128'
DEBUG: Code 256 at 'He45{[q-y^5,6lA[]*$o,/:29395586
DEBUG: Code 336 at 'He45{[q-y^5,6lA[]*$o,/:213131939
DEBUG: Code 4294967295 at _%SXZ,ljdE.zAAv}?&ui:213133250
DEBUG: Code 0 at _%SXZ,ljdE.zAAv}?&ui:121265062
DEBUG: Code 0 at _%SXZ,ljdE.zAAv}?&ui:29394689
DEBUG: Code 0 at 'He45{[q-y^5,6lA[]*$o,/:121263406
DEBUG: Code 0 at sg+vC4:"mHe"u/:29397104
Cells 1-1 were removed from title start
Cells 32-32 were removed from title end
DEBUG: Code 62264 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 134899 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 181826 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 217434 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 279074 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 314315 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 360037 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 450724 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 566631 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 651875 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 676054 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 782593 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 854388 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 939180 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1012395 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1016789 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1131263 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1221919 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1362403 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1413549 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1460804 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1546130 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1633464 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1716788 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1786744 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1825395 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1847428 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1899919 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1929342 at A6J`{yh*d8]Z1s:213132721
DEBUG: Code 1973679 at A6J`{yh*d8]Z1s:213132721
Title #1 declared length is 1:41:23 while its real length is 0:00:00 - assuming fake title
Title #3 in broken titleset was skipped
JustSomeGuy
Re: Mystery DVD won't rip but will play in DVD player
Post by JustSomeGuy » Mon May 08, 2023 4:04 pm
Update - I swapped out the drive for an apple Super Drive and was able to play the DVD on my computer and MakeMKV had no problem reading the disc and is currently ripping.
Previous drive was a Buffalo BD and it has ripped over a 100 DVDs without issue.
Post by dcoke22 » Mon May 08, 2023 9:51 pm
Do this long enough and you'll end up with a fleet of optical drives. The same disc in a different optical drive will often times yield different results. :)
JustSomeGuy
Post by JustSomeGuy » Tue May 09, 2023 1:06 am
Heh, I can see that. I just wanted to make sure there wasn't some setting I could try. I have learned so much about using MakeMKV from everyone here.
