Downloading MakeMKV without Internet
JVMKQ
Post by JVMKQ »
Hello. I wanted to use MakeMKV on a Mac with no Internet. So what I did was: I downloaded the program on a different computer, put the program on a flashdrive, and then downloaded the program from the flashdrive to my Mac without Internet. This worked fine for one month. But I now get that message saying "Evaluation period has expired. Please purchase an activation key if you've found this application useful."
Is it possible to purchase the activation key on a computer without Internet? Is there any other way I can re-install a MakeMKV which I can keep on this Mac? Any suggestions of anything I can try? Thanks.
Re: Downloading MakeMKV without Internet
The key can be obtained without having MakeMKV installed on the computer you "order" through. It will come in an email, which you can then copy to the computer in question, OR type in manually (long key, pain in the ... to do). You can practice it by installing the new beta key that came out a few weeks ago, post here, if you're not wanting to buy right now.
JVMKQ
Post by JVMKQ »
Thank you very much. Where in the program do I go to install this new beta key?
Help->Register
Big long blank to type (or paste) in to.
JVMKQ
Post by JVMKQ »
I now wish to purchase the key to have MKV on my computer permanently. Where exactly do I go to make such a purchase? Thank you.
JVMKQ wrote:
Mon May 08, 2023 6:07 am
https://www.makemkv.com/buy/
JVMKQ
Post by JVMKQ »
Thank you!
JVMKQ
Post by JVMKQ »
Do I want "License to another person?"
I think I explained the details of what I'm doing - which is NOT downloading it directly on to the same computer I'm purchasing it with, but rather getting a password so I can permanently have the program on another computer without Internet service.
Thanks.
