Are you sure about that?
the script uses mediainfo to read the profile information so maybe your file doesn't have p7 DV or it's not muxed properly.
Yes i m sure it is 7 profile mkv 7 profile dolby vision remux from RARBG FGT tracker maybe you will show how to do it properly all the stepsRESET_9999 wrote: ↑Sun May 07, 2023 12:11 pmAre you sure about that?
mediainfo of your file?
get the TS version of my script and disable the muxing at line 22 (set MUX=NO)
RESET_9999 wrote: ↑Sun May 07, 2023 2:24 pmmediainfo of your file?
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 35 min
Bit rate : 76.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.383
Stream size : 51.0 GiB (86%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
What does it mean disable the muxing at line 22 ?RESET_9999 wrote: ↑Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)
then use workflow (4-3) and when it's completed, select bluray folder (or iso) in tsmuxer and mux.
well then, maybe you didnt download the tool pack?? This is the only reason I can see.
All the workflows mux to TS or MKV by default.
I downloaded the tool pack at the one of disks of my computer i guess i did it wrong cause my script folder didnt look like properly as you show , please show how to do it properly ,sorry for lot of my questionsRESET_9999 wrote: ↑Sun May 07, 2023 2:36 pmwell then, maybe you didnt download the tool pack?? This is the only reason I can see.
your script folder must look like this:
MP4 workflows are not affected by this setting.
Thank you Boss!RESET_9999 wrote: ↑Tue May 02, 2023 2:05 pm
Unfortunately no but check out the new version I will upload today (1.8.3). Only for this time, I will share the tools with the bat file because there are a lot of new tools/DLL to add.
I implemented the DoVi_Baker (FEL screenshot maker) into a workflow that index and creates an avisynth script that can be opened in avspmod or MPC.
I did all what you said and it s not working, i don t no why, i make a new folder named it Dovi.Scripts, put the beta bat file and the tools folder and it s till don t work ,shows that it couldn t find the way input file not 7 profileRESET_9999 wrote: ↑Sun May 07, 2023 3:18 pmmake a new folder. example ''DoVi.Scripts'' (preferably no space nor special characters)
put the beta bat file and tools folder in it.
Click on the bat file and select your workflow.
I'm sorry, but I didn't understand much.RESET_9999 wrote: ↑Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)
I did as you said. Disabled mux in bat. And TSmuxer created a file for me with two videos. But these are just 2 identical files. Tsmuxer himself wrote to me that this is not Dolby Vision of the Blu-ray standard and it will not be played by these players.RESET_9999 wrote: ↑Sun May 07, 2023 2:26 pmget the TS version of my script and disable the muxing at line 22 (set MUX=NO)
