#8281 Post by RESET_9999 » Sun May 07, 2023 2:36 pm
valington wrote: Sun May 07, 2023 2:28 pm
well then, maybe you didnt download the tool pack?? This is the only reason I can see.
your script folder must look like this:
valington wrote: Sun May 07, 2023 2:30 pm What does it mean disable the muxing at line 22 ?
All the workflows mux to TS or MKV by default.
MP4 workflows are not affected by this setting.
valington
#8282 Post by valington » Sun May 07, 2023 3:13 pm
RESET_9999 wrote: Sun May 07, 2023 2:36 pm
I downloaded the tool pack at the one of disks of my computer i guess i did it wrong cause my script folder didnt look like properly as you show , please show how to do it properly ,sorry for lot of my questions
#8283 Post by RESET_9999 » Sun May 07, 2023 3:18 pm
make a new folder. example ''DoVi.Scripts'' (preferably no space nor special characters)
put the beta bat file and tools folder in it.
Click on the bat file and select your workflow.
Mrmorrison
#8284 Post by Mrmorrison » Sun May 07, 2023 7:08 pm
RESET_9999 wrote: Tue May 02, 2023 2:05 pm
Unfortunately no but check out the new version I will upload today (1.8.3). Only for this time, I will share the tools with the bat file because there are a lot of new tools/DLL to add.
I implemented the DoVi_Baker (FEL screenshot maker) into a workflow that index and creates an avisynth script that can be opened in avspmod or MPC.
Thank you Boss!
valington
#8285 Post by valington » Sun May 07, 2023 7:23 pm
RESET_9999 wrote: Sun May 07, 2023 3:18 pm make a new folder. example ''DoVi.Scripts'' (preferably no space nor special characters)
I did all what you said and it s not working, i don t no why, i make a new folder named it Dovi.Scripts, put the beta bat file and the tools folder and it s till don t work ,shows that it couldn t find the way input file not 7 profile
9700PRO
#8286 Post by 9700PRO » Sun May 07, 2023 10:06 pm
RESET_9999 wrote: Sun May 07, 2023 2:26 pm
9700PRO wrote: Sun May 07, 2023 1:20 pm Hello RESET_9999, tell me please, I made an mkv file with Dolby Vision. How do I get DV in HEVC file like it is made in UHD Blu-ray discs? Thanks in advance for your reply.
get the TS version of my script and disable the muxing at line 22 (set MUX=NO)
then use workflow (4-3) and when it's completed, select bluray folder (or iso) in tsmuxer and mux.
I'm sorry, but I didn't understand much.
What is obvious to you is not to me. I created a TS container in it with 8.1 DV video (as far as I understand). Next, i need to make profile 7, which is not clear how, there is no downgrade option. And then apparently from it I should get the desired file. In UHD format, this is a 1920x1080 hevc DV file. But none of this works. Is it even possible? I beg you to help and make step by step instructions. By the way, if you load the received ts with DV into Ateme Titan, then he does not see DV there. Perhaps Profile 7 is just needed. It's also not clear how to get it. I will be very grateful for your help.
9700PRO
#8287 Post by 9700PRO » Sun May 07, 2023 11:13 pm
I did as you said. Disabled mux in bat. And TSmuxer created a file for me with two videos. But these are just 2 identical files. Tsmuxer himself wrote to me that this is not Dolby Vision of the Blu-ray standard and it will not be played by these players.
#8288 Post by RESET_9999 » Mon May 08, 2023 1:58 am
9700PRO wrote: Sun May 07, 2023 11:13 pm I did as you said. Disabled mux in bat.
9700PRO
#8289 Post by 9700PRO » Mon May 08, 2023 6:01 am
RESET_9999 wrote: Mon May 08, 2023 1:58 am
Dear RESET_9999. Thank you very much for trying to help me. But I can't :-). I'm sorry but I don't seem to understand the obvious. Yes, I made an ISO. But inside it there are also 2 identical video files. In your own video, they are already correct. And if I then try to convert this iso in your program, I get an error that it does not see DV st-dl. Apparently the main question is how do I get this particular dv file 1920x1080 profile 7?
Is it possible to convert Profile 8 to Profile 7 st-dl? (Blu-ray UHD standart).
valington
#8290 Post by valington » Mon May 08, 2023 8:49 am
If i take a mkv 7 profile dolby vision then i mux it in tsmuxer and then gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages which was in previous mkv 7 profele dolby vision ?
#8291 Post by RESET_9999 » Mon May 08, 2023 11:00 am
9700PRO wrote: Mon May 08, 2023 6:01 am Is it possible to convert Profile 8 to Profile 7 st-dl? (Blu-ray UHD standart).
no, and st-dl is not bluray standard
valington wrote: Mon May 08, 2023 8:49 am gonna play it in x800m2 sony player from usb, do i get truly dolby vision with all subtitles and all languages ?
yes, see the link in my signature for what the x800m2 support or not
#8292 Post by Coopervid » Mon May 08, 2023 5:47 pm
Yes, it is. Here is a crude tutorial how to do it.
https://forum.redfox.bz/threads/create- ... mkv.87159/
renvan
#8293 Post by renvan » Wed May 10, 2023 2:42 pm
Is it possible to change maxfall and maxcll values with the script?
#8294 Post by RESET_9999 » Wed May 10, 2023 6:27 pm
renvan wrote: Wed May 10, 2023 2:42 pm Is it possible to change maxfall and maxcll values with the script?
For L6 DV yes: workflow 2-1-1
For the BL: no, not with my script.
valington
#8295 Post by valington » Thu May 11, 2023 11:24 am
RESET_9999 wrote: Wed May 10, 2023 6:27 pm
Hi , is it possible to mux with your script MKV 7 PROFILE DOLVY VISION to
MKV HDR10+ and remove dolby vision metadate, cause i m asking it for qd-oled samsung
