MakeMKV UHD direct disc playback with Windows
Davidpe76
Post by Davidpe76 »
I tried to search but was not able to find anything. I have the paid version of MakeMKV.
While I am able to rip UHD disks and play them back fine using VLC, if I attempt to play the UHD disk directly using VLC I get stuttering and anywhere around the 1 hour mark the video will stop playing but the sound continues in the background.
Is their a solution to be able to watch a UHD title directly without first ripping it to my HD ?.
Thankyou.
David.
Davidpe76
Re: MakeMKV UHD direct disc playback with Windows
Post by Davidpe76 »
Does everyone just rip their disks directly to PC ?.
Surely their is the ability to watch by putting the disc in instead of ripping it ?
Thanks,
David.
It's less used to watch disks without ripping, frankly. Also, pausing the video for too long (letting the disk stop spinning) can have issues.
Davidpe76
Post by Davidpe76 »
Thankyou, I always thought once the drive was cracked you could use them to play content on your PC (without ripping) instead of TV
(if you buy player)
