Thank you Boss!RESET_9999 wrote: Tue May 02, 2023 2:05 pm
Unfortunately no but check out the new version I will upload today (1.8.3). Only for this time, I will share the tools with the bat file because there are a lot of new tools/DLL to add.
I implemented the DoVi_Baker (FEL screenshot maker) into a workflow that index and creates an avisynth script that can be opened in avspmod or MPC.
Mrmorrison
valington
I did all what you said and it s not working, i don t no why, i make a new folder named it Dovi.Scripts, put the beta bat file and the tools folder and it s till don t work ,shows that it couldn t find the way input file not 7 profileRESET_9999 wrote: Sun May 07, 2023 3:18 pm make a new folder. example ''DoVi.Scripts'' (preferably no space nor special characters)
put the beta bat file and tools folder in it.
Click on the bat file and select your workflow.
9700PRO
I'm sorry, but I didn't understand much.RESET_9999 wrote: Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)9700PRO wrote: Sun May 07, 2023 1:20 pm Hello RESET_9999, tell me please, I made an mkv file with Dolby Vision. How do I get DV in HEVC file like it is made in UHD Blu-ray discs? Thanks in advance for your reply.
then use workflow (4-3) and when it's completed, select bluray folder (or iso) in tsmuxer and mux.
What is obvious to you is not to me. I created a TS container in it with 8.1 DV video (as far as I understand). Next, i need to make profile 7, which is not clear how, there is no downgrade option. And then apparently from it I should get the desired file. In UHD format, this is a 1920x1080 hevc DV file. But none of this works. Is it even possible? I beg you to help and make step by step instructions. By the way, if you load the received ts with DV into Ateme Titan, then he does not see DV there. Perhaps Profile 7 is just needed. It's also not clear how to get it. I will be very grateful for your help.
9700PRO
I did as you said. Disabled mux in bat. And TSmuxer created a file for me with two videos. But these are just 2 identical files. Tsmuxer himself wrote to me that this is not Dolby Vision of the Blu-ray standard and it will not be played by these players.RESET_9999 wrote: Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)9700PRO wrote: Sun May 07, 2023 1:20 pm Hello RESET_9999, tell me please, I made an mkv file with Dolby Vision. How do I get DV in HEVC file like it is made in UHD Blu-ray discs? Thanks in advance for your reply.
9700PRO
Dear RESET_9999. Thank you very much for trying to help me. But I can't
Is it possible to convert Profile 8 to Profile 7 st-dl? (Blu-ray UHD standart).
valington
If i take a mkv 7 profile dolby vision then i mux it in tsmuxer and then gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages which was in previous mkv 7 profele dolby vision ?
no, and st-dl is not bluray standard9700PRO wrote: Mon May 08, 2023 6:01 am Is it possible to convert Profile 8 to Profile 7 st-dl? (Blu-ray UHD standart).
yes, see the link in my signature for what the x800m2 support or notvalington wrote: Mon May 08, 2023 8:49 am gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages ?
Yes, it is. Here is a crude tutorial how to do it.
https://forum.redfox.bz/threads/create- ... mkv.87159/
renvan
Is it possible to change maxfall and maxcll values with the script?
For L6 DV yes: workflow 2-1-1renvan wrote: Wed May 10, 2023 2:42 pm Is it possible to change maxfall and maxcll values with the script?
For the BL: no, not with my script.
valington
Hi , is it possible to mux with your script MKV 7 PROFILE DOLVY VISION toRESET_9999 wrote: Wed May 10, 2023 6:27 pmFor L6 DV yes: workflow 2-1-1renvan wrote: Wed May 10, 2023 2:42 pm Is it possible to change maxfall and maxcll values with the script?
MKV HDR10+ and remove dolby vision metadate, cause i m asking it for qd-oled samsung
Yes you can remove the DV metadata/layer with 6-1-2 but you will have to mux the new HEVC file to MKV yourself with mkvtoolnix.valington wrote: Thu May 11, 2023 11:24 am Hi , is it possible to mux with your script MKV 7 PROFILE DOLVY VISION to
jkatchy2
So with Tool its possible to remove DV metadata , is there a way to convert that DV metadata to HDR10+ metadata ?RESET_9999 wrote: Thu May 11, 2023 12:09 pm Yes you can remove the DV metadata/layer with 6-1-2 but you will have to mux the new HEVC file to MKV yourself with mkvtoolnix.
NiCE77
@RESET_9999
Can you give me some guidance on DoViBaker?
Let's assume this is the starting script:
bl=DGSource("blclip.dgi")
el=DGSource("elclip.dgi")
DoViBaker(bl,el,rpu="RPU.bin")
If I recompress this with e.g. Handbrake, I get a 10 bit HEVC HDR10 stream containing the FEL data, to which I can add the RPU converted to Profile 8 with dovi_tool.
So why does DoViBaker need the RPU?
In this case, in which mode should the RPU be converted to P8 (preserving mapping or not)?
